Question about Toshiba 51H84 51" Rear Projection HDTV-Ready Television
My toshiba 51H84 has picture but no sound,was watching heard a snap like static then no sound.
Sounds like either a transformer or somthing that handles the output for the projectors got blown
Posted on Jul 18, 2010
Toshiba 37" LCD flat screen. I heard a small
Get a quote from a TV repairer then you can decide if it us worth repairing.
Mar 30, 2013 | Televison & Video
Internal interference
ok you can used the matching transformer to avoid the interference. or you can buy a 'interference free'at the electronics stores!
Oct 06, 2007 | Toshiba 51H84 51" Rear Projection...
I have a Toshiba 51h84.I push the power button and I get a solid red power light. There is a click from inside, kind of like a relay clicking on. No picture, no sound. If I leave it on I get an occasional...
Tv have "LAMP" indication LED light blinking?The tv projection lamp is dead,require changing.Hearing alot of clickings sound too?Mean the board,call the Ballast board is dead.Require change the Ballast too.The Ballast board,the board that help to ignite the projection lamp.
Aug 06, 2010 | Toshiba 51H84 51" Rear Projection...
Toshiba 51h84 "Crooked Picture"
Still the convergece prob.The FL231 fuse near the FBT transformer it dead.The square fuses 3 rectangles fuses.One in the middle.
Aug 09, 2009 | Toshiba 51H84 51" Rear Projection...
Loud static type snap from tv
TV's use high voltage to generate the stream of electrons traveling across the picture tube hitting the screen and lighting it up (thus the name Cathode Ray Tube). It takes about 25,000 volts to do this. In normal air, it takes about 1000 volts to jump an inch of air, so the high voltage transformer needs to have good insulation. It generates the voltage through a technique of charging the transformer's magnetic field with a low voltage of about 140 volts then letting it go where upon it flys back out the high voltage side at much high levels (Thus the common name flyback). A most common failure in a CRT type TV is for the insulation to crack in this transformer which is a unique component for each model of TV and leak out the current overstressing the circuit driving it. You can liken it to a little bolt of lightning getting loose in the circuit and has the same sound on a smaller scale.
It would be well to replace your flyback transformer before it gets worse and blows up something else as well. Best done by a professional used to handling high voltage. The picture tube can retain voltage even when the TV is unplugged for some time, and replacing the anode lead (the big red one) can be dangerous.
Hope Ya Fix It!
Jan 09, 2008 | Toshiba 51H84 51" Rear Projection...
Toshiba theaterview tz50v51
my guess would be flyback however your lucky you might be able to see a burnt spot on the board giving you a better clue.
Nov 25, 2007 | Toshiba 55H70 55" Rear Projection...
Toshiba 51H84
convergence IC's need to be replaced
Dec 12, 2006 | Toshiba 51H84 51" Rear Projection...
Toshiba 51H84
is the waves running horizontal?
Dec 02, 2006 | Toshiba 51H84 51" Rear Projection...
Toshiba 51H84 51" Rear Projection HDTV-Ready Television Logo
125 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
