Question about Frigidaire ATF6000ES Front Load Washer
I have a 12 year old Frigidaire 39022 Front loading washer that seems to have broken some kind of floating drum supports. I have always been aware that the drum is suspended in some manner, but during a spin cycle, some thing let go and the drum started banging something awful. I shut it down an unloaded it. I noticed that the drum seems to be a whole lot looser than before. I can actually push the drum inward until hit hits the back of the cabinet. I assume that was what the noise was. I tried running it again with a small load and it did it a second time when the spin cycle started. Any ideas how much to fix, and is it worth it. I live in Northern CA where all labor is very expensive.
4 Suggested Answers
SOURCE: Loud banging noise during final high speed spin
I have the HE3T which is 6 yo. Last week it started making a loud banging noise in the spin cycle. I had a repairman come out. He said it is the drum bearings. He said that it is a problem with these machines and to call Sears. He said that the drum and bearing is one assembly and that Sears should cover it.
I called today and Sears todl me that I have to pay for a Sears technician to come out a determine if it is indeed the problem. If so, it will be covered under the lifetime warranty on the drum. I have to pay for the service call $75.00 and if it is the problem, I will be reimbursed. Cross my fingers!
Posted on May 21, 2009
  • 111 Answers
SOURCE: My 6 year old Frigidaire
A typical failure with your machine is that the rear tub seal may seep water into the bearings. Once moisture enters the bearings, they will quickly fail and cause the type of symptoms you mention. I would suggest purchasing a new machine as the repair cost can't be justified. Whirlpool / Maytag machines are very good and, at least relating to top loading, they are all made in USA. If you want a front loading machine made in USA, I would highly recommend the WFW94HEX model- Consumer Reports #1 rated.
Good luck.
Posted on Mar 27, 2011
SOURCE: Loud banging seems to be
bab shock
Posted on Jul 14, 2011
Hard bang on spin with my frigidaire gallery frontload washer
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Apr 15, 2010 | Frigidaire GLTF1040A Front Load Washer
My Frigidaire front load washer model no. GLTF2940E, is about 5 years old. It has always worked fine. Last week the spin cycle left some cloths wet and now when I start it, it only allow about 5 seconds...
Sounds like you have faulty water inlet valves. They may not be opening fully. You can test the power to the valves with a voltmeter to see if the power is quitting or if the valves are malfunctioning
Mar 12, 2010 | Frigidaire ATF6000ES Front Load Washer
The drum won't turn - sounds like motor is trying to work - only 2.5 years old
IF THE MOTOR SOUNDS LIKE IT'S RUNNING THE BELT IS BROKEN PULL THE TOP OF DRYER OPEN AND SEE IF THE BELT IS AROUND THE DRUM
Aug 19, 2009 | Frigidaire Affinity ATF7000E Front Load...
Drum in Frigidaire GLTF1240AS0 has loud clunking noise
The rear drum support must be replaced.The supporting ball has eaten into the support cup.The belt will have stretched and must be replaced also. You can do the job yourself.
Aug 18, 2009 | Frigidaire GLTR1670A Front Load Washer
Drum came loose on Fridgedaire front loader on final spin cycle.
What was the point of posting this on the site?
The drum has broken loose from the support plate at the rear
You need a new drum and a support plate plus probably an outer shell.
A complaint to the manufacturer may get you a deal on a replacement
Jun 04, 2009 | Frigidaire ATF6000ES Front Load Washer
Kenmore front load washer #44072 drum banging noise
2 possible issues with your washer.
1 or both the support shocks or springs have broken
the drum would look off center even when empty
or rear bearring has worn out.
this is a very common problem with the fridgidaire washer... (this kenmore is a frigidaire model)
problem is caused by very hard water (well water) or improper use of detergent. this machine uses a High efficency type detergent, marked by "HE" on the detergent container
May 27, 2009 | Kenmore 44072 Front Load Washer
My Frigidaire model FWT445GES1, was making noses like the drum was coming off. it nocking and is loss when you grab it. How do I fix this? thanks
I had the same problem (9 year old washer). It was a broken support spider for the drum. It had corroded nearly through, so it was ready to break. Had to buy an assembly that included the drum. Cost about $265. The tub assembly has to be removed and split to remove the drum assembly. I found out that the door boot has to be reinstalled with the tub assembly out and the counterweights in the front removed. My door boot was glued to the front panel. Had to cut it loose with a razor blade. If the problem should be the bearings, the repair procedure will be the same.
Apr 28, 2009 | Frigidaire GLTF1670A Front Load Washer
Frigidaire ftf630as0 Front-Load Washer TUB DOESN'T WASH OR SPIN
How old is your machine? Mine was doing the same thing. After doing some research online (and a visit from a Sears technician), I found out that the bearings died on on the drum. The Sears technician told us it was a combination of the type of soap being used (non HE), and the amount of soap being used per load that contributed to the unit's failure. I wish someone had explained that to us 7 years ago when we bought the machine. Appearently there are enzymes in the soap that will eat away at the rubber washer that protects the bearings. There are less of these enzymes in HE laundry soap, thats why it's recomended for front loading machines.I think the HE soap will still eventually cause this machine to fail, but it would take a little longer than 7 years (maybe 10 or 12). By then it's probably time to by a new machine anyways. We bought a new machine because it would cost over $500 CND to get the old one fixed. We ended up with a Frigidaire Affinity (FAFW3577KN).
Jan 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Drum makes loud noise when spinning
HI thanks for the question. Frigidaire has a life time warranty. on that part .call them. thanks the appliance doc. please rate my answer. thanks.
Apr 29, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire front load washer model LTF530DS loose drum
I have the same issue with the broken spider...in the us and they say it is $300 for labor and $360 for parts. My washer is only 3+ years old...what can I do?
Feb 07, 2007 | Frigidaire GLTF1670A Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
64 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
