Question about Maytag Amana 30 in. Electric Double Wall Oven with Temp-Assure Cooking System
Model #A027DGW1, Gas or Electric? where can I
Model #A027DGW1, Gas or Electric? where can I get a manual?
Further to my previous question it is not a microwave oven it is an electric oven with a gas top
SADLY Lindsay when you do not state the MAKE there really is not much help we can provide ..try searching thru Google by MAKE/MODEL and see if you find a manual
Jun 11, 2016 | Ovens
Kenmore Oven- The oven doesnt heat or light at all. If I sent it to 350 degrees; should i still smell gas?
I beleive this model has an electric igniter, You may have to change this they sometimes just wear out, or it's just simply your pilot light is out and you need to relight it, hope this helps.
Sep 19, 2012 | Kenmore Ovens
Need a manual
Well-- let's see if we can help--
Can you give us the Make-- and model?
And are the ovens GAS or Electric? (All the same model?)
Now-- tell us what kind of problems you are having with these ovens?
Like temperature swings, or won't light, or-- WHat?
Mack B
Jan 11, 2011 | Ovens
The oven doesnt work. Broil does nothing else
You did not give a model number or whether yours is gas or electric....
here are tips that I wrote for both gas and electric...
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Nov 24, 2010 | GE Ovens
Elderly tenant unable to use oven as they don't know how to turn it on. elements work ok as new so what is the trick. manual not avl from owner of rental house
You have not mentioned the make model of the oven, whether it is gas or electric.
Please check for gas line, gas valve, gas regulator to open and ignite.
If electric make sure there is power at the outlet, if the circuit has tripped, check mains.
Please consult your landlord before you pull out any units as he could be the best help.
Nov 16, 2010 | Ovens
Oven will not light. it is a frigidaire model #
When the bake igniter becomes weak or burns out, your oven will not bake. The bake igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
If the bake igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve will not let the gas out into the oven burner. A weak igniter must be replaced.
A faulty igniter is probably the most common cause, however there are others:
  1. Defective thermostat
  2. Defective selector switch
  3. Defective gas safety valve
  4. Defective gas valve coils
Dec 17, 2009 | Frigidaire Ovens
Oven-part of Franke Stove not working.
I have a Franke gas stove top and under one burner knob the spring is broken. Model #AD 72 M WQ
Jul 10, 2009 | Ovens
I have a classique gas/electric oven and need to set the clock because of power cut. Oven was in house when purchased so have no manual. Think this is model 2320 SS although not certain as plate with info...
Cassique gas top & electric oven. Oven does not have usual temperatures but has 1 to about 20. What do these numbers relate to in terms of temperature
Mar 05, 2009 | Ovens
Maytag Amana 30 in. Electric Double Wall Oven with Temp-Assure Cooking System Logo
126 people viewed this question
Top Maytag Ovens Experts
Dan Webster
Dan Webster
Mack Baxter
ashburton
Are you a Maytag Oven Expert? Answer questions, earn points and help others
