Question about RIM BlackBerry Curve 8520 Smartphone
My blackberry 8520 wont pair with Ford audio - RIM BlackBerry Curve 8520 Smartphone
  • 334 Answers
In order to pair a BlackBerry device with a Bluetooth device, the Bluetooth device must be in pairing mode. Most Bluetooth devices are not set to pairing mode by default. Therefore, refer to your Bluetooth device manual for instructions on how to set the device to pairing mode.
1. On the BlackBerry device, in the device options, click Bluetooth.
2. Click the trackwheel and click Add Device. The Select Device list appears and lists devices that are in range and available to be paired.
Note: Only devices that are in range and are in pairing mode will appear in the available device list.
3. Click the device to which you are pairing. The Enter passkey dialog appears.
4. Enter the passkey to authenticate the device. Most Bluetooth devices contain a hardcoded passkey. See your Bluetooth device manual for the passkey.
Best regards
Posted on Sep 01, 2010
  • fra_pala Dec 05, 2010
    useless solution
SOURCE:
How to pair with a blackberry
You directed this question at me, but I claim no expertise on this subject. FixYa suggests I inform you that I cannot help you. According to FixYa, this will put your question into the general pool for other experts to answer.
Dec 29, 2011 | RIM otion BlackBerry Curve 8520 Smartphone
Cannot pair blackberry 8520 with parrot ck3100
I could not pair the Blackberry Curve 8520 with the Parrot CK3100. After looking at the Parrot website, I saw that the Blackberry was actually supported, so it SHOULD work.
Then I found the solution: the Parrot had already too many other phones paired (4 or so), so it could not pair an additional one. After removing the other phones from the Parrot pairing list, the Blackberry paired without a problem. SOLVED!
Davy
Feb 22, 2011 | RIM BlackBerry Curve 8520 Smartphone
How to unlock a virgin mobile cell phone in canada with paying and calling
The best solution to unlock your Blackberry Curve 8520 is by using the Unlock code. Always go for a trusted vendor to purchase the unlock code. I have unlocked my Blackberry Curve 8520 from UnlockGenie.com. I think their codes wont fail.
Nov 02, 2010 | RIM BlackBerry Curve 8520 Smartphone
How to connect by bluethooth in Lexus 350 to blackberry 8520
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Aug 30, 2010 | RIM BlackBerry Curve 8520 Smartphone
How blackberry bluetooth connect with other phones
Go to manage connections and bluetooth options, press menu key and select add device. Standard code for pairing is 0000, but you may use any code you like, but give it to other person. Then you can pair. You will not be able to receive any pics/tones, and such until you go to media, press menu key, and select receive using bluetooth. Then it will work.
Jan 15, 2010 | RIM BlackBerry Curve 8520 Smartphone
How to get Jabra BT2050 in pairing mode? Problem - Rogers Tech Support asked me to ''wip'' my BlackBerry 8520, after that the bluetooth device stopped working and won't go into paring mdoe. Thanks.
Press and hold the center round on/off button for 10 seconds to put Jabra BT2050 into pairing mode. Type in pin "0000" when the BlackBerry 8520 detected the bluetooth headset, then the two should be paired. Hope this help.
Joseph
Jan 09, 2010 | Jabra BT2050 Bluetooth Headset
RIM BlackBerry Curve 8520 Smartphone Logo
1,042 people viewed this question
Top RIM Cell Phones Experts
RONALD CARTER JR
gggg
Ekse
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
