Question about Microwave Ovens
MAYTAG GEMNI ELECTRIC RANGE when either oven is turned on, i get an F1 code and an 800 number to call. suspect trouble is on motherboard.
    Brigadier General:
  • 3,513 Answers
The F1 code means Defective touch pad or clock (ERC). Replace touch pad or clock (ERC). Touch pad is a more common problem.
Please check the bellow links to learn more aboutthe fault code..
http://appliancejunk.com/forums/index.php?page=133
Let us know if you want something else please accept the solution.
Thank You for contacting fixya.com
Posted on Apr 26, 2010
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
MY OVEN DOOR REMAINS LOCKED AFTER CLEANING. I GET A F1 DISPLAYED. I LEFT IT UNPLUGGED ALL NIGHT AND IT STILL SAYS THE SAME THING AND IS LOCKED. IS THERE ANYTHING I CAN DO?
I could be more specific with a model number from the range.
The F-1 code on most ranges is a bad electronic control board. The oven lock is controlled through this board.
If you replace the board you should be able to open the oven.
You may also have a blown thermal fuse behind the rear panel on the oven as a result of self-cleaning.
Self cleaning is a nice feature but is not recommended by appliance repair technicians.
Sep 04, 2011 | Maytag Microwave Ovens
Hi, I have a Maytag stove and unfortunately have lost my manual. In the last couple of days there has been an alarm going off with F1 appearing on the display panel. Once at 5:30 am and at 1:00 am. Could...
With Maytag Ovens the F1 error means Defective touch pad or clock (ERC). This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present. (If you don't feel comfortable doing this yourself you need to arrange a repair technician to look at it for you)
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Regards, Kat (please leave feedback, thanks)
Aug 19, 2011 | Maytag Microwave Ovens
Maytag model mmv4203dw00 is showing a e5 and is dead in the water
Actually it can't be "dead" if a fault code is on the display.
There should be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
It should tell you what the E5 code means, but I would suspect a defective temperature sensor or control board.
At
our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Jun 06, 2011 | Maytag MMV4205 Microwave Oven
Maytag microwawe model mmv4203dw00 the control board is showing a trouble code e5 unit wont go on i try unpluging from the outlet to reset it but still it wont work
At
Jun 06, 2011 | Maytag Appliances Over-the-Range Microwave...
F1 range code on display
F1 is the oven cavity thermal sensor on most models.You could try to unplug the microwave for few minutes, say 15 minutes and then turn it ON. If problem persists, you need to replace the sensor.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jun 03, 2011 | Microwave Ovens
My Frigidaire electric range has the f-3 message error what does that mean
This indicates a failure in the temperature probe. This is easy to check and replace. Here is a link that will walk you thru checking an oven Temperature Sensor .
Fault Code F1 F3 F9 Dr
Dec 04, 2010 | Frigidaire Microwave Ovens
GE Profile Microwave Oven with an F1 error code
F 11 code. it is a touch pad error.
If you just cleaned the control panel it may have water in the panel causing a key to stick.
If after a day or 2 it hasn't dried out - then you will need to replace the touch pad.
Visit www.searspartsdirect.com and enter in your full model number for a parts breakdown and schematics.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 11, 2010 | GE Profile Spacemaker Over-the-Range...
66993 pizza oven microwave oven combo pizza oven not heating error code f1 microwave part works
Hello, please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
Jul 20, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
Microwave Ovens Logo
23 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
