Question about Brother MFC-8660DN 5-in-1 Laser Multifunctional Printer
When printing paper comes out all "crinkled" maybe roller problem?
  • 85 Answers
It the paper comes out crinkled or accordion looking then it is your fuser. Check where your the paper comes out of. There might be a piece of paper jammed in there that is causing this. If no obstuctions then it might be the roller on the fuser cracking and cause it to crinkle the paper. The fuser is the last thing the paper goes through before coming out. It "fuses" the toner to the paper.
Posted on Apr 26, 2010
Having constant paper jams - the paper does feed and the document prints about 3/4 of the page, but crinkles up before exiting the printer, like the slit where the paper is supposed to come out after...
If the paper is jamming at the exit rollers, you will be need to clean the rubber on the rollers. It gets shiny and does not grip the paper to take it away.
I clean the rollers with Isopropyl Alcohol and the green kitchenlb_icon1.png scouring pads. When the rollers are shiny they often have white/grey markings on them. Keep scrubbing until rubber is roughened up.
Oct 14, 2013 | Brother MFC-7220 All-In-One Laser Printer
MFC 240C print quality is excellent but prints crooked on page. Ran alignment multiple times, no help.
When the paper does not feed straight, dirty or sticky rollers can cause it to jamb or crinkle, also failure to remove all traces of paper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these pieces of paper. The rollers may be dirty or sticky and causes the paper to not feed straight.
Try cleaning the rollers with methylated spirits.
Mar 30, 2013 | Brother Multi-Function Center MFC-240C...
My canon Pixma. When it prints, the sheets come out crinkled!
This usually happens when the rollers that feed the paper through the printer are dirty. Because your printer is still rather new, I'd imagine that it is a dust problem rather that ink overflow. what you should do is get a cotton swab and some 99.9% alcohol and clean the rollers. The rollers will look like black cylinders and will be in locations that the paper goes. there are usually 2 just inside of where the paper is, and you find some under the cover where your ink is. Once you have cleaned the rollers, try to print again ans see if it still comes out wrinkled.
Mar 05, 2011 | Canon Pixma MG5220 InkJet Printer
Ricoh CL 7100 fuser jam.
The grinding noise is the clashing of gears. The fuser is composed of 2 rollers, a metal or ceramic with a heater inside (bulb) and a silicon roller to apply pressure. The 'hot' roller is geared and the silicon roller can be geared or free floating. There is at least 1 paper sensor in the the fuser to let the unit know whether paper is there and there when it should or should not be. Sometimes, the sensor gets slightly dislodged and can actually cause a jam. If you are hearing a gear clash, the paper is being pushed through the machine and instead of being pushed through the fuser, it stops because the fuser rollers are not turning. The rest of the machine keeps pushing, crinkling the paper.
If there is crinkling, then gears that drive the fuser need to be checked. It is this gear cluster and/or the fuser that need to be replaced.
Aug 03, 2009 | Ricoh Aficio GX5050 GelSprinter InkJet
Paper is coming out wrinkled in one spot
Most of the crinkled paper issues I deal with have to do with the fuser roller lining going bad. If this is your issue the crinkle will be a vertical line from the leading edge to the trailing edge. You will need a new fuser.
Jan 30, 2009 | HP LaserJet 2840 All-In-One Printer
Crinkled paper
Pop open door to make sure nothing is stuck near rollers. Could be paper, staple, paperclip, etc. Clean out and try again.
Is it the same paper you always used?
Feb 26, 2008 | Brother MFC-8460N All-In-One Printer
PAPER CRINKLING
First check the paper path for something in the paper path. Staple, paper clip, etc, causing the paper to twist. Reseat the imaging unit and see if the transfer unit is seated properly.
But, What sounds most likely is that the fuser needs to be replaced. The rollers are most likely getting pretty bad inside that unit.
If I recall correctly, it is in the $200 range to replace.
Feb 16, 2008 | Xerox Phaser 6250DP Laser Printer
Martin Yale Paper Folder Problem
Im not familiar with a paper folder but if its anything like a printer, it probably has a maintenance kit you can buy or you may have to replace the rollers. Alot of the times they have a rubber grabber that wears out or a roller that gets dirty and doesnt catch the paper evenly and pulls it through at an angle, crinkling it. Check for debree or paper particles that may be floating around inside.
Jan 02, 2008 | Computers & Internet
Paper crinkles for fax or copies
either your feed rollers are bad or there is a piece of paper stuck
Dec 05, 2007 | HP LaserJet 3030 All-In-One Printer
Crinkled paper
It sounds like a fuser problem. You may have something stuck in it, or the lower roller could be defective. You may have to replace the fuser.
Nov 01, 2007 | Lexmark E320 Laser Printer
Brother MFC-8660DN 5-in-1 Laser Multifunctional Printer Logo
551 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
