Question about Maytag MED5600TQ Electric Dryer
My dryer is not drying well. I have to dry load
My dryer is not drying well. I have to dry load twice . We cleaned the vents out but that did not help. The dryer is only 2 years old.
  • 45 Answers
Replace the heating element.
Posted on Apr 28, 2010
Dryer takes twice as long to dry clothes.
Did you check the outside vent? Those get clogged as well.
Oct 27, 2012 | Whirlpool LER7646J Dryer
My dryer is producing heat but is not drying, i am drying the same size load i usually do on the same cycle. the lent is cleaned out, and the oustide vent is blowing hot air. why are my clothes not getting...
make sure that all the seals are ok, door,front and back drum seal, blower housing seal(inside dryer). also consider that depending on washer type if you overload or have a worn drive belt in washer it will take twice the time to dry. also make sure that the dryer drum tumble. open door,press door switch and start dryer to see if drum turn. lastly disconnect vent pipe behind dryer and dry a load. if it dry ok then you have a partial blockage. you can also have a weak heating element.
Feb 11, 2011 | Whirlpool WED5300S Electric Dryer
Dryer not drying in alloted time
there is a thermostat. it usually is located on the heating element housing
May 26, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
I have a kenmore elite HE2 dryer and it takes 2 or 3 times before the clothes are dry
know this may seem simple, but the lint filter needs to be cleaned after every load- some times twice- 'specially if you have cats, or heavy blankets, or lint prone fabrics. might try using vacuum cleaner to clean vent tube, or check external vent louvers. blocked or repressed airflow can really slow the drying process!
good luck!
Sep 08, 2009 | Dryers
My dryer whirlpool wed5300sq0 is getting hot but clothes arent dry
I suspect you have a blocked air vent. A blocked vent will definitely extend your drying time. You may even find yourself having to run a load twice to get it fully dried. One way to confirm this is to disconnect the vent hose from the back of your dryer and dry one load with the machine venting directly into your laundry room. If that load dries quickly then you know the problem is a blocked vent. Most vents get blocked by lint near their exit to the outside. There's usually a screen at this location to prevent small animals from crawling into your house. Often this screen gets clogged with lint. Most vents are designed to allow removal and cleaning of this screen from the outside.
Jul 07, 2009 | Whirlpool LER5636P Electric Dryer
Dryer doesnt dry clothes
Jun 06, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer not performing as it should
A blocked air vent will definitely extend your drying time. You may even find yourself having to run a load twice to get it fully dried. One way to confirm this is to disconnect the vent hose from the back of your dryer and dry one load with the machine venting directly into your laundry room. If that load dries quickly then you know the problem is a blocked vent. Most vents get blocked by lint near their exit to the outside. There's usually a screen at this location to prevent small animals from crawling into your house. Often this screen gets clogged with lint. Most vents are designed to allow removal and cleaning of this screen from the outside.
May 28, 2009 | Oregon Scientific Electric PTO Clutch for...
Dryer has to run twice to dry completely
clogged wall vent dryer vent,lent shut,clean them all out-mike
May 17, 2009 | Kenmore Elite HE4 Electric Dryer
Dryer isn't getting as hot as it should, clothes take twice as long to dry
clean out your wall vent,dryer hose and lint trap that should do it,what happens if you have a clogged vent the dryer keeps the wet hot air in loner and it take twice as long to dry-mike
Apr 20, 2009 | Dryers
Drying cycles taking way to long
ck vent to outside starting at back of dryer looks restricted or flatten vent hose then ckd vent from wall or floor to outside to verify problem is vent issue leave vent hose off and try a load may get a little warm and dusty but would be quick way to verify
Nov 25, 2008 | LG DLE2532W Electric Dryer
Maytag MED5600TQ Electric Dryer Logo
98 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
