Question about Sanyo DS27930 27" TV
Turn off close caption
I lost my remote and i need to know how to turn off close caption with menu button on tv. it is a sanyo 27" model number d27820
  • 74 Answers
SOURCE:
I have a Sanyo Model DP42841 and I want to know how to stop the texting that comes when people are speaking?
If your source is the TV (RF input), then the Caption button on the original remote for the DP42841 will let you cycle through the available closed caption options. If you have a universal remote, you'll need to find a code that lets a Caption (or CC) button work with this TV. This is shown on page 8 of manual. ManualsLib has the manual here: https://www.manualslib.com/manual/148706/Sanyo-Dp42841.html .
If your source is any set-top box, you need to disable the captions on that source. This can depend on the system setup. I know that on one satellite dish receiver, the captions for a second TV on the system had to be enabled from the primary TV. (Then the captions showed on both TVs.) On a IPTV set-top box that I use, to disable the closed captions, I need to enter the Settings menu using a pass code from the provider. Then the setting is under Audio.
I hope this helps.
Feb 09, 2018 | Sanyo Televison & Video
How do i turn off closed caption without remote?
There is a manual button said MENU on the tv frame wright?Yes.Try push the MENU button locate functions like Close Captioning like 1,2,3... turn it all off.Also TEXT like 1,2,3... turn it all off too.Tv should have no more Closed Captioning.
Jul 31, 2011 | Sanyo DS31520 31" TV
I am trying to find out how to turn on the closed captioning on this tv, can you help? I have lost my remote...and am hard of hearing.
Look at the tv bazel frame at the bottom of the tv have manual controls buttons look for button said Menu.Push that button go into tv menu look for functions said close captioning turn it on to CC1,2,3 so on.Now tv with programming have CC logo should have close captioning.Or try website like Remotes.com to buy an exact remote as ur original remote.
Jan 14, 2011 | Sanyo HT32744 32" TV
Is there a way to turn off closed caption on this older sanyo tv ds27580
Don't know on the Sanyo, but most TVs let you turn off the CC via the remote, either by a CC listing on the remote itself, or by going to the menu (menu button) which shows on the TV screen, then working your way through the menu to the closed captioning. That should let you turn it on or off.
Good luck.
Oct 05, 2009 | Sanyo Televison & Video
I need closed captions turned off and dont know how
your remote has a caption control on it. it is also in some of sanyo's DS models
Sep 09, 2009 | Sanyo DS27510 27" TV
Can't shut off closed caption no remote
Have you tried unplugging the entire device and plug it back in 15 secs later.
May 17, 2009 | Sanyo DS31520 31" TV
Closed caption
Go into the setup menu and turn off closed captioning there, or just restore the factory presets. I believe this model has a menu button on the front of the tv.
You didn't ask for it, but here's a link to the user manual, in case you need it.
http://www.sanyotv.com/DS27820%20(ESF)%203824A-.pdf
Nov 10, 2008 | Sanyo DS27820 27" TV
Lost remote! How do you turn off the closed captioning?
Try using the channel down button until you reach the menu and proceed from there. Or, you can try purchasing a replacement remote.
Nov 04, 2008 | Sharp 27DV-S100 27 in. TV/VCR/DVD Combo
Closed Caption won't turn off
The following should solve your problem if you have a comcast digital cable box and possibly for others.
Hey, it's worth a shot!
Turn the TV Power on and cable box power off.
Press the MENU button on the front of the cable box.
Scroll down to the caption item on the menu and toggle it to "disabled"
Press the menu button again to close.
Hope this helps!
Aug 11, 2008 | Sanyo DS31520 31" TV
Closed captioning
try uplugging the tv for a day if the captioning is still in customer menu then try to find a universal or replacement remote this remote may have dedicated captioning key there may be a button sequence on the front of the tv that will reset the customer settings
Dec 09, 2006 | Orion STV2763 27" TV
Sanyo DS27930 27" TV Logo
219 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
