Question about Norcent Technologies LT-2722 27 in. LCD Television
LCD TV Remote quit working
Just bought that TV a few weeks back. all of a sudden the remote stopped working. Well, first thing I thought, batteries are dead, so I replaced them.. but still nothing works.. could a remote be somehow locked? Is it possible to buy a universal lcd remote for this model without the remote working?
thanks guys
    Scholar:
  • 43 Answers
First thing, turn off the TV and unplug it for about 2-3 minutes. Remove also the batteries on your remote. Re-install the batteries on the remote and plug in your TV. Power on your TV using the remote. No luck?
Norcent may not be supported by a universal remote. If you just bought your unit new (maybe Best Buy who carries this brand) you are still covered by its warranty. Below are ways you can reach Norcent.
http://www.norcent.net/main/contact.asp
909) 305-2121
[email protected]
Posted on Mar 24, 2008
SOURCE:
My remotes stopped working within a week of each other??? I have a 32" and 42" bought at the same time a few years ago. Last week my 32 decided it didnt want to work with the remote anymore and now my 42...
infrared board may have a fault. its in the front part on the board with the buttons. the infrared receiver may be going or gone it looks like a square led. that picks up the signal light from the remote.
Sep 20, 2013 | Vizio Televison & Video
The TV is not responding to the remote contrlo. It is a new Linsar 16LED05B. We cannot cmplete the initial installation without it. we have checked the batteries and they are fine. The light on the...
is this the second tv in the house? we have just bought another tv for bedroom and had the same problem but we discovered control WOULD function when the aerial was NOT plugged in, it obviously could not tune but all other functions worked. We still have not solved the problem but thought it might be worth you checking,
Dec 25, 2010 | Televison & Video
When I first had my Bose home theater system installed professionally, my bose remote controlled my tv, cable box, and dvd player. I have 4 remotes including the bose remote. I thought the bose remote was...
If your remote worked everything for a few weeks and then quit, and you are sure the codes are correct, take the remote back under the 1 year replacement warranty and exchange it. It is defective.
Jul 31, 2009 | Audio Players & Recorders
LE26R74BDX TV Not responding to Remote
there is a easier way to check your remote.
Open your radio on AM frequencies, you don't need to be tuned just noise is perfect, then bring your remote near the antenna and press some button. You will ear the frequency in your radio. If it works this way but not on the TV make sure to press the TV button before using it (if the remote is universal).
Jul 01, 2009 | Samsung LE26R74BDX 26 in. HD-Ready LCD...
Vizio remote control not working
Wow, I feel stupid! Solution #2 did it! There are 2 Tv buttons, one on the top right and one on bottom right. You have to press the bottom one!! THANK YOU PPL!!!
Apr 04, 2009 | Vizio VO47L 47 in. LCD TV
Tv won't stop changing channels
You need to isolate the problem.
1) Unplug the set for a few seconds then plug it in.
2) Operate the TV with the control/buttons on the TV. (Channels etc)
If the TV operates correctly then do the following.
3) Try operating with the remote unit. If the problem returns then it's the remote failing.
Sometime remotes can be reset.
Try this;
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
Try it again. If the problem is still there then the remote is bad.
Since this is a new TV you should use your warranty to replace any bad parts.
Mar 16, 2009 | Vizio L32 32 in. LCD HDTV
Vizio 32L, remote sensor malfunction
UNBELIEVABLE!!! mattymcmatt has the solution!!! I have had trouble with my Visio 26" remote ever since I got it several years back. Had to mess with the batteries, BUT Finally it quit entirely several months ago. I have tried everything... batteries, unplug TV, press each button on remote, etc... just bought a new remote, and tried all the above 'fixes' AGAIN nothing has worked. read mattymcmatt's fix of unplugging tv held down the on button on the tv for little over a minute, plugged tv back in and and VIOLA my remote is now WORKING!!! thankyou matty!!!!
Nov 27, 2008 | Vizio L32 32 in. LCD HDTV
Zenith B27A11Z remote stop working
remove the batteries from remote ,then put im back and then try again
Jan 01, 2008 | Zenith B27A11Z 27" TV
Remote Control Problem
take the batteries out of the Sharp remote press and hold the POWER button on the top of the remote for 5 seconds. Put batteries back in. Make sure that function is set to TV. Should work - if not call Sharp. If you are inside the original manufacturer warranty they will replace remote
Dec 21, 2007 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Remote control
The IR detector has failed. it is inside the tv and it is not a do it yourself job.
Dec 12, 2007 | Sylvania LC370SL8 37 in. LCD Television
Norcent Technologies LT-2722 27 in. LCD Television Logo
398 people viewed this question
Top Norcent Technologies Televison & Video Experts
Audrey Messer
Audrey Messer
Jaime Hernandez
Are you a Norcent Technologies Televison and Video Expert? Answer questions, earn points and help others
