Question about Hayward H Series
The AO code came up when I tried to start the heater today. What does that mean?
  • 64 Answers
Is the blower coming on? If not, i would start with the blower. You would need to check for voltage going into the blower. If you do, and blower is not coming on, then the blower is bad. IF the blower is on, then check the tubing coming to/from the blower for breaks or disconnected. Also, may be a bad blower vacuum switch. You can jump this after a call for heat has been established to see if it fires. You should only attempt this if the blower is working.
Posted on May 19, 2010
Can you run the pool heater with the AO code flashing
It will not run with AO code. That is telling you something is wrong/blocking the combustion fan from satisfying the safety switch. If it is a brand new heater this usually means the correct voltage has not been set in the heater = you would need to check what you have and then check setting. Doing this incorrectly could completely destroy all electronics in the heater.
If this is a heater startup for a new season the rubber tube from the combustion fan to the blower switch could be off or damage by rodent bites.
If this heater is older it could be a clogged heat exchanger which is a much bigger repair or problem for a homeowner.
manuals are available on haywardpool.com
Apr 20, 2014 | Hayward H Series Pool & Spa Heater 400k...
Ao smith tankless 310 has a code 10
No such thing as 10, there 3 digit numbers . Try reseting the machine
Dec 27, 2012 | A.O. Smith ATI-310-N ATI-310-N On Demand...
Ao error message in Hayward heaters
You didn't indicate exatctly which model you have. But on most the AO error code is :Blower vacuum switch
open error If the blower prover switch does not close after the blower starts the control will
stop the ignition trial go into lockout. The blower will continue to run. Automatic reset is immediate after the switch closes.Check to be sure combustion blower starts
If you don't have your manual you can download one for your exact model at : www.haywardnet.com
Jul 29, 2010 | Hayward H Series Pool & Spa Heater 400k...
I have an ao code and have replaced the vaccum switch and blower vaccum switch and still getting the ao code
Check the tubing going from the blower to the blower vacuum switch. If there are any cracks, missing, or cut, it will give the same code. Rodents like to chew on this tube. Also, if the blower is not coming on at all, then you will get the same code, and the problem is not with the switch, it is likely in the blower.
May 19, 2010 | Hayward H-series Electronic Gas Pool...
I had code AO displayed on my hayward H250IDE. I
Check your wiring again on all the safety devices - Water pressure switch and both Hi- limits in the header.
Feb 19, 2010 | Hayward H Series Pool & Spa Heater 400k...
My rheem water heater is flashing an error code of AO and 52. no hot water. what does this mean.
This means the solenoid to the modulating gas valve is sharing a fault. You will need to inspect the wiring to the solenoid to make sure it's ok. You can ohm out the solenoid to make sure it's not open. If it is, you will need to replace it.
Dec 23, 2009 | Rheem RTG-53PVN Indoor Natural Gas...
I am getting error code AO and the temperature
its most likely diplaying a code... is it code 21? that usually will follow ao. first make sure the door is securely on, if not make sure it contacts the switch
Nov 14, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
AO error
This error is produced when the blower prover switch does not close after the blower starts, the control will stop the ignition and go into lockout. Automatic reset is immediate after the blower prover switch closes.
If you keep having this problem, contact a reputable service company, especially if it's under warranty.
The link to the owners manual is below, it references fault codes, etc..
Hope this helps.
http://74.125.95.132/search?q=cache:4mAdY7bLfoQJ:www.haywardnet.com/products/Manuals/pdfs/Manual227.pdf+hayward+AO+error&cd=7&hl=en&ct=clnk&gl=us
Sep 16, 2009 | Hayward H Series Pool & Spa Heater 400k...
Hayward H Series Logo
172 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
