Question about Zebra 170XiIIIPlus Thermal Label Printer
How do I put in an ip address in a 170xiIII plus
    Scholar:
  • 97 Answers
You should be able to get to the setting by pressing the SETUP key and then press NEXT until you see a setting called IP RESOLUTION. Use the black oval keys to select Dynamic,Permanent. The default password is 1234. Use the left black oval key to change number position and the right one to change the number value to set the password, then press NEXT. Press NEXT until you get to IP ADDRESS. Again, use the left black oval key to change number position and the right one to change the number value until you get the desired IP address. Press SETUP again and then press SAVE to make a permanent save.
This assumes that you have an internal ethernet card installed.
Hope that helps.
Posted on Apr 26, 2010
  • MZubaidi Aug 11, 2011
    what if i did not IP Resolution or IP Protocol in the LCD Panel !
    what should i do ?
  • Bob Miller Aug 14, 2011
    You must have an external ethernet print server then. It's either the Printserver II or the 10/100 ethernet print server. If your network hands out IP addresses by DHCP then your print server will have picked up an IP address. There should be a small test button on the server that you can push and this will print out a configuration label and show you the current IP address.
I am having trouble in printing.. I send the label to my Zebra 170XiIII plus and it out of specs... any help please??
Make sure you are using the correct driver 170xiIII plus, and make sure the dpi of the driver matches the print head resolution.203 or 300dpi.
Sep 09, 2011 | Zebra 170XiIIIPlus Thermal Label Printer
I have set up three devices to access thiswireless router and the way it was done before was by going throuugh my IP address and then adding the mac address. However now everytime I put my IP address it...
You may have used fixed IP addresses and then used MAC address filtering.
I recommend you let the Netgear issues IP address (DHCP) and use PA or WPA2 encryption plus MAC address filtering.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Jan 07, 2011 | NetGear WGR614 Wireless Router
My G Mimo Plus adapter won't pull and IP address. Any suggestions?
Is there a RESET button on the back of the router, if so power it up and press the RESET button until all the LEDs flash and reconfigure the router.
Try a different LAN cable, the other could be faulty
Install the latest LAN and wireless card drivers (this problem sometimes occurs when you install a new router).
Check the LAN and wireless cards are functioning correctly in Device Manager.
Open the DOS cmd window.
Test the NIC - loopback test address - ping 192.0.0.1
Ping the router's IP configuration address
Type ipconfig to see what IP address you get (if any)
Type inconfig /renew all - this will (should) get a new IP address from the router's DHCP
Let me know how things work out.
Dec 24, 2009 | Belkin Wireless-G Plus MIMO Router with...
The segement of the print server you select is different from your computer" on Vista,
Meaning that the IP Address of the print server is different from the computer's IP Address.
If you're computer has a static IP Address, you need to assign a static IP Address for your Print Server. To assign a static IP for the print server, you need to open the PSAdmin utility on your computer, locate the TCP/IP and click the plus (+) sign. Double-click the IP Address and you may change it from there.
Make sure that the IP Address of your computer, router and print server are in the same IP range. And make sure that you could ping the IP of the print server.
Then configure the printer port settings and you should be able to print.
Have a great day!
Jul 03, 2009 | IOGear GPSU21 Print Server
How to put an IP address on the CopyStar CS-1820 printer
putting an ip to 1820, just go to system menu, scroll down look for the network setting, you will find ip address, then fill it up.
Apr 21, 2009 | Copystar CS-1820 Copier
How do I secure my DLink-524 wireless
In securint your wireless security try accessing the configuration page of the router. go the the window where you created your wireless netowrk connection.
On that Wireless window choose WEP for security.
By defaut WEP Encryption is 64bit.
Under Key1 erase what's on the box and type in the password for your wirelss network. It should be exactly 10 characters, You could use 0 to 9 or A to F then click on Apply >next.
Try Accessing your wireless networ.
Nov 19, 2008 | D-Link AirPlus DI-524 Wireless Router
Setup
If that is the report that the laptop gives for an IP address, then you have to change the IP address settings.
Go into your network settings, and tell it to automatically aquire an address, and DNS.
Once you click OK, it should sense the DCHP from the router.
If the IP is already set to automatically aquire, then the router needs to be reset to factory defaults. That should put you back to the 192.168.2.xxx settings.
Jul 27, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Need an IP address?????
yes you can create the ip address of the network to make sure the security and to access the network functionally.
Jun 10, 2008 | Belkin Wireless G Plus MIMO (F5D9010)
Zebra 170XiIIIPlus Thermal Label Printer Logo
950 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
