Question about Fujitsu ScanPartner fi-4120C2 Path-Through Scanner
Background changeover unit failure on 6130dj scanner. Tried cleaning it, rebooting pc & downloading driver . . . what else can I do?
    Novelist:
  • 104 Answers
When a background switching malfunction occurs, "F" and "4" will display alternately on the function number display panel of the scanner.
Wipe the top and bottom glasses located inside the ADF with the Cleaner F1 and check if the problem persists.
If turning on the scanner again does not recover the situation, then follow the procedures provided below:
1 Does the same symptom occur after turning OFF and ON the scanner? Press power button of the scanner for more than 2 seconds to turn it OFF, and after more than 2 seconds elapse, press the power button to turn the scanner ON.
2 Are the cables between the Control PCA and the BW Motor damaged? Or are the connectors connected correctly?
3 Is the white reference work properly? If not, then replace the BW Motor.Perform background changeover test.
4 Is the OPT Unit installed correctly? Check ADF (Front) and ADF (Back)
5 Replace the Control PCA and see if the error is resolved.
6 Replace the OPT Unit and see if the error is resolved.
Hope the above information is helpful.
Thanks,
ScanCare
Posted on Sep 28, 2011
Background changeover unit failure [fi-5120Cdj #2 , 048005 , c2]
Posted on Aug 18, 2010
2 Suggested Answers
TechSatya
  • 104 Answers
SOURCE: Background changeover unit failure
Hi Vivek,
Thank you for contacting Fixya.
When a background switching malfunction occurs, "E" and "F" will display alternately on the function number display panel of the scanner.
Background changeover unit failure error is detected in initial checking at power on. Probable causes:
- Insulation material damage of BW motor cable or the damage of the wire in the motor. - Defective lamp or CCD or CCD cables. - CCD Connector disconnected. - Defective Control PCA.
Solution:
Wipe the top and bottom glasses located inside the ADF with the Cleaner F1 (or isopropyl alcohol) and check if the problem persists.
1. Does the same symptom occur after turning OFF and ON the scanner? Press power button of the scanner for more than 2 seconds to turn it OFF, and after more than 2 seconds elapse, press the power button to turn the scanner ON. 2. Check if the cables between the Control PCA and the BW motor damaged? Are the connectors connected correctly? Check & confirm the position of the BW motor and check the cables. 3. Check Is the CCD cable F or B damaged? Or are the connectors connected correctly? 4. Check if the OPT Unit is installed correctly? 5. Check if the white reference works properly? If not, then replace the BW Motor. 6. If the above do not resolve your issue, then you may have to replace the Control PCA or Optical unit to see if the error is resolved.
Hope the above information is helpful.Please revert if you have any doubt.
Regards,
TechSatya
Posted on Aug 19, 2010
Code EF 5120c
"EF error" in Fujitsu fi-5120c scanner refers to Background changeover unit failure. This error is detected in initial checking at power on.
Probable causes:
Check the followings:
1.Does the same symptom occur after turning OFF and ON the scanner?
2.Are the cables between the Control PCA and the BW motor damaged? Or are the connectors connected correctly? Confirm the position of the BW motor and check the cables.
3.Is the CCD cable F or B damaged? Or are the connectors connected correctly?
If the above information doesn't help, then you are recommended to visit the nearest Fujitsu service center for assistance.
Thanks & regards,
ScanCare
Mar 03, 2014 | Fujitsu fi-5750C Flatbed Scanner
Cursor frozen
Background running programs must be the reason for that you must use some start up manager or background application manager to avoid your PC from freezing & slowing down, The one well known and reliable program is Reginout to manage everything on your PC.
Nov 18, 2013 | Dell Inspiron Computers & Internet
Error EF
The error code EF displayed on your fi-5750c scanner front panel explains Background switching mechanism alarm. The probable causes are:- Background detection sensor connector disconnected.
- Defective background detection sensor
- BW motor connector disconnected, Defective BW motor
- Defective background unit F
- Defective background unit B
You are rceommended to visit nearest Fujitsu service station for rectification.
Thanks & regards,
ScanCare
Nov 07, 2013 | Fujitsu fi-5750C Flatbed Scanner
I download hp 5590 drivers from hp.com i tried to install it, the proces eend normaly, but if i connect the scanner, windows xp show the new hp connect like its not installed yet. I check at add remove...
