Question about Acer TravelMate 5720-6635 Notebook
Can not reset clock
Screen displays CMOS battert on ACER Model 603TER. I can not locate battery. I requested this last week and the response was wrong.
    Sergeant:
    Champion:
  • 305 Answers
Turn computer over you will see 3 removeable panels not sure wich panel its under so look care fully for a watch type battery make sure its not the type thats soldered in acer dont usually do this. remove battery very carfully use plastic tweezers then buy new battery, size and type on battery. any retail shop that sells battery.
then replace.
hope this helps.
Posted on Apr 29, 2010
BIOS
Step 1:
This might not be your laptop it might give you a guide into the cmos battery
The CMOS (Complementary Metal Oxide Semiconductor) battery saves basic settings on your computer. If the date and time function on your Acer notebook isn't working, chances are your CMOS battery needs to be replaced. Separate from your laptop's main battery, the CMOS battery is about the and shape of a coin and is located inside of your computer. Changing the battery yourself isn't the simplest task that relates to your Acer, but it isn't terribly difficult either. Here's how.
Open the notebook screen until you can easily access the keyboard. Locate the plastic bar that borders the top of the keyboard. Insert the flat head screwdriver at one end of the bar and gently pry it up until you can grip the edge with your fingers. Pry the other side of the bar up with the screwdriver and pull out the entire bar, being careful to mind the ribbon cord that connects the keyboard to the computer. Remove the two screws on either side of the keyboard that secure it to the computer. Slide the keyboard up and place it to the side. Remove the four screws on the exposed metal plate that covers the motherboard and remove it. You should now see the CMOS battery in the bottom-right-hand corner of the motherboard. Remove the battery by gently pulling it up and off the motherboard. Replace it with the same model battery (available at any computer store or online). Reassemble the computer the same way you took it apart. Acer TravelMate 6592G Keyboard Replacement Guide http://tomkaminski.com/acer-travelmate-6592g-keyboard-replacement-guide
http://www.insidemylaptop.com/taking-apart-acer-aspire-5100-laptop/
Apr 01, 2013 | Acer Aspire One Netbook 8.9" Notebook
Where is the location of the Cmos battery for my
You really need a service manual to try & locate the CMOS battery. With laptops the CMOS battery can be different on each model. These are often located on the motherboard below the keyboard, but a service manual should help you.
Nov 01, 2009 | Acer TravelMate 240 Notebook
How do I replace a dead cmos on acer 4520LCi travelmate laptop? The laptop no longer keeps track of system time when shut off completely. Can you tell me the exact location of the cmos so I can be able to...
what you replace is not the CMOS, but the CMOS battery.
On an ACER from those years the CMOS battery looks like a coin, or a coin wrapped in plastic and connected to the motherboard.
On most models from same series the battery is located on the lower side of the motherboard, like on picture below:
On some model the battery may be located underneath the keyboard.
Here disassembly instructions for a similar model.
Sep 11, 2009 | Acer TravelMate 2300 Notebook
Where can i find CMOS battery of my laptop ACER travelmate
You will have to turn it upside down and start removing compartments untill you find it. (As you did not give me the model of the computer I can't tell you exactly where it is)
The CMOS battery is located on the motherboard and it looks like a large watch battery.
Details on changing it is here: http://www.smartcomputing.com/editorial/article.asp?article=articles/2004/w1510/32w10/32w10.asp&articleid=24031
Have a great Day!
Jan 28, 2009 | Acer TravelMate 529ATX Notebook
Start up no response on screen
OPEN THE CASE A REMOVE THE CMOS BATTERY FOR 3-5 MINUTES THAT SHOULD RESET THE CMOS TO DEFAULT SETTINGS. OR GO INTO THE BIOS AND SET TO DEFAULT SET UP.OR DEFAULT SETTING AND REBOOT.YOU MAY ALSO HAVE A CMOS RESET JUMPER.CHECK MANUAL FOR MOTHERBOARD.AND FOLLOW THOSE DIRECTIONS.RICHARDM69
Nov 30, 2008 | Acer Aspire M1640 Refurbished Intel...
Cmos battery
Its easy you have to take out the cmos battery. Its usually below the keyboard of the notebook. Before this you are requested to refer the manual.
Mar 29, 2008 | Acer TravelMate 529ATX Notebook
Acer Aspire 5100-5840 USB Problems
Is your laptop still under warranty? I would go to the manufacturer first if it is.
If not:
the system clock is run by the CMOS battery. When low will cause a host of problems. Change it and let me know if this fixes your problem.
Dec 27, 2007 | Acer Aspire 5100 Notebook
Acer TravelMate 5720-6635 Notebook Logo
134 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
