Question about Biostar M6TSU Motherboard
I need a replacement fan the Tforce 550 SE Mother board
It is the small fan next to the grafix card. Not the CPU fan.
  • ary_bragha
    ary_bragha May 11, 2010
    please write your question's more detail .....
  • 54 Answers
Being so, you need a small standard Fan, ask for it in any coputer parts store.
Posted on Apr 26, 2010
I have desktop computer having biostar mother board model M6TWG having intel cpu Pentium III 550 Mhz.
to use win 7 2gb of ram is reccomended, in any case the cpu will be too slow. try a linux light distro instead. bye
Apr 08, 2014 | Computers & Internet
My hp a 1410n desktop powers up but shuts down after five seconds
#1 on the list for this is shut down from over heat due to CPU fan not running or CPU overheat. Check to see if your CPU fan is turning on when your system is powering up. If its not.. thats your problem (get a new fan)... Even if it is it could mean the fan is not properly contacting the CPU with thermal paste. If this is the first time you\'ve powered the system up, your next step is to go out and get some thermal paste and put it under the CPU fan, if you\'ve been running the system and this problem just cropped up.. skip the thermal paste, its already there. #2 Next possibility is BIOs power settings are incompatible with your hardware. For example the frequency on the CPU is set higher then it can operate and its over heating. Some systems will automatically shut down and restart with default settings others you have to get into and set to default. can you get into BIOS? Can you reset your BIOS settings to defaults? Check your mother board manual. #3 A compenent is shorting out your system and needs to be replaced. Is the system posting prior to shutdown (beeping once on start up?) If its beeping more then once that means something else and you should read your manual. If its not beeping then its a short somewhere and you can bet you have a bad part in the system. To identify which part it is you can either disconnect things (RAM, Drives, vid card, PCI cards,ect) one at a time, attempting to start the system after each one or you can take everything but the bare bones out and try to start it. I usually take all the RAM out but one stick and start by testing them. Your RAM is the most likely place for a problem in this situation. #4 If you\'ve striped it down and it still can\'t get a boot (with no post beep). You need to replace the mother board.
Jan 18, 2014 | Computers & Internet
My mother board is M2N MX SE AND THE PROCESSOR IS AMD ATHLON 64 X2 4200+. I HAVE GOT TWO DESKTOP WITH SAME CONFIGURATION. RECENTLY BOTH THE MACHINES HAS STOPPED WORKING. THE PROBLEM S THAT THEY WON'T...
you may try and make sure that the cpu fan is functional and tightly attached to the cpu's surface
if the VGA card is not built-in, also try to remove it and clean its slot
good luck
May 16, 2011 | ASUS M2N-MX SE Motherboard
Requires a new mothe4rboard and CPU,How to I identify the parts needed
Easy the mother board is the big computer board that all the wires are connected to it,The CPU is the chip underneath the small fan on that board. if you go to microcenter.com you can see by looking in the BYO section(build your own) ,you will also get a good look at what they look like and what they cost,speeds ,sockets and so on.
Just a question who told you needed a board and CPU and why?
Apr 05, 2011 | Computers & Internet
I HAVE ASUS P5KPL-AM IN MOTHER BOARD MY SYSTEM IS ON BUT I DONT FIND DISPLAY IN MONITOR. MY RAM IS OK, MY PROCESSOR IS OK BUT I DONT FIND DISPLAY ON MY MONITOR .
if you have your monitor light flashing or the cpu fan is working when you on the system try this,
you just need to load the BIOS to its defaults, to do this you need to open the CPU case, unscrew the two screws on the left side of your cabinet, on the motherboard you can see a small button sized battery, remove it and after one minute replace it into its position.
close the cabinet and start the computer it'll work fine....
Sep 06, 2010 | ASUS P5KPL-AM SE Motherboard
Need a video card but cannot locate it
no one is able to understand your question
do u want a grafix card or what please specify
Jan 28, 2010 | AMD Athlon-64 3800 CPU and Mother Board...
The cpu not on
You wil have to give me more details please
Oct 17, 2008 | ASUS P4P800 SE (890552603657) Motherboard
Display(VGA) output
does your system have on board grafix? or do you have a grafix card? if its on board grafix try borowing a grafix card off somebody to try in your system or try your grafix card in another system
Aug 03, 2008 | Dell OptiPlex GX110 PC Desktop
Dell XPS 400 Card Cage Fan Failure
dell xps 400 pentium d once i turn it on, it beeps and says "card cage fan failure" everytime i press f-1 to continue it shuts off and boot up again it does it everytime how can i fix this CARD CAGE FAN FAILURE??
Apr 22, 2008 | Dell XPS 200 PC Desktop
Biostar M6TSU Motherboard Logo
Top Biostar Computers & Internet Experts
Jayburt
David
David
Jerry Umali
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