FIRST UNINSTALL YOUR PRINTER COMPLETELY
REMOVE ALL CABLES OF PRINTER (USB)
REBOOT YOUR SYSTEM
HAVE DRIVER CD
PUT IT IN ROM(CD/DVD)
INSTALL PRINTER SOFTWARE
DONOT PLUG THE USB CABLE UNLESS & UNTILL PROMPTED
PLUG USB WHEN ASKED
FINISH INSTALLING PRINTER
NOW YOU CAN FIND THE SCANNER
Feb 15, 2011 | HP Scanjet 5590 Flatbed Scanner
Hi Vivek,
Solution:
Regards,
TechSatya
Aug 18, 2010 | Fujitsu ScanPartner fi-4120C2 Path-Through...
I was working with my scanner for 2 years and suddenly it stopped working. I deleted all the drivers and tried to install again the hardward. Now it ask me for this driver hpxp2436.dll. I have the...
Go to the link below, download the latest copy, unplug scanner, install software and reboot, plug in scanner, and it may ask for a driver, if so, show it to where the files are, reboot. You should now be OK. If still no go, go to device manager, totally remove ALL USB, uninstall it. Then reboot, then re-install software, reboot, at desktop next, NOW plug in scanner, if required show where drivers are, reboot, at desktop next you should be OK. Driver link below, remember you must install the actual scanning software as well. Also get Vuescan.. it's real good & doesn't need drivers etc.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=297430&
Feb 26, 2010 | HP ScanJet 2400 Flatbed Scanner
Fi4990C
When the scanner scans the first image it will bring in via a set of solenoids a background white Reference metal flap for both rear and front cameras.
The above error comes about when the solenoids are sticking or they have magnetised themselves.
1.Clean the Solenoids.
if scanner still errors .
2. Replace solenoids.
Dec 30, 2008 | Fujitsu M4099D/FI-4990C Scanners
Need a solution for failure of the ialmrnt5 display driver
Hello, I've Previously had this problem while using both the onboard and an extra pci videocard. The easiest way for me to fix it was usually going to the hardware manager, removing all drivers for all video devices, turning off the computer. Then when it is back on, do not let it reinstall the drivers, instead make sure your intel chipset has the newest drivers, if it does, then make sure the intel video card drivers are installed and working properly, then move onto the pci videocards drivers.
In this order, CHIPSET, ONBOARD VIDEO, ADDON VIDEO CARD (Is you use one). Reboot between each one to ensure the settings save.
Another strange problem i have every now and then, is that when i use an image (VERY LARGE IMAGE) as my desktop, the settings for the onboard intel "forget" themselfs, They just, stop, and the card always starts in 8bit mode with the lowest screen size. Changing the background image for my login page(NOT WELCOME SCREEN, ONLY LOGIN PAGE BACKGROUND) it continued to remember settings.
Other than this, the intel driver uses a dom+ service on the windows machine to read/write settings, if you have disabled dom+ or any of its dependencies, you may not be able to use the intel driver set.
Jul 07, 2008 | ASUS P4P800-MX Motherboard
Cant scan from hp 3110 photosmart printer
You are having hardware communication problems caused, very likely, by driver installation troubles. Go into CONTROL PANEL and then SYSTEM and then DEVICES and look for the scanner there under IMAGING DEVICES and check to see if it has an exclamation mark next to it, or if any other device has this mark, meaning that drivers are not installed for it. If there is no scanner but you have a warning icon labeled UNKNOWN DEVICE, this is the problem. If you find any non-functioning hardware devices, this is probably it.
Try this as a fix. Unplug the cable to the printer/scanner.
Go online to HP and download the latest drivers and utilities for the scanner/printer and save them to your desktop.
In CONTROL PANEL, open ADD REMOVE PROGRAMS. Scan down and remove (uninstall) anything related to the HP printer or scanner, everything. Then reboot. Then install the drivers and utilities on your desktop you saved previously, plugging in the unit when prompted to do so. If you are never prompted, plug it in at the very end when everything is installed. If this routine fails, try rebooting the system without the HP scanner plugged in, wait for a complete start-up, and then plug the scanner into a different USB port and follow the directions on screen taking note of any failure messages. PS: the scanner/printer needs to be powered on through all of this, of course. :>)
Good luck
Nov 16, 2007 | HP Pavilion dv4000 Notebook
Epson RX425 multifunction
Just cracked it, had same prob...printer would print but wouldn't scan
lost original CD...tryed epson downloads but not the older versions...
i needed the 2.6 version
TRY THIS
http://driverscollection.com/?file_id=24466
Sep 13, 2007 | Epson Stylus RX425 Multifunction...
Fujitsu ScanPartner fi-4120C2 Path-Through Scanner Logo
1,260 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Tony
Jax Planet
Jax Planet
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
