Question about Dell Dimension 2400 PC Desktop
How much power will a typical Pentium 4 desktop computer consume at full load?
    Sergeant:
    Novelist:
  • 172 Answers
A typical Pentium 4 will need less than 500 W of Powe supply. Are you asking because you want to upgrade or add more peripherals to your comoputer?
Posted on Apr 26, 2010
My windows will not load
try to unplug your computer but keep it on till the battery runs out
if that does not work then you can try pressing the off button and holding
Nov 17, 2011 | Acer AZ5610U9072 Allinone PC 23' Touch...
When i start up my dimension 3100 dell desktop instead of a green light i get a flashing amber light. people say it is the power supply but the light wouldnt even come on if it was. can you please help me?
No, the light WOULD come on if it was a Power Supply problem.
1) If ALL of the LED lights on your computer were on at once, they would use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts.
3) A typical Processor uses from 51 to 125 Watts. Depends on what Processor it is.
Dell Dimension 3100 desktop computer?
An Intel Pentium 4.
Intel Pentium 4 model 640.
Can operate up to a frequency rate of 3.2GigaHertz. (3.2GHz)
Fits in a Socket 775 processor socket. (Also know as Socket T)
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_4_microprocessors#Prescott_2M_.2890.C2.A0nm.29
Can use up to 84 Watts.
You have enough power to light that LED light, but not enough power to turn the Processor on.
Dell Support > Dell Dimension 3100 > Service Manual > Advanced Troubleshooting > System Lights,
http://support.dell.com/support/edocs/systems/dim3100/en/sm/adtshoot.htm#wp1124612
"Power Light - Blinking yellow - A power supply or system board {Motherboard} failure has occurred"
Dell Dimension 3100 desktop computer Service Manual, (Free from Dell Support),
http://support.dell.com/support/edocs/systems/dim3100/en/sm/index.htm
Click on Removing and Installing Parts > Power Supply
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 20, 2011 | Dell Dimension 3100 PC Desktop
1 out 50 times I turn on my Dell Dimension E520 there is no signal to the monitor. I have tried to install a new PCI express card instead of using the integrated graphics but the result was the same e.i no...
The problem is the Power Supply. Weak voltage power rail.
You've taken the right steps with your diagnosis.
1) Start with the monitor cable. If removable use a known to be good monitor cable.
Checks okay, go onto the graphics 'engine' of the computer.
If the monitor cable is not removable, use another monitor, and cable for a test.
2) If you are presently using Integrated Graphics the next step in diagnosing is to install a graphics card.
See if the problem is the Integrated Graphics 'engine'.
[ Just to add:
Intel GM X3100 is the graphics 'engine'. It is integrated into the Northbridge chip of the motherboard chipset.
Intel G965 chipset is the motherboard chipset. The Intel ID number on the Northbridge chip is 82G965.
The Southbridge chip is an Intel ICH8, or ICH8R, or ICH8-DH,
http://en.wikipedia.org/wiki/List_of_intel_chipsets#Core_2_Chipsets
{Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Intergrated_Circuit }
The Northbridge chip handles the Processor, Ram Memory, and HIGH-speed graphics.
AGP and PCI Express are High-speed graphics.
A graphics card in a PCI slot is not High-speed graphics.
The Southbridge chip handles the slower capabilities of a computer.
PCI and Integrated Graphics being two of the slower capabilities.
SATA, IDE, USB, and Ethernet, are also some of the slower capabilities of a computer,
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
CPU = Central Processing Unit. Another name used is Microprocessor, or Processor for short ]
3) Power Supply.
The Power Supply has enough power to light LED lights, and maybe spin fans, but Not enough power to turn the Processor on.
A) ALL the LED lights on at once will consume less than 1 Watt of power.
B) EACH fan consumes 2 to 3 Watts of power.
C) A typical Processor can consume (Maximum) 51 to 125 Watts of power.
The Dell Dimension E521 desktop computer's motherboard, has an LGA 775 processor socket.
(Processor has the socket holes, processor socket has the pins)
The Intel processors that can be used in this processor socket, can be an Intel Pentium 4, (Version that uses an LGA 775 processor socket), Intel Pentium D, or Intel Core2 Duo, AND Intel Core 2 Quad, with a maximum FSB of 1066MHz. (If the BIOS version will support Intel Core2 Quad processors)
{Front Side Bus of 1066Megahertz}
Wattage consumption can be as much as 105 Watts.
Do you have a KNOWN to be good, compatible Power Supply available, to use as a test unit?
{Compatible being that the Power Supply case fits, (ATX), has the right amount of power cables, and the correct power cables. (Needs to have a 24-pin ATX main power cable, and a 4-pin ATX +12 Volt power cable, for one)
Perhaps there is an unused computer that has a Power Supply you can borrow.
Maybe someone has upgraded to a better computer, and has an unused one with a compatible power supply for a test unit.
Nov 07, 2010 | Dell Dimension E520 PC Desktop
I have a acer 210t laptop with a 700 processor. can I upgrade to a faster processor and if so which one and how fast. Thank you.
Some laptops have "mobile" CPUs (physically smaller, and consuming less power) than the typical "desktop" CPUs.
So, if you know "how" to disassemble your computer, you may be able to remove the heat-sink & fans on top of the CPU, remove the CPU, and install a faster one.
However, if your current CPU is of the "Pentium III" series (which ranged from 500 Mhz to about 1400 Mhz), you may not be able to find a CPU that will be significantly faster than your current 1.26 Ghz CPU.
Instead, I would check the disk-drive -- if it is 4200 RPM or 5400 RPM, I would replace it with a 7200 RPM disk-drive, for better I/O speeds, and thus help your computer go "faster".
Also, I would add more RAM, again to make your computer go "faster".
Jun 09, 2010 | Acer Pentium III , 1.26 GHz Processor...
Error loading operating system
You will need to perform a repair install using a Windows CD. The current configuration on the hard drive was basically with an entirely different computer and thus, it does not know how to "talk" to the new hardware. The repair install should fix that and create a new Hardware Abstraction Layer (HAL) that will enable Windows to "talk" to the new hardware.
Mar 18, 2010 | Famous Brand Dell Optiplex GX280 Intel...
Video card upgrade
Yes you can put that new videocard. Your computer requirements meets videocard needs
Aug 05, 2009 | Dell OptiPlex GX270 PC Desktop
Can't connect to internet, modem not found
right click on m computer- properties- hardware-device manager- check and see if you have anything with a yellow ! or ? or if you have anything listed under Modems. sounds liek you need the drivers installed-
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=PLX_PNT_P4_GX260&os=WW1&osl=en&catid=&impid=
click the + by communications and download the 3 listed and install on your home pc
Jun 03, 2009 | Dell Optiplex GX260 Refurbished Intel...
Computer saying error loading operating system
You can configure your boot setup from your bios screen (for dell, either F11 or F12) then set up your optical drive as your 1st priority then, save settings. After that, you need to insert your windows XP cd in order for it to boot.
inform me of what happened after you have done this.
Mar 16, 2009 | Famous Brand Dell Optiplex GX280 Intel...
Really disappointed with dual core
You can buy a 3.02 pentium 4 processor and need not change any thing else. On the other hand try changing your hard disk with a one with smaller capacity such as 80 GB make it primary with the windows partition not exceeding 15 GB . Make this drive (80 GB )primary and other one secondary.Increase the virtual memory size of your system and for sure you wont need to buy any thing or be depressed anymore.
Oct 09, 2007 | Computers & Internet
Dell Dimension 2400 PC Desktop Logo
56 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
