Question about Dell 924 All-in-One InkJet Printer
I'm holding in my hand a clear plastic band/strip approx 14"long and 1/4" width which came out from the inside of my Dell all in one 924 printer. Can you tell me how to get it back in place in the printer?
    Scholar:
  • 67 Answers
It can be done, but not without a lot of PAIN. You say it's in your hand. This is the ENCODER STRIP. It runs the length of the printer left to right. It is hooked on the left onto a small metal tab of the chassis, and on the right onto a spring-loaded tab to make it flex. In between the tabs, it sits in a channel on the rear of the in carriage. Its job is to tell the chip in the carriage where it is from left to right at allm times. If it were still in the channel you could, with a little effort, reattach the left and right ens to the chassis. However, it will be difficult to get into the channel now, because it cannot be twisted, and it must be on the correct side facing you. You've nothing more to lose by trying, but a service charge at a shop (IF they would attempt it in the first place)would cost as much or more than some new inkjet printers. If you succeed, be sure to clean the strip with alcohol on a Q-tip. Clean both sides and allow to dry before testing. Good Luck!
Posted on Apr 26, 2010
Carrier Jam
This is what my printer did when it kicked of the 14" plastic strip inside the printer(see posts referring to strip). Look inside for a loose, quarter inch wide and 14" long plastic strip with slots on the end. Let me know if you solve this.
Dec 15, 2008 | Dell 926 All-In-One InkJet Printer
Dell AIO 924 Carrier Jam Problem
To clean the encoder strip, perform the following steps:
  1. Power down the printer and unplug the power.
  2. Lift the cover on the printer.
  3. Using a dry, lint free cloth, pinch the encoder strip on the right-hand side of the cartridge carriage and pull your fingers across it toward the right-hand side of the printer99d8177.jpg
Figure 1: The Encoder Strip to the right of the cartridge carrier. The encoder strip is a narrow band of clear plastic and can be difficult to see without direct lighting.
  1. Plug in the printer and power it on.
  2. Open the cover to allow the cartridge carriage to center itself.
  3. Using a dry, lint free cloth, pinch the encoder strip on the left-hand side of the cartridge carriage and pull your fingers across it towards the left-hand side of the printer. 43e0b19.jpg
Figure 2: The encoder strip to the left of the cartridge carrier.
Nov 16, 2008 | Dell 924 All-in-One InkJet Printer
Dell 924 printer
There could be 4 possibilities.
1. Ink cartridges lids are open which is not allowing cartridges to move freely.
2. Ink cartridges carriage will not move from its original position(left) when front cover is opened
3. Encoder strip is Dirty.
4. Encoder strip is Out of position.
Solution:
1. Open the front cover and check if ink cartridges lids are properly snapped in.
2. Turn the printer off and pull out the power cable from power socket, open the front cover and manually center the ink cartridges carriage.
Clean the metallic rod inside the printer using WD40 or Kleenex from Left corner to right corner properly.
3. Cleaning the encoder strip:
a. printer should be off and disconnected from power.
b. open the front cover.
c. Using a dry, lint free cloth, pinch the encoder strip on the right-hand side of the cartridge carriage and pull your fingers across it toward the right-hand side of the printer and you can move the cartridges carriage to clean the strip completely.
d. Note: The encoder strip is a narrow band of clear plastic and can be difficult to see without direct lighting running parallel to metallic rod.
e. Close the printer and try again to print.
4. Repositioning the Encoder strip.
a. Remove the power cord from the printer.
b. Open the front cover.
c. Gently slide the ink cartridge carrier to the middle of the printer.
d. Gently move the top part of the printer belt to the right.
e. Using an index finger, gently push encoder strip down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
f. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
g. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
h. Once the encoder strip has been re-seated, close the scanner lid.
i. Re-connect the power cord to the printer and try again to print.
Incorrect position of encoder strip
Correct position of Encoder strip
Hope it should fix the issue.
Nov 05, 2008 | Dell 924 All-in-One InkJet Printer
Carrier jam on printer
Solution:
Oct 28, 2008 | Dell 924 All-in-One InkJet Printer
Clear carrier jam
In your case It seems like the Encoder strip is broken or its out of printer . However if you see encoder strip inside the printer connected from left to right, try these steps.
Solution:
1. Cleaning the encoder strip:
2. Repositioning the Encoder strip.
Oct 26, 2008 | Dell 924 All-in-One InkJet Printer
Clear carrier jamed
Solution:
Oct 20, 2008 | Dell 924 All-in-One InkJet Printer
Dell phto 924 clear the carrier jam
Solution:
Oct 10, 2008 | Dell 924 All-in-One InkJet Printer
924 Printer
'Band?'
Does it look like a strip of clear plastic with very fine vertical lines?
Or, does it have teeth molded into it?
The former is used to determine the position of the carriage and is normally mounted through a narrow slot in the carriage and should have small holes at the ends.
One of these ends will be mounted on an immobile hook, the other will have some kind of spring to maintain a little tension on the band.
These will be located at opposite ends of the printer beyond the normal travel of the carriage.
Some printers want these oriented in a particular way; front/back left/right but most don't care much how they are mounted.
Look for markings that might indicate a specific orientation.
If it has teeth, it ain't a band :-( it's the drive belt and the printer will have to come apart to replace it with one that doesn't have any 'ends.'
Don't know the specifics of your printer and the difficulty in replacing these varies widely, depending on the stupidity of the designers.
Aug 27, 2008 | Dell 924 All-in-One InkJet Printer
Dell all in one 926 printer
its a very important part of the printer .that band is called the bar encodder strip.if its broken from its ends it is to be replaced or if just moved out of the printer but looks proper then you have to open the printer and refit it.there is a space for thet strip behind the back of the cartridge carriage from where it should pass while you fit it again.
thanks.
Aug 23, 2008 | Dell 924 All-in-One InkJet Printer
CLEAR THE CARRIER
Solution:
Aug 19, 2008 | Dell 924 All-in-One InkJet Printer
Dell 924 All-in-One InkJet Printer Logo
99 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
