Question about Acer Aspire 5610-4648 Notebook
Power I have acer 5610z laptop. The screen visibility was only 10%. So I change the lcd inverter. The visibility came back. The next day the power went off. There was no light glowing on. So I checked everything and it seems ok. I disassemble the laptop and find that whenever the motherboard is connected to the lcd screen the light will go off. So what you think is the problem?? I took it to the shop and the guy told me to change the board. I don't know whether it is because of the inverter I changed because the old inverter i throw it away.
  • 45 Answers
Yes it is your board.
Posted on Apr 30, 2010
My acer aspire 5517 laptop green blank screen and changes to red every 4 second!
More than likely the screen Inverter, Anowarul.
http://www.amazon.com/Acer-Aspire-Series-Inverter-Board/dp/B006BHRG9E
However the problem should be diagnosed.
Problem can be;
1) Graphics chipset
2) Video Cable
3) screen Inverter
4) LCD screen
I have a diagnostic flowchart you can follow, if you wish.
Post back in a Comment.
The plastic frame in front the LCD screen is the Display Bezel.
(Acer? LCD Bezel)
Once removed the screen Inverter is right there in front.
Mounted to the bottom of the LCD screen's Screen Frame.
Service Manual, (Free),
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-acer
Go to where it states - Aspire 1200 (1200 in Blue)
Drop down to the 7th line. (5310G)
Scroll across, and click on 5517.
http://www.insidemylaptop.com/remove-lcd-screen-replace-inverter-board-acer-aspire-5100-laptop/
Regards,
joecoolvette
Mar 19, 2013 | Acer Aspire Computers & Internet
Acer Aspire 5610Z. Upgraded to Win 7. Screen resolution changes
Your laptop was not designed to run windows 7 or be compatible with it. It may run fine with windows 7 but issues might come up sooner or later like the one you're experiencing.
[EXPERIMENTAL]
Download both of these (as I don't know which one of thsese two your laptop needs). Keep mind that doing the following could render your system inoperable and use at own risk. When downloaded, extract ZIP , open desired folder and find SETUP or INSTALL program. Right click and choose properties, then navigate to compatibility mode, then select windows Vista from the menu. Then apply changes, ok and close window and attempt to start.
Acer Aspire 5610Z VGA Intel Driver Vista
Acer Aspire 5610Z VGA NVIDIA Driver Vista
May 27, 2010 | Acer Computers & Internet
I have an Acer Travelmate 5520. Last night while working the screen started to flash and then went totally blank. I powered down and back up again and the same thing happened. The laptop is running but the...
Most likely the inverter module for the lcd screen has failed. If you can hook up your laptop to an external monitor, you will be able to make sure that the rest of the laptop sill functions.
An inverter is a inexpensive part, $10-15 dollars, but requires that the lid be disassembled somewhat to install it
Oct 21, 2009 | Acer TravelMate 5520 Notebook
ACER ASPIRE 5610z BLACK SCREEN
You could have a defective screen - follow this to determine the fault.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 19, 2009 | Acer Aspire 6930-6771 Laptop
My Acer Aspire 5610z laptop picture is breaking up + going blank
Replace the screen, you can download the pixel tester softwar to figure out if the screen is going bad. I'm pretty sure it is.
If you change the inverter its either the onboard video card on your laptop (usually not replaceable easily) or the screen.
Feb 18, 2009 | Acer Computers & Internet
No Backlight when powered up Acer 5610.
Mine does this too. It is the inverter. Of course it goes wrong as soon as your warranty expires. It can result from Best Buy sending you the incorrect battery and them insisting to put it in even though the voltage doesn't match...
You need to replace the inverter. This page should help:
Jan 13, 2009 | Acer Aspire 5610-4648 Notebook
Black screen
check display on the monitor through the vga port of the laptop, if there is display then its the porblme of your screen
Jul 28, 2008 | Acer Aspire 5610 Notebook
Dark lcd screen
when the time you where replacing lcd you made some shot by touching inverter board by lcd. you need to replace or fuse is found in inverter board just replace it it will solve your problem....
Jul 10, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
FIX:
I have an acer aspire 5520G and i can relate all too well. It worked fine for about 3weeks (from brand new!!) then one day the screen went blank while trying to boot. I managed to fix it and it worked fine for almost 2years, untill i went to sell it and encoutered the problem again.
The Fix: this is the fix that worked for me; firstly the problem; this seems to be a big problem with acers for some reason, and there are a few variations or confusions about it when people describe their fault. My fault is that when my laptop is off, i press the power button and the green light comes on, a fan starts up and there is hope, but then the fan changes speed slightly and it stays like that indefinatley, without the screen having ever come on, and i mean the computer is virtually dead except the power light and fan, you cannot press ctrl-alt-del or see the screen from an angle or with a torch. the only thing you can do is hold the power button and force a shutdown, so some deep seeded hardware is still working, but it seems the display never starts and the BIOS never loads.
My first fix - i managed to start my computer by pressing the power button, then as fast as i can (hold function button) repeatadly press F5 and F6 ie. with the function button held you are pressing [Black out screen/Restore Screen] and [Switch Monitors]. this usually starts my laptop on the first or second attempt. The first time i did this i was playing around with external monitor cables and connections, and switching monitors and the problem spontaneously fixed itself as mysteriously as it had arrived.
Second time was extremely frustrating, i could still load my computer by pressing F5 and F6 combos but could not get it to become self sufficent. I upgraded my BIOS with the Flash Updater from acer (i found it on the net) and after the second boot attempt, windows vista installed some memory drivers, and the problem was resolved.
if this hadnt worked i would have tried the memory battery fix as above, as my problem definatly seemed bios related.
Hope this helps someone from loosing their hair.
Sep 02, 2007 | Acer Aspire 5610-4648 Notebook
Acer Aspire 5610-4648 Notebook Logo
89 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
