Question about Toshiba Satellite A100-S8111TD Notebook
XP home edition error
Some time after I start my laptop (Several minutes if not longer)the following error appears.
Error loading C:Program FilesCommon FilesParetoLogicUU52UU5.dll
The specified module could not be found.
I'm not sure what effect it is having because I simply delete it and carry on. Never-the-less I would prefer to solve the problem if possible.
    Sergeant:
  • 180 Answers
Try this. i guess just ignore the avatar stuff.
http://www.rudevirtual.com/Forum/default.aspx?g=posts&m=702958
Posted on Apr 26, 2010
Runs at work, error at home
the restarting is an OS Problem . Please send More details . Regarding Error Code
Mar 25, 2010 | Microsoft Windows XP Home Edition
I recently discovered that Anytime I start my Toshiba Saetelite A105-S3611 laptop/notebook with windows Xp SP2, there is a message: ?Toshiba Power Saver?, A fatal error has occurred, this program will be...
Download the hotkey utility from the toshiba web site. I got this errorafter installing service pack 2 for xp. The hotkey utility fixed it.error appeared every time I started windows xp. Go to:http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
and go to downloads, select model and download:
Toshiba Hotkey Utility
Install and restart, problem solved. thank you, thank you...
May 05, 2009 | Computers & Internet
Windows XP Home Edition Crashed After Loading Service Pack 2
hey coco
nothing happens when you try to use the recovery console right by pressing "r".
try this again and again , sometimes it idles but its still running, if the error appears, restat again.
some corruptions maybe beyond our control and sometimes the only solution for this is to recover the inportant files you have on that HD and do a reformat...
Jan 24, 2009 | Microsoft Windows XP Home Edition
Microsoft windows xp home edition service pack 2 error 1603
Hello corejmwilli,
The 1603 error code your getting, is probably a conflick within the .net versions. I would go to remove programs and software in control panel, and delete any versions of .net that are there, and then you can download this one which is the most current. HERE. That should solve your provblem.
Good Luck
Mark
Jan 06, 2009 | Microsoft Windows XP Home Edition
Connection to server failed account ntlworld server pop.ntlworld.com protocol pop3 port 110 secure (ssl) no socket error 10061 error 0x800CCCOE. This message appears when I use my laptop which uses vista...
Verify the setting via Manage accounts on your XP machine (the one the email client works on) in whatever email client you use on it and verify and edit if need be the setting in your Windows Live Mail on your Vista home Laptop.
Jul 15, 2008 | Computers & Internet
Problem w/ WIN2000 Pro & XP Pro
HERE IS THE SOLUTION :
click on the link given below and find oc25.dll....if you are unable to find press keyboard key cntrl + f .A dialog box will appear now type oc25.dll and hit find key and you will find the oc25.dll .click on that file to download it to your computer.
http://www.dlldump.com/dll-files/O_2.html
Once you have downloaded the file you are looking for you still need to make sure Windows or the program causing the error can find it. Follow these steps:
1. If you are encountering an error with Windows...
The file you downloaded needs to be placed into the Windows System directory. On most machines this is one of the following locations:
C:\Windows\System (Windows 95/98/Me),
C:\WINNT\System32 (Windows NT/2000), or
C:\Windows\System32 (Windows XP).
If you are encountering an error with a particular program...
The file most likely needs to be in this program's directory. This directory is where the program is installed (i.e. c:\Program Files\ThisProgram).
If this step solves the problem, you do not need to complete step 2.
2. You may to register this file with Windows. Click on the Start Menu and then on 'Run'. If you are replacing a Windows system file, type the following command:
regsvr32 \windows\system\file.dll (Windows 95/98/ME),
regsvr32 \WINNT\system32\file.dll (Windows NT/2000), or
regsvr32 \windows\system32\file.dll (Windows XP).
For example, 'regsvr32 \windows\system\apphelp.dll'
If you are replacing a file for another program, change the directory where appropriate. For example, 'regsvr32 \program files\Norton\xyz.dll'
If the file is registered correctly, you will receive a positive confirmation message.
Please let me know your feed-back.
Thanks
dilipbagdi
Technical Associate
Apr 28, 2008 | Microsoft Windows XP Home Edition
Problem loading win XP-SP2
Don;t know if this is the cause of u're errors, but it might be do to the motherboard chipset drivers (the lack of them in u're windows version). If so, u have to make a copy of u're windows cd with all u're motherboard drivers included, and try to install with that cd. The same problem appears to all new laptops that do not offer XP support and only Vista support . In order to do the new XP cd, u\ll need a little program that u'l find on internet..... (for example: n-lite)
Jan 18, 2008 | ASUS A8N-SLI Deluxe Motherboard
Loading XP 15 minutes into the load it stops
try www.supportspace.com
100% free, but 100% qualfied experts to help you.
Oct 31, 2007 | Dell Latitude D600 Notebook
Toshiba Satellite A100-S8111TD Notebook Logo
42 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
