Question about Alpine MRP-M350 Car Audio Amplifier
Can I attacch two speakers and a sub to a alpine MRPM352
  • 175 Answers
Not really it will under power the sub and probably damage the amp it will work but the current draw from sub will damage the amp, one or the other i sugest
Posted on Apr 27, 2010
What amp would be better to use with what speakers/sub? I have a KAC-7202 kenwood 920W maximum power (150wX2 RMS, 4ohms) (230wX2 RMS 2ohms) and then the other amp I have is a Alpine MRP-M500 mono power...
I'm using that Alpine right now for 2-12" subs and I have compared it to 6 or 7 other amps this month and most were 4 channel 150Watt/Channel Bridged to 300Watts x 2 and found the Alpine to be superior in both sound quality and loudness. The Alpine has also not turned off even with full volume for hours at a time, Very solid amp I was very surprised due to it's size!
Apr 04, 2013 | Kenwood Car Audio & Video
What is the best amp for one 15" alpine type r?
sub spec 250watts per coil you should be just fine I have 2 typr 15s on orion hcca 2500 1 and it kicks a$$ thats 1000 watts over the rated limits of the subs only shut the amp down once these subs can take a lot more power than they say just use your common sence with the volume and gain levels
Jan 31, 2012 | Alpine Type-R SWR-1242D Car Subwoofer
I have the Alpine MRP-M1000 amp. I want to use 2 subs with this amp. Which Alpine subs would work best with this amp?
this amp is rated at 600w at 4 ohms and 1000w at 2 ohm so as long as you calculate your speakers to match the ohm specs of the amp you can hook up
parallel = pos to pos and neg to neg of the 2 speakres
2 - 8 ohm speakers in parallel = 4 omhs
2 - 4 ohm speakers in parallel = 2 ohms
series = pos to neg of the 2 speakers
2 - 1 ohm speakers in series = 2 ohms
2 - 2 ohm speakers in series = 4 ohms
Feb 22, 2011 | Alpine MRP-M1000 Car Audio Amplifier
Hello i just recently bought alpine speakers for my eclipse 2003
mostly because the subs in the back are probley using more amps than the ones in the front in the front should be used mostly for vocals and your bass in the trun so maybe trying to unhook the ones in the front from the sub and just leave then hooked up to the cd player where you can hear the vocals really good and leave your subs in the back hooked up to the amp
Jul 27, 2009 | Alpine SWS-1223D Car Speaker
Sub will drain all the sound off the front speakers
if you have both amps connected to the same power wire this will happen...run another power wire to the alpine and this should solve the problem.
Jul 25, 2009 | Rockford Fosgate Punch 301S Car Audio...
How can i wire 2 alpine type r subs series swr 1240
Hello asg_1024,
The wiring configurations are shown here in the "Wiring Wizard". Wiring 2 4ohm subs in series will result in an 8ohm load.
Hope this helps
Jun 08, 2009 | Alpine SWS-1240 Car Speaker
Subwoofer stopped working
Put another known working speaker in there to see if it works. If it does then the issue is with your speaker. If it also does not work your amp is to blame.
Sep 16, 2017 | Alpine SWR-1222D 12" Type-R Series...
Has my subwoofer been blown?
hook ithe sub up to a 9volt battery and see if the woofer moves... You will not dammage the suub testing it this way.
Mar 23, 2009 | Alpine Type-R SWR-1242D Car Subwoofer
Want to bridge my alpine 3555 amp to run my sub.
I'm assuming this atleast a 2 channel amplifier all you need to do is hook the negative side of the speaker wire coming from the sub to the negative channel one. and the positive to another positive on channel 2. Should indicate on your amplifier channel one and two. most amps provide a diagram right on the amplifier over top of the speaker inputs. let me know if this helps.
Mar 07, 2009 | Alpine Car Audio & Video
Alpine MRP-M350 Car Audio Amplifier Logo
103 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
