Question about RCA D52W136D 52 in. TV/DVD Combo
Tv will not turn on
My tv power light will appear periodically 2-3 times but tv will not come on. What is wrong?
  • racecar3 Mar 25, 2008
    Thanks so much! I was hoping for a quick fix but I think its a little more complicated than I wanted to believe. I also called a tech today and he said it could be a lamp bulb (?) which would also not allow it to turn on if blown. A new bulb cost $229.
    Genius:
  • 1,139 Answers
Hello racecar3,
This denotes a power supply problem. It could be as simple as a blown fuse or as complex as a problem in your horizontal drive section of your Tv causing the shutdown circuit to activate. I would suggest that first you unplug the TV and do a visual inspection to see if you can see any blown fuses in the TV. If not then put the rear TV cover back on and then take the TV to a qualified TV repair shop to have them take a look at it, and repair it.
I hope this helps,
Thank you,
Henry A. McKelvey
Posted on Mar 24, 2008
I have a Samsung Plasma tv (PN59D8000FFXZA) that after my neighbors house was struck by lightning it won't turn on. What steps should I take for diagnosing the root issue?
When it get hit with any surge usually the main Board is gone, to replace it and hope nothing else is wrong, you can get a 4k LED for probably same price
Amazon com 4k smart tv 50 inch Electronics
Jun 17, 2016 | Samsung Televison & Video
When i turn on the tv, it takes maybe a minute or two to turn it on.. red light flashes as it try to turn on what is wrong with the TV
The reason your television takes a while to come on and have a red light flashing before it comes on is because it is about to develop a problem and it is most likely a power problem.
If your television does not get properly shut down and power goes off on it without the proper procedures, it would start to flash the red light which is to sound a warning that your television would become faulty within a short period of time.
So ensure you go through the normal procedure in turning off your television.
Take care
Oct 08, 2010 | Samsung Televison & Video
Can't power on TV occasionally
It is possible that the conductivity of a power diode is diminished after a period of time causing the unit to receive just under the needed current to function. Test the resistance of internal components after periods of tine or seek manufactures assistance.
Apr 12, 2010 | Samsung LN52A650A LCD TV
Standby light blinks twice after turning itself
this a code that mean overvoltage in power supply (+B)
Mar 20, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Does not turn on, light flashes, it clicks once, the remote control will not even turn the light on
Please follow the below troubleshooting steps: 1. If the Television is plugged into a surge protector, remove it from the surge protector and plug it directly into the wall outlet. 2. Try connecting the TV to a different AC wall outlet. 3. Try power resetting the TV. To Reset the TV, disconnect the power cord for a short period of time (approximately 1 minute), then reconnect the power cord and power ON the TV. 4. If the issue still persists, TV will require service.
Jan 21, 2010 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Flashing green light
Did you try this yet
SYSTEM RESET
If the TV will not respond to either the remote control
or the front panel controls and/or will not power Off,
press the SYSTEM RESET button with a pointed item
like the end point of a paperclip. The TV will turn Off
and the TIMER light will flash quickly for about one
minute. When the TIMER light stops flashing, you may
turn on the TV again. Changes you made the last time
the TV was On before you used the SYSTEM RESET
button may be lost, however, the changes you made
previously are not lost.
POWER/TIMER Indicator
The green light is a multi-function indicator. This light
will flash rapidly for about one minute each time the TV
is plugged into the wall electrical outlet, when power
is restored after a power failure, or using the SYSTEM
RESET button. Do not attempt to turn on the TV again
during this period. Wait for the flashing to stop and
the light to turn off, before attempting to turn the TV
on. While the TV is powered on, the light illuminates
steadily. If the TV has been programmed to turn on
automatically using the Timer feature,
Sep 21, 2009 | Mitsubishi WS-65515 65" TV
TV made a buzzing noise then turned off. Now power light flashes
You have a very Technical problem with this TV. you may have 2 big problems, ballast and dmd. but it could be something else. If you decide to repair it, honestly you will spend more than 300dlls on it, if you like to, go to fixyourdlp.com
Sep 03, 2009 | Samsung Televison & Video
Tv doesnt turn on.
check the caps on power supply
Mar 21, 2009 | LG 32PC5DVC 32 in. Plasma EDTV
No picture but has sound
My LG TV
switch on no picture but short period of sound then nothing
Jan 20, 2008 | Sony KP-51HW40 51" Rear Projection...
Screen shuts off
my screen will turn on right after unit is plugged in and stay on for a short period of time, then it shuts off and the red light near the power button blinks and teh tv will not turn back on. there might be problem of loose contact in power supply Thanks
Sep 11, 2007 | Toshiba 32AFX61 32" TV
RCA D52W136D 52 in. TV/DVD Combo Logo
264 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
