Question about General Electric WHDSR209DWW Top Load Washer
My washer fills with water and thats it, it wont agitate, or spin , but it does drain the water out. i know i have power in and out of my lid switch, i know the timer is sending power to the motor, i have never seen this before but the motor has a control board mounted at the to of it. do i have a bad motor possibly, the washer is about 2 yrs old.
  • 5 more comments
  • J-run Apr 26, 2010
    I have a G.E. top load washer that fills with water then stops, I have tested the lid switch i know it is good, the timer is sending power to the motor. it wont agitate or spin, but it drains jsut fine. the motor has a control board mounted to it, i was wondering if the board is bad or the motor,
    My G.E. top load washer will fill with water then stop, i know the lid switch is good, i have power to the motor. It wont spin or agitate, but it does drain the water out. there is a control board mounted on the motor could that possibly be bad.
    No I have not. I'm not home right now, Nothing against you I have never tried this type of approach to fixing my appliances, I wanted to see what the 3'rd reply would have said, so i can compare the 2 most comon answers. Like I said nothing against you its something new to me. I priced the motor out and it pretty pricey, I do appreciate your advice though
    How would I by pass that board, I'm comfortable with testing it, where do I start
    Is that board seperate from the motor or does it come with the motor
    I really appreciate the help I received from (emissionwiz) I know I annoyed him a little but he was very helpfull, thanks for the great service!!!
    My- inlaws have an bosch nexxt 500 series elec. dryer. its getting an error E:01 what could that be
    Top Expert:
  • General Elec... Master
  • 75,822 Answers
Most likely the motor control board is defective, u can test the motor by byp[assing the control board with clip leads from a 110 volt source, only do this with great caution and if you have allot of experience doing these types of electrical tests, if u are not comfortable with this Please call Sears or some other local appliance repair service..
Posted on Apr 26, 2010
  • 2 more comments
  • yadayada
    yadayada Apr 26, 2010
    U asked for assistance which u got, have u tried testing the motor?
  • yadayada
    the board mounted on the motor is the circuit board i am referring to. it is called the motor control board
  • yadayada
    I gave u an approch, u shot me down before any testing was even attempted, good luck ficxing this
  • yadayada
    disconnect the board from the motor, then make up a clip lead to supply 120 volts to the motor. I really doubt the motor is defective, the boards are what fails almost 99% of the time.
  • 19,396 Answers
Hi.
This is usually a problem with the water temperature sensing. If the problem was the motor it would be detected by control board, and cycle would stop with a fault code.
The fault description will be slightly different if machine is not self heating. In this case check the water inlet hose, and ensure that the dual inlet valve is OK. The valve is tested reading continuity. A dual valve can also be tested swapping hose. If the Hot inlet is bad, the machine with swapped hoses will not fill at all because warm water is filled last.
If the machine fills and heats up the water (r fill warm water), but does not proceed any further in cycling , that means that the timer board did not detect that the correct temperature has been reached.
In this case the machine keeps heating or filling warm water, and the cycle does not advance, or the machine stalls with cold water inside, and cycle still will not advance.
When this happens it usually means that the thermostat is faulty.
The thermostat can be tested by a technician reading Ohms at its contacts and jumping or opening its contacts.
The thermostat must read zero or very low impedance at room, and it will cut off reading no continuity when the limit temperature is reached.
If the machine keeps cycling , then the thermostat is not opening, or it is not reading temperature because defective.
To find parts you can use the links listed here: Parts and diagrams.
If you need to call a technician, use the phone number listed on the owners manual or see Fixya directory.
Regards.
Wont spin, drain or agitate
the transmission is either burnt out or the freaky looking belt that turns the pump is off. or the switch that tells the unit that the top lid is down sometimes comes loose cause some companies used a caulk like substance to keep the foot attached to the switch as slid away from where it is and the lid is not pressing that foot down to close the circuit and tell the tranny its safe to spin etc. You can fill with the lid open but not spin. There is a motor that controls all the spinning and draining or agitation and if something in their design is opening the circuit it wont perform those functions.
another idea is the timer motor isn't making contact and you might have to replace that..... there are tons of issues that can cause that.
