Question about Huffy Womens Mountain Bike - Passion Purple
Ball bearings fell out of handlebar connection on 3-speed bike.
Was adjusting handlebar when ball bearings fell out. It's a 3 speed 1969 model Made in England mens bike. The gear adjustment is in the right grip handle. The steering is real tight now, and doesn't steer well. Help.
    Brigadier General:
  • 8,546 Answers
Take it to a professional bike shop. They have the knowledge and tools to set it right.
Or take a look at this:
http://www.sheldonbrown.com/headsets.html
The headset nuts were not necessary to be moved for handlebar adjustment. Now the bearing load is too tight. Correct adjustment of the headset requires a delicate balance between tightness and freedom of movement. If your bike has/had the original bearings it's a safe bet they may be due for replacement anyway.
Posted on Apr 28, 2010
How many ball bearings are there supposed to be on each side of the front axle of the Schwinn Point Beach model S4852WM bike?
There will always be a small gap in the bearing ring, and not all hubs take the same amount. However, if the balls are 3/16" there are almost always 10 on each side. If they are 1/4 inch (less common) then 9 is the correct amount. DO NOT replace only some of them - replace only in a full set of 20 or 18.
Sep 10, 2016 | Schwinn Cycling
I want to roll my handlebars foward on my 2011 vegas 8 ball how do i adjust the break an troddle back
I'm unfamiliar with the Victory's, but can't you just loosen the handlebar clamps and rotate the bars forward?
Jul 11, 2014 | 2008 Victory Vegas 8-Ball
Ball Bearing Replacement
Ball bearings or ball joints? Ball joints do go bad about that milage on your truck.
Feb 20, 2013 | 2006 Ford Explorer
Do you know about the deep groove ball bearing?
If it fell out then it can't do it's job which is to regulate the pressure within the pump and is "shot."
Oct 09, 2012 | Cars & Trucks
NEED TO REMOVE CLUTCH CABLE FROM CLUTCH
Loosen the clutch cable adjuster and increase the slack in the cable. Remove the jesus clip on the bottom of the clutch perch at the handlebars. Push up on the pin that holds the cable in the clutch perch and remove the pin. Pull the top end of the cable out of the clutch perch. Remove the trans side cover. There is a ball and ramp attatched to the inside of the cover with a retaining ring. Push the ramp all the way to the front, turn the cable 180 degrees and remove it from the ramp. it is easier to do this if you remove the retaining ring, then take out the ball and ramp. Be careful not to loose the 3 ball bearings! Unscrew the cable from the trans cover and you are done. Installation is the reverse of removal. When reassembling the ball and ramp, it is easier if you put grease in the indentations for the ball bearings, to hold them in place. Before reinstalling the trans cover, make sure the ball and ramp are pushed toward the rear of the bike.
Aug 05, 2012 | 2005 Harley Davidson FLSTC - FLSTCI...
Front right hub and sensor assembly or a diagram
Removal Steps
1. Torsion bar
2. Wheel speed sensor
(if equipped with ABS)
3. Back plate
4. Lower ball joint
5. Upper ball joint
6. Knuckle assembly
7. Oil seal
8. Thrust washer
9. Needle bearing
10. Knuckle
Installation Steps
10. Knuckle
9. Needle bearing
8. Thrust washer
7. Oil seal
6. Knuckle assembly
5. Upper ball joint
4. Lower ball joint
3. Back plate
1. Torsion bar
Mar 01, 2011 | 1999 Isuzu Trooper
Shaking in handlebars
Your tire is out of balance, your steering head bearings are not tight, and you are running too low of a pressure in your front tire.
Aug 30, 2010 | 2006 Honda VTX 1300 S
I have a 1972 mt50 suzuki trailhopper,by chance is there little ball bearings in between the cases when i split my cases there were little bb looking ball bearings that fell out all the bearings are all...
no ball bearings between the cases,only alignment dowels, hollow in the center.if you have ball bearings they have to be missing from one of the internal bearings
Apr 07, 2010 | 2005 Suzuki Boulevard C50
Huffy Womens  Mountain Bike - Passion Purple  Logo
178 people viewed this question
Top Huffy Cycling Experts
 Mikey
Mikey
Are you a Huffy Cycling Expert? Answer questions, earn points and help others
