Question about Intermatic Inc. ST01C Digital In-Wall Timer
Instructions are unreadable for the self-adj wall timer 0192773
I need readable instructions for the self-adjusting wall timer recently purchased...
Open following link:
0192773 is single-pole switch only
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
Posted on Oct 04, 2011
Im trying to install a Utilitech 0192773 self adjusting wall timer. It has four wires, black(hot), red(hot), white(neutral) and green(ground). I have a standard three light switch plate(outside light,entry...
Thank you for clear description of wiring, switches, and for including timer model number.
1) Open following link for ez programming and wiring for Utilitec.
2) Your single-pole switch has 2 wires.
0192773 replaces single-pole switch only.
Black wire that connects each of the switches is Hot wire: connect this wire to timer Black wire.
Other black wire that connects to switch goes to load: connect this wire to timer red wire.
Timer white wire connects to white wires that are covered with wire nut.
Timer green connects to bare ground wire.
3) How to connect stranded wire and solid wire
http://waterheatertimer.org/How-to-twist-electric-wire.html#stranded
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 03, 2011 | Intermatic & Self-Adjusting Wall Switch...
INSTRUCTIONS FOR UTILITECH SELF-ADJUSTING WALL TIMER MAKE NO SENSE! iNSTALLED, BUT HAVE TO TURN PORCH LIGHT ON MANUALLY EACH DAY; ALSO COMES ON SOMETIMES IN THE MIDDLE OF THE NIGHT! HELP!
1) Sounds like you have timer wired correctly.
The wiring is confusing for many people, so it's apparent you're a quality electrician.
2) There are no repairs for defective timer, but timer can be reset using reset button.
Reset will clear program conflicts and overlaps that cause timer not to operate as expected.
3) Model number of Utilitec timer is not given, so expert has to guess which fork in the road you want to choose.
4) If you have 0192773 timer and want do-it-yourself solution, open following link for larger print and photo illustrations that make programming easier.
5) If you have 0141224 timer, then open following link for larger print instructions.
http://waterheatertimer.org/Program-wire-Utilitec-LW60418.html
6) At any point, you can add a comment and ask very specific question about any part of the instructions for either in-wall Utilitec timer, or any Utilitec timer, or ask a question about almost any 60Hz timer on the market today.
That comment sends an e-mail, and then I will respond.
I have tested both Utilitec in-wall timers.
Aug 31, 2011 | Hardware & Accessories
I have a utilitec self adjusting wall timer #0192773 that stopped functioning. The led display is blank. I tried to re-set per the instructions, but nothing. I've confirmed power to the timer. Does this...
If resetting timer does not restore functionality, and timer has power, and you checked that LIGHT BULB is good, then timer has gone bad.
To double-check circuit, replace timer with ordinary on-off switch and see if it works.
Warranty: buy new 0192773 timer at Lowes, and return broken one inside new package.
Apr 21, 2011 | Intermatic Inc. ST01C Digital In-Wall...
I have a Utilitech Self-Adjusting Wall Timer- #0192773 that will not hold it's program. It worked fine and then I had a power outage after replacing the standard bulbs with CFL bulbs. Now I set the...
Manual for this timer says to reset timer when encountering a problem.
Just press reset button for 3-4 seconds, and then re-program timer using instructions on following page.
I have tested this timer, and it is a good timer with typically difficult programming because of Astro option, but all these in-wall timers have 1 year limited warranty.
You can buy another one at Lowes, and then return defective one in new package if necessary.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
Feb 25, 2011 | Intermatic Inc. ST01C Digital In-Wall...
Purchased utilitech 0192773 self adjusting wall timer. planning on installing in garage wall switch box for outside lamp posts, 3 total. the wiring in switch box consists of grounds tied together, 2 whites...
you got the wires you need. add switch's white to the white bundle in the back; green to grounds, red to the black going to the light; black to the other black. worked for me!
Jan 29, 2011 | Computers & Internet
Utilitech Self-Adjusting Wall Timer- #0192773. Unable to program timer. The instructions are so small it is hard to read them
Utilitec 0192773 is also listed as LW60419
1) Has optional daylight savings plus dawn to dusk programming
2) Electrical wiring must be connected in order to program timer. This is because timer is powered by electric circuit (instead of battery).
3) Program choices:
-Individual days MO TU WE etc
-All 7 days of week
-Weekdays
-Weekends
4) Large manual + wiring tips:images load slow with dial-up
5) Enlarged manual
-Click on image to enlarge
-For more size, hold down Ctrl key on keyboard and use scroll-wheel on mouse
Sep 30, 2010 | Intermatic Inc. ST01C Digital In-Wall...
I can't read the instructions that came with the utilitech #0192773 timer. The print is too small. Please e-mail me readable instructions for programing.
I couldn't find the instructions online, however, you can go to just about any Commercial copying place and get an enlargement of the instructions that came with the device for a nominal fee.
Sep 12, 2010 | Intermatic Inc. ST01C Digital In-Wall...
I do not need an expert, the instruction sheet got wet, so I cannot read it for utiltech self adj. wall timer.
You are asking for a Utilitec manual but don't specify which manual that fixya expert should provide free of charge, which is why you don't need an expert?
Open following link for several different Utilitec timer manuals.
Jun 30, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Intermatic Inc. ST01C Digital In-Wall Timer Logo
455 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Steve
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
