Question about Bosch Nexxt 300 Series WFMC2201UC
Im getting an error e 13 message and the door will not unlock
    Problem Solver:
  • 5 Answers
Error code = bad pump? or just a clogged screen /kinked drain hose?
E:13Er:13 test #P:15Drain pump time exceeded,Faulty drain pump, wire harness, hose
Posted on Apr 27, 2010
  • 5050fix Apr 27, 2010
    look for my other bosch fix post think it was a next 500 but is where the screen filter is on the 300 also
Whirlpool AWZ 612 E13 Error code on hot wash
This happens to me as well when I use drying. After using the machine, when I want to reuse it I get this error "E13". Somehow I manage to make the machine pass the error...
Though I am able to open the door. Here is how I do it (be careful if there is a lot of water in the machine):
- turn off the machine by switching the program knob to "Off";
- wait a few seconds (5 to 10 seconds or so);
- turn the program knob to any program (e.g. Cotton 30);
- the machine will do several clicking sound;
- one of the clicking sound is actually the door unlocking, at that moment open the door;
- turn the knob to "Off".
Hope that helps.
Oct 30, 2012 | Washing Machines
Im getting a "LO" error
The LO error code means the LID OPEN
Here is what the techicians service manual say to check
LO Door failed to unlock Door lock monitor switch does not indicate to the machine control board that the solenoid in the door lock mechanism retracted and unlock the door. 1.Check for debris inside inside the door lock mechanism, which may be jamming the lock solenoid. 2.check wire connections in harness leading from machine control board to door lock mechanism.
3.Check the door lock monitor switch for welded contacts.
4.Replace responsible component.
Jul 30, 2011 | Maytag Neptune MAH5500B Front Load Washer
Error code 13 on my 5oo plus series washer, it will not coplete the load or unlock the door, im afraid the clothes are going to start smelling
On the small round disk at the bottom right...insert a small round pointed object into the hole and push gently, while do this rotate the disk clockwise. This will allow you to remove the disk. Look inside and there will be a slender plastic rod next to the drain clean out. Pull down gently to manually unlock the washer door. Unfortunately that will unlock the door but probably not fix what caused the issue in the first place.
Jan 18, 2010 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Hello, I get a E:13 error code and the door will not unlock. Any ideas?
On the bottom right there is a round door with a small hole. Insert a small rod and push slightly, you will feel a spring action, then turn to the side and the door will come out. Inside you will see a large twist handle ( this is the clean out for the water pump) THERE WILL BE WATER THAT COMES OUT, BECAUSE YOUR FILTER IS PROBABLY CLOGGED, THAT IS THE E-13 CODE) Remove the door, clean the filter, clean up the mess and this will probably fix the problem.
Oct 10, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Unlocked Treo 650 wont send text messages
I have the same problem using an unlocked Treo 650 on O2(UK).
One thing you need to do is make sure that the Message Centre Number is set correctly for the SIM network you are using. Get the MCN from the internet, then on the Treo Messaging > Menu > Options > Preferences > Network > Manual > Edit to check/set the MCN.
Oct 01, 2009 | Palm Treo 650 Smartphone
DSi-ttds-error has occured message
Hay ive had the same thing 2 except my brother did sytem update nd the card dont work (i hav ttds 2) im 13 and im upset 2
Oct 01, 2009 | Nintendo DS Lite Console
Washer will not drain or stat new cycle, no error message
What is the make, mode # of your washer? Do you have dial or, a keyboardl controls
Apr 26, 2009 | Whirlpool Washing Machines
HI, this is a defective CCU(Central Control Unit). you must have it replaced asap. this will correct the error.
Apr 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Dl error message on front loader
This is the info from the error code for your washer DL/F
Door Unlock Error
A Door Unlock Error occurs if the door cannot be unlocked. It will try to unlock the
door 6 times before displaying the error.
Potential Causes
• Door Lock Mechanism broken.
• Check Door Lock/Switch Assembly for foreign objects
• Check Wire Harness connections to the Door Lock/Switch Assembly and Central
Control Unit (CCU)
• Door Lock/Switch Assembly Failure
Note: The Door Lock/Switch Assembly can be manually unlocked. See Section
Seven, TECH TIPS
Mar 05, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Bosch Nexxt 300 Series WFMC2201UC Logo
1,035 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
