Question about Vacuums
I think its a hoover any way,i guess at one time some one vacumed up some moisture i can se it on the bottom of motor,on one of thewires theresa thermol senser and i see rust in the plastic,cause it good and thencuts out i think the senser out because of the rust in it???????
    President:
  • 1,673 Answers
If mositure got on it, it could have damaged it and hopefully the motor didn't receive any moisture on the inside of it.
Posted on Mar 24, 2008
Water in henry hoover motor HVR 200A
Chris, I hate to be the bearer of bad news, but you've already guessed it. You need a new machine. Personally, if I were you, I'd check into the small shop vac's, type of vacuum. Craftsman has a good one that I've been using for, wow, more years than I can remember now. I had it a long time I know that. I actually picked up a spare one at a garage sale last summer and put it up on a shelf for one my old one finally bites the bullet, but so far, it's still going strong. The wet/dry vac's have a float system in them that actually plug the bottom of the air chamber where the vac draws it's air from, when the water gets too high in the tank. The motor starts to race faster than normal and that's the tipoff that it's full. Dump out the tank and go at it again. Better luck this time.
Nov 10, 2013 | Numatic Henry Bagged Canister Vacuum
I think i vacumed something up and now the moor is loud . But i looked at the belt and bar and everything seems to be spinning okay.. What might be the problem ?
You have most likely cracked the motor fan. Remove the head and look for damage to the fiberglass fan. A broken fan can be VERY loud.
Jan 22, 2011 | Hoover WindTunnel TSeries WindTunnel...
My Hoover vacuum cleaner is not picking up from the carpet like it used to. Like it's having difficulty picking up strings, fuzz, etc. from the carpet. Suction power seems to be fine. The belt and the...
YOUR VACUME SHOULD HAVE A HOSE THAT PLUGS INTO THE LOWER PART OF THE VACUME OR MAY COME APART AT THE BOTTOM . IT SOUNDS LIKE THE TUBE IS STOPPED UP AT THE FAN MOTOR
Jan 16, 2011 | Hoover Vacuums
No suction
OK - Details details details.....
If the motor turns on and only sucks a little bit or you are experiencing a great loss of suction,.
THEN
You have a plug somewhere
Be it a partial block from say a HEPA Filter
or else it is a block in the path of travel where items get sucked up into your vacume.
If you look back to the last time someone used it, was it a fine powder which was cleaned up? then look to the filter (see owners manual for maintenance and or cleaning of the vacume machine) Otherwise is it possible that someone else used it and get it clogged with something larger? Although I'm thinking it is the HEPA filter needing cleaning...
The good news is that if the machine turns on, then you know you have a block somewhere in it, bottom line is you will need to find the clog and you'll be back up and running in no time.
Best regards
Ck
Jan 05, 2011 | Hoover Elite Rewind Bagless Upright...
Hoover core vacuum cleaner. My son has vacuumed water into machine. will this ruin it
Allow it to dry dry for sometime , clean all the filter after keeping it open, then run it open without any attachments , the bag or the filter till all traces of water/moisture goes off. I dont think there will much of problem unless it has gone into the motor and damaged, But take care if it is wet and allow it to dry before you touch it or connect to mains.
Aug 31, 2010 | Hoover Vacuums
Hoover canister vacuum (windtunnel)- turned it on and it had good suction, then smoke came out and it smells like something is burning. Is it the motor burning up or something else?
Probably the belt..
Turn it over so the bottom is facing up..
Remove the plate that surounds the brush..
Check to se if brush is spinning frely and that the belt is on there poroper
Jul 14, 2009 | Hoover U6630-900 WindTunnel Bagless...
Where do you put the filter
This is a motor filter.  It is usually located near the top or bottom of the front of the unit behind a little door.
Nov 28, 2008 | Hoover Vacuums
I can't figure out how to change the belt on my hoover bagless Sprint upright. Please help.
1 set up vacume with bottom facing you , making it easy to deal with.
2 remove the 4 screws holding base plate on and carefully remove the base plate, on mine there is a small catch that must be released.
3the belt compartment is on the right, remove the old belt, it's about 1 and 1/4 wide.
4 You have to put the belt on the stainless steel motor spindle first, then work the belt over the plastic drive wheel, and spin it around a few time to ensure it's running on track ok.
5 Replace the base plate , click in the self catching clip last.
6 Replace the four screws and test the vacume.
Oct 23, 2008 | Hoover Vacuums
My fan belt on my hoover is broken,where is it located and how do i fit a new fan belt
Get a new belt, then remove the bottom plate. The belt goes around the brush roll and the motor shaft. If you don't see the motor shaft, then you will need to remove the top cover to get to it. The belt will stretch to go from the motor shaft to where the brush roll sits in. If this model has 2 belts, then the drive belt(flat) goes from the motor shaft to the bigger pulley close to the brush roll.
Aug 10, 2008 | Hoover Vacuums
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