Feb 20, 2014 | Amana Washing Machines
Washer fills, agitates, will not drain or spin
check your lid switch ,or debriss in drain pump ,pump can not run will not spin untill machine waterlevel switch comes below a certain level of water pressure
Jan 22, 2013 | Hotpoint 3.2 Cu. Ft. Super Capacity Washer
Wont agitate or drain water to spin
Check to see if your lid switch is working. On most models the lid switch will prevent the washer from spinning with lid open. Some models will stop once the washer fills with water. Depending on what brand you have depends on where the lid switch is. If you need assistance finding the lid switch or replacing it please respond back. Thank you
Aug 02, 2011 | Washing Machines
Kenmor top load Washer, Wshr fills, agitates, wont spin or drain
The Lid switch is the most common problem with what you have descibed.
some of the lid switches are located in the control area and some are on the right side center lid area and their is a hole where the lid has a plastic pin that presses it.
Jan 12, 2010 | Washing Machines
Whirpool washer wont work
The lid switch, get something to hold it down to make machine work. Turn machine on and push down on lid.
Jul 26, 2009 | Whirlpool CAM2752KQ Top Load Washer
Washer is filled with water,,it wont drain,,nor
Sounds like a bad lid switch. When you close the top lid, there is a safety switch that closes, it is actuated by a pin attached to the lid, there will be a small hole located on top of the machine, somewhere on the perimter of the top of the tub. Could also be a bad timer.
Jun 25, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag washer, model: LAT8415AAE top loader. Washer fills with water but will not start agitating,spin or drain.
Check lid switch. Most will not run with lid open and the switch may not be pressed down when door is closed
May 17, 2009 | Washing Machines
Kenmore washer 80 series 110 model not spinning.
unless your washer is over 20 years old, then it wont have a belt. the temperature of the water wont have anything to do with it spinning or not.
need to know if it agitates or drains and just wont spin.
if it agitates but no spin or drain, then you have a bad lid switch.
if it wont agitate or spin, but will drain, then you have a broken drive coupling.
Jan 08, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 series
Okay...I'm a little confused on your symptoms. You initially said it fills, but doesn't agitate or spin, but drains.
Then, you finished with the washer filling, no agitate or spin, but now doesn't drain.
Which one is it?
The symptoms you describe are usually associated with the following:
1. Fills, may or may not agitate, won't spin or drain - lid switch.
2. Fills, may or may not agitate, won't spin, but still drains - motor coupling.
3. Fills, may or may not agitate, won't spin or spins slow - gear case.
4. Fills, agitates, spins, but does not drain – water pump.
NOTE: These are the more common failure items with these symptoms.
Double check the lid switch by opening and closing the lid. You should hear a clicking noise to indicate the switch is working. The switch is located under the top panel along the wash tub rim on the right-hand side. If not, check to make sure the lid strike (small plastic piece on the lid itself) is in place. This activates the lid switch when the lid is closed. Also, check the mounting screws along the rim (there are two of them) to see if they are tight.
If the motor coupling were bad, the washer would still drain, but there would be a rattling sound as the washer tries to spin or agitate.
If you need replacement parts, go to searspartsdirect.com and type in your model number in the "Search by Model Number" window. The lid switch can be found under the "Top and Cabinet" heading as item number 11 (part #3949238). Instructions on how to replace are located at the following link:
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
If you wish to replace the motor coupling, the part can be found under the “Brake/Clutch/Gearcase/Motor/Pump” heading as item number 13 (part #285753A). If you need instructions on how to replace, just follow this link:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
Now, there’s a couple of ways to drain the washer. If it’s a simple lid switch problem, you don’t need to drain the washer to replace the switch. With a broken switch repaired, the washer will run and drain by itself. However, if you wish to drain the tub you can use a shop vac to pull a vacuum on the drain hose. This may take a few times depending on the size of the shop vac. These wash tubs typically have about a 35 gallon capacity. If you do not own a shop vac, you can by-pass the lid switch by jumpering the two BLACK wires at the lid switch connector that is connected to the console. CAUTION: Make sure you UNPLUG the washer before jumpering, then plug back in.
I hope this information is helpful to you. If I’m wrong about the symptoms, please post back and update me on what the washer is or is not doing, so I can assist you further.
May 15, 2008 | Kenmore 24032\24036 Top Load Washer
Washer problems
if it wont drain , check your lid switch, check out your motor coupler, if it will not agitate and spin, replace your motor coupler, if it agitates and dont spin, replace your lid switch.
alot of times the washer will drain but we hurriedly cut it off when we hear noise or the water is out but it never spinned and so the clothes are soapy wet...
Nov 12, 2007 | Roper RAX7244KQ Top Load Washer
General Electric WHDSR209DWW Top Load Washer Logo
62 people viewed this question
Top General Electric Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
