Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
My whirpool refrigerator model ET18GKXHT0 freezer seems to be defroasting into the refrigerator.Is there a way I can fix this ? There is water going in under the veg.drawer.
SOURCE: water in bottom of fridge
Thanks to all who spent money or shared their experience to have somebody do this repair, and I really mean it.
I have a Whirlpool TopLoad Fridge (not a side by side).
Things you'll need
30 minutes
Small socket for cardboard panel on lower back and panel inside freezer
Bicycle Pump
4 Towels
Hair Dryer
1. Take everything out of freezer
2. Turn dials off in fridge for both compartments
3. Pull fridge out so you can get behind it and unplug it
4. Be vigilant of ice maker line if installed
5. Pull cardboard panel off on back
On the left side you should see the back of the skinny drip pan and a small line. That line goes from the freezer and is most likely clogged.
6. Blow dry the back of the freezer enough so the ice is thawed at the bottom of the back panel.
7. Remove the two screws on the back panel. You may just be able to pull it toward you enough to get behind it. You'll see the coils and fan, and underneath these you may see some ice sheets and there should be a hole. That is the drain line that is clogged. I heated up some water and poured it over the drain to thaw the line. You may want to remove the crisper drawers and put some towels down there to catch the overflow. Once the ice is thawed enough at the drain. Go to the back of the fridge and place the end of the bicycle pump at the bottom of the drain hose. Apply pressure to get a good seal but keep pumping. You may have to go back and forth between pumping and thawing, but you'll know it is clear when you hear air going into the freezer and then the wonderful moment when water drips into the drip pan as advertised!
Keep those fridges less full so that the door stays sealed and keep the seal clean and also keep your doors from having too much stuff so the weight of the door doesn't pull away.
Okay, put it back together, turn everything on and be careful of your cord and lines when pushing the fridge back. Thank the Lord ours has wheels and man,was it cruddy underneath. Vacuum those coils underneath the fridge too for proper air circulation.
Blessings to you!
tay
Posted on Jan 11, 2009
Sea Breeze
  • 4655 Answers
SOURCE: water is dripping inside refrigerator
This ia a common problem that indicates the drain from freezer is clogged or blocked. I will send you to another link to help explain how to resolve this, Thanks, Sea Breeze
http://appliancejunk.com/forums/index.php?topic=22.0
Posted on Apr 27, 2009
SOURCE: Whirlpool Custom Series refrigerator leaks -Model ET18JKXSN05
It sounds like the line you found is for draining the water from the defrost cycle. It should drain the water from melting the ice into the pan at the bottom so it will evaporate. Sounds like its being clogged is the cause of the water in your fridge.
Posted on May 13, 2009
Sea Breeze
  • 4655 Answers
SOURCE: water collects in bottom of refrigerator
This is something you will be able to solve, the like below will take you to a detailed instructions and photos of what to do. Let me know if you need more help, Thanks Sea Breeze
Posted on May 23, 2009
SOURCE: WATER DRIPS DOWN FROM INSIDE TOP REFRIGERATOR BELOW FREEZER
Not an original solution - but a good one. Remove panels at the back of the freezer compartment to expose the heater unit or heater wire that defrosts the freezer coils and wrap a solid copper wire gently around the heater/ heater wire and place the loose end in the drain. This will conduct heat to the freezer drain and help keep it open. I did see a manufactured part in one of the appliance parts websites but it did not match my unit.
Posted on Jun 09, 2009
Whirpool Gold refrigerator model GR2SHTXKQ01 (water leaks from dispenser. This model has freezer on top, dispenser is inside refrigerator.
Water valves leak like a leaking faucet sometimes. They just will not close all the way allowing water to bypass the valve and either drip at dispenser or drip and make a mess in freezer. Your model takes a=> 2219592 Water Valve - Dual Outlet
Change the dual water control valve and I believe this will solve this problem, Thanks Sea Breeze
Jul 11, 2012 | Whirlpool Refrigerators
There is a puddle of water inside the refrigerator, beneath the vegetable bins.
How many items are in your freezer? I had this problem and there was too much in the freezer, not allowing the air to circulate properly in the freezer, thus resulting in freeze up in the top (freezer) and condensation below in refrigerator section. Additionally, I had the refrigerator setting too cold, which accelerated the problem. I had to thaw the drain hole in the freezer section, below the fan, to allow water to leave freezer during defrosting stage. Hope this helps?
Jan 03, 2010 | Kenmore 18.3 cu. ft. Top Freezer...
Water laeks into the refrigerator part of refrig from the freezer above. pan at bottom of refrig is dry. I think drain is blocked. how do i solve this for a whirpool model et18nkxjw00
you are probably right. the drain is located behind the back wall of the freezer section, under the evaporator coil. simplest fix is to remove the rear panel and unplug the fridge,prop the doors open and let it melt on its own, a hair dryer or hot water may speed up the process.
Jun 11, 2009 | Whirlpool GD2SHGX Refrigerator
Side by Side fridge stops cooling and the works again !
soiunds like the defrost timer is bad, Unless your highly mechanically inclined I would go ahead and call out the service repair company and tell them to be sure to bring allong a timer fo your unit. Hope this helps and good luck.
Jan 09, 2009 | Whirlpool ED2FHGX Side by Side...
WHIRPOOL ED2
Not enough model to get the wire diagram. It sounds like a diode is out in the water valve harness. If it is using the triple valve on that unit.
May 08, 2008 | Whirlpool ED2FHEXN Side by Side...
Whirpool refrigerator, freezer fine, refrigerator warm
my suggestion give it up for the dead
Feb 23, 2008 | Refrigerators
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
156 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
