Question about Minolta EP4000/5000 CS/PRO Copier
Is there any way to add printing to this machine, and how to repair auto dupex
  • Minolta Master
  • 1,297 Answers
Please describe your problem.This copier not functionally to add PC,he is not on printer,is simply on copier machine analogique.
Posted on May 08, 2010
How can I get it to print?
Try unplugging from your computer, uninstall printer on your computer and reinstall.
Add or remove printer
Jan 09, 2016 | Canon PIXMA MP830 All-In-One InkJet...
Hi i have canon ir 2018 machine with duplex but it dosent giving back to back print
Dupex is an optional item for this unit, fixed on right door and 1 wire harness to be attached with main unit which usually forget please check.
Jan 12, 2013 | Canon imageRUNNER 210S Copier
Hp[ officejet 6500. 1: how do i print dupex ??
I'm afraid your printer is not capable of duplexing automatically, so its a case of reinserting already printed sides the other way up.
secondly the font size is set by the software you print from.
Mar 19, 2011 | HP Officejet 6500 Wireless All-in-One...
Add yellow ink appears cannot print.
The printer will not print if it thinks it may completely run out of ink. Running this machine dry could damage the $1500 print head, never mind the cost of labor to do the job. I have the multi-function version of that machine and our print head was bad out of the box. Even if you are only printing black, the machine will purge ink slowly through the print head of each color to avoid a clog and other costly repair.
Your solution is to add yellow ink and always use original Xerox ink, compatible ink can damage the print head as well and Xerox will not repair it. You will have to go after the vendor that sold it to you, which is very difficult.
Feb 02, 2010 | Xerox Phaser 8560DN Printer
Canon irc5185 new machine, print not good
run auto gradation adust in add. func. on heavy paper then check each colour ! at a time it iis possible ! of the new drums has failed. good luck
Nov 20, 2009 | Canon Office Equipment & Supplies
Incoming fax goes to memory and display panel Auto Print Off
If you press the on /off button once the machine will switch to auto print on,if you keep the on/off button in the machine will switch on or off.
Apr 08, 2009 | Canon FAX-JX200
Laserjet 4250 not dupexing
Had this same issue on my 4250dtn. The solution in my case was that both paper trays were set to "custom". This is a small lever on the right side toward the back of the paper tray. Even HP was stumped on this. Hope this helps.
Apr 01, 2008 | HP LaserJet 4250n Printer
2nd side crooked
I would have to say that there must be a same piece of paper touching the paper as it is being feed through the duplex ass'y. The best thing to do is to see if the copy gets tilted toward the front or rear of the copy/ copier. You will be able to find where the obstruction is in the dupex path.
Feb 23, 2008 | Canon D320 imageCLASS Digital Copier
Confirmation pages
press function
press dataregistration
press set
use scroller up and down to select the function that you want to do, there's a lot of function, like user setting, report setting vvvvv.
select user settings, then scroll up or down
select activitiy report, then set it auto print off
will help you, play around with it.
Oct 22, 2007 | Canon FAXPHONE L80 Laser
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
