Question about Sharp Audio Players & Recorders
Sharp cd-bk100w mini component system. was playing well, but stopped abruptly, and is now showing ERR0306
  • 4234 Answers
SOURCE: Sharp BA2100 3 CD mini component system - NO DISC
This is a relatively common problem when the optics get dirty. If you can reach the lens, try cleaning it using a cotton swab and alcohol. Don't bother with the "cleaning discs" available as all they can do is bruch off the dust. These lenses sometimes get a smoke or dirt film on them that the brushes can not celan.
Keep us posted.
Dan
Posted on Sep 17, 2008
SOURCE: display says protect
check your low voltage fuses, the protect light up when a overload comes....
Posted on Jan 30, 2009
  • 4234 Answers
SOURCE: How can I get the cd changer to stop changing non stop?
Something is out of timing. When powered up, the unit trys to get to a known state and will continue until it reaches that state. If the timing of the gears has been changed, this may not occur.
I'll try to see if I can create a set of instructions to re-time this.
Dan
Posted on Mar 11, 2009
  • 30 Answers
SOURCE: Need User Guide/Owners Manual For:
Hi providing you 2 websites where you can download the required information.
www.fieldcommunicator.com/downloads/375UserManual.pdf
www.p4c.philips.com/files/3/37pfl9603d_10/37pfl9603d_10_dfu_eng.pdf
Posted on Apr 09, 2009
SOURCE: Sharp CD-BA200 MIni Component Stero System
I've been messing with mine because it says no disc and I messed it up so it started saying this error. Unscrew the screws around the top (4 screws) and slide off the top cover. The small black rectangular box that sits over the eye/laser can be removed carefully by compressing the clips. Then the cd tray can be removed. I figured out this error was coming up because I had the tray out of alignment... so try to see if that's the problem with yours... also the eye itself slides (the entire mechanism it's on... slides away from and towards the place where the cd sits to be lifted and read) and it should be as close as possible to the area that lifts the cd. Sorry if this isn't making sense... trying to explain in the best way possible. The tray being out of alignment causes that error though.
Posted on Oct 27, 2009
I CANNOT GET THE CD DRAWERS TO OPEN ON MY SHARP MINI COMPONENT SYSTEM MODEL CD-DK890N
Chances are the loading mechanism is out of alignment. Very hard to realign this mech. even the manufacturer just replaces the entire mechanism when repairing.
Dec 08, 2013 | Audio Players & Recorders
I need a FM antenna X 1 (92LFANT1535A) for Sharp Mini Component System model CD-DK890N
Try these web sites:
http://search.aol.com/aol/search?&s_qt=sb&q=Sharp+mini+cd-dk890n+parts&tb_oid=07-01-2013&s_it=amonetizetest1-ie&tb_mrud=07-01-2013&tb_uuid=20130107163427450
http://www.partstore.com/Model/Sharp/Sharp/CDDK890N.aspx
Jan 20, 2013 | Audio Players & Recorders
I have a Sharp CD-DK891N Mini System. The 5 tray CD system will not play any CD's, there isn't anything stuck in any of the trays. How do I get the CD 's to play??? Any help would be appre
Get a CD cleaning kit and follow instructions, if no change the laser pickup assembly will need to be replaced, far cheaper to buy a new player.
May 12, 2012 | Sharp Audio Players & Recorders
I have sharp mini component system cd-sw300h and can not switch the machine on . The timer light is flashing but I cannot seem to get the unit to turn on at all.
My sharp mini component CD es777 won't work. it only flashes a red light where timer is. I tried the remote timer but still no luck. Help
Apr 29, 2011 | Sharp Shelf System Shelf System
My Sharp Multi-System Mini component system shelf... is stuck on the ipod setting, if I push audio-in, it goes to audio-in for a second and then switches back, the same thing happens when I try and switch...
Have the same problem. Called Sharp and they told me to do the following:
At front of unit push open/close and stop button at same time. While these are held down press CD button All clear should appear on screen.
Have not tried yet, since I am at work
Feb 03, 2010 | Sharp Multi-System Mini Component System...
Sharp CD-DP2400 3-disc mini component system stops playing in first track
the rails on the laser slead need cleaned..the grease gets hard/dirty and stops it from moving skip it to track 16 to move the dirt off the track..
Oct 26, 2008 | Audio Players & Recorders
54 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
