Question about Panasonic ToughBook 52 Notebook
Can you buy replacement keys for the panasonic cf 52
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 240 Answers
Go to ebay and type in your laptops model + keys or keyboard in search box to get plenty results. Good Luck
Posted on Apr 27, 2010
Testimonial: "good idea, well worth a try"
5 Suggested Answers
1234s282
  • 144 Answers
SOURCE: keyboard installation for CF-52 toughbook
Here you , this is a step by step disassembly guide with pictures
Its for a Toughbook CF-50 but it should be similar as theres not too much difference in the model number
http://www.machinaelectronics.com/store/library/article.cfm?f=key_type_k17
Posted on Jan 04, 2009
GuruGrundy
  • 64 Answers
SOURCE: instructions to replace the LCD screen on a Panasonic CF-52 Toug
Trying this link to see if you can get this information.
Its Panasonic's website, toughbook section
Also try this link.
Posted on Mar 19, 2009
SOURCE: keyboard lights on CF-52
To Control Keyboard lights on CF-52
FN - Up Arrow
or
FN - Down Arrow
Posted on Jul 11, 2010
  • 176 Answers
SOURCE: How do i remove and replace the keyboard on a
There is a plastic piece above the keyboard, pry that off gently, take your time, then remove the screws underneath it that holds the keyboard....make note of the keyboard wiring how its plugged in before you remove the cable, plug in new keyboard and replace everything you took out...should take 15 minutes.
No sound cf-52
Drivers for the CF-27 do not seem to be available but drivers for the CF-52 are available from the Official Panasonic Toughbook Support Website which you can find here:
Official Support Download Center of the Drivers Manuals and FAQs TOUGHBOOK...
Good Luck to you and Best Regards from:
Richard, Montreal Based Panasonic Canada Toughbook
Authorized Dealer since 1989.
Feb 01, 2014 | Panasonic Toughbook CF-27 Notebook
Swapped out hdd cf-52 nothing happening
When you swapped out the Hard Disk Drive
of the Panasonic Toughbook CF52 it is very
importatnt that you did not "hot" swap the HDD
but that you turned off the unit with a full shutdown
and unplugged it as well.
Once you removed the Hard Disk Drive (HDD)
I am assuming that you replaced the drive with
another drive that had a proper operating system
already installed. If not, then of course nothing
happened since you replaced the HDD with a blank
or unformatted HDD.
One way to verify if the replacement Hard Drive
is recognized by the Toughbook is to go into
the BIOS by pressing the F2 function key and
checking the size or capacity of the replacement
Hard Disk Drive. If it shows the proper value,
then the HDD is recognized at the Hardware Level.
If it shows HDD as None or Zero then the replacement
HDD is NOT recognized and you have to try a different
drive which is functional.
Good Luck!
Regards,
Richard - Montreal Based
Panasonic Canada Toughbook Authorized Dealer since 1989
Nov 08, 2013 | Panasonic Toughbook CF-52 (CF-52ELNBDAM)...
How to enter bitlocker key on a cf-52 or a backdoor
You have secured the machine with a bitlocker key. inter the code to unlock.
Nov 20, 2012 | Panasonic CF74JDMFK2M Semirugged Notebook ...
Panasonic CF-52 Unusable USB Ports
Not usable? Are they broken?
Go into the bios and make sure USB is enabled. Restart your computer and look at the screen to see which key to hit to get into the BIOS or System Setup. Look for USB to make sure it is enabled.
If you have a pcmcia slot on your laptop, you can always buy a device that sticks into it that will have usb ports on it for less than $30 - $40. Otherwise you might need a repairman to take the laptop apart and solder new usb ports to the motherboard.
Apr 13, 2012 | Panasonic Toughbook 52 Notebook -...
How do I replace my keyboard on a CF-52
For the Panasonic ToughBook CF-52 series of Notebook PC's, it's a little tougher to remove the Keyboard, than per se other models.
1) With all repair on laptops first remove ALL power.
Remove the AC adapter (Charger), and Battery.
2) Next you should follow Anti-Static Precautions. A little more on this as to why as you read, but you'll also see you will be very near the Processor.
A Processor is the most susceptible hardware component in a computer, to Static shock.
(It's close to the Keyboard Lid Plate under the Keyboard)
Anti-Static Precautions:
Your body carries Static electricity.
Static can fry out (Short Circuit) the delicate hardware components inside a computer.
The best method is to buy, and wear an ESD wrist strap, and connect it's alligator clip to a good ground source. (Electro Static Discharge. About $5)
The next best method (Debatable) is to place a large metal object on the table, and touch it before disassembling the laptop, and occasionally during.
(Metal serving dish, metal knickknack, etc.)
3) Components to be removed in order; [Straight from the Service Manual]
A) Power, as mentioned
B) The HarDDrive and it's mounting kit.
C) The DVD optical drive
D) The Tilt Panel Assembly
Simply the top outer cover along with the LCD screen that is mounted to it.
The part you tilt up and look at.
E) Keyboard Lid Cover
F) Keyboard
4) Use a multi-compartment container for the various screws you will remove. Mark each container for the area the screw/s come out of.
DO NOT mix them up!
[Some screws look very similar to other screws, plus they are S-M-A-L-L.
Put a screw in the wrong hole, and it may seize halfway in.
Cannot remove it without damaging the laptop, and cannot screw it all the way in.
You can substitute using a multi-compartment container, and use a clean egg carton instead.
Label each egg holder]
Make drawings, and notes if you wish. A guide to return to in case you are interrupted.
5) This is a link to the Service Manual for the Panasonic ToughBook CF-52 series of Notebook PC's.
It is for a CF-52EKMxDxM, but will work for all CF-52 series models, (Manual is free),
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-panasonic
Page 24 for the Disassembly Flowchart
Page 25 for removing the HarDDrive, and it's mounting kit, plus the DVD optical drive.
Page 26 for the Tilt Panel Assembly
Page 29 for removing the Keyboard Lid Plate, and Keyboard.
I'm here for additional questions please post in a Comment.
Regards,
joecoolvette
Jun 21, 2011 | Panasonic ToughBook 52 Notebook
FN - Up Arrow
or
FN - Down Arrow
May 31, 2009 | Panasonic Toughbook 52 Notebook...
Instructions to replace the LCD screen on a Panasonic CF-52 Toug
Also try this link.
Mar 19, 2009 | Panasonic Toughbook 52 Notebook...
Keyboard installation for CF-52 toughbook
Jan 04, 2009 | Panasonic ToughBook 52 Notebook
Where to buy cf 52 motherboard
www.laptopparts.com would be a great place to start. CF-52 is a Panasonic Toughbook laptop.
Dec 30, 2008 | Computers & Internet
Panasonic ToughBook 52 Notebook Logo
383 people viewed this question
Top Panasonic Computers & Internet Experts
Oloyede Monsuru
micky dee
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
