Question about Norelco Health & Beauty
I have a Philips Norelco ear/nose hair trimmer. It stopped
I have a Philips Norelco ear/nose hair trimmer. I replaced the battery and it will not work. I checked the battery, replaced it with another new battery and it still won't work. The trimmer is only a few months old. Any idea what might be wrong? And, yes, I checked to make sure the battery was put in correctly - it is not that.
Philips Norelco Nose and Ear Trimmer you need to clean it if it stops. Take the battery out run water over the the head and brush till clean. It then should work. It should be cleaned after each use by running water over the head so that does not clog up with hair and dirt.
Posted on Jan 07, 2014
  • 12 Answers
SOURCE: Blades pull hair when cutting
Just make sure the blades are aligned precisely and make sure it is well oiled. It should be oiled after every use. I use WD40
Posted on Aug 11, 2009
  • 32 Answers
SOURCE: I need some replacement blades for my nose and ear
call the manufacturer and supply the model number this will help
Posted on Oct 09, 2009
clipperdoc
  • 17 Answers
SOURCE: philips hair shaver
it's the small motor inside is shorting out, you are better off with a wahl nose trimmer the warranty is a year but you will not get no bs from wahl on a reolacement. need help geting one email askmannyssharpening@yahoo.com
Posted on Nov 14, 2009
  • 10 Answers
SOURCE: i TOOK THE HEAD APART FOR MY NORELCO T765 TRIMMER.
Go to the URL listed below for a complete owners manual including 20 diagrams. For more assistance with this trimmer, call toll free: 1-800-243-3050
http://download.p4c.philips.com/files/t/t765_60/t765_60_dfu_aen.pdf
Posted on Jun 03, 2010
SOURCE: I recently purchased the G370 Norelco hair
S.O.B! Just bought the bastard 3 weeks ago after I had another one before it that didn't last even a month. THEY WON'T CHARGE A BIT!!! The damn light glows as if it's charging but the device never turns back on. This damn company can GO TO HELL!!
Posted on Aug 24, 2010
Phillips norelco nose and ear hair trimmer
If it is battery powered then the battery is probably flat. If the batteries are rechargeable then check the charger and if alkaline then get new one/s
Jul 18, 2013 | Philips Norelco NT9105 Nose and Ear Hair...
PHILIPS NORELCO G370 CHARGER NOT WORKING . WHERE CAN I GET A REPLACEMENT
Hi, the cheapest ones (with most positive reviews from buyers) is Amazon com PHILIPS NORELCO G370 charger. hope this was helpful.
Sep 25, 2011 | Philips G370 Hair Trimmer
I need to change the battery in a norelco 7864 xl, how to do it?
You will find the correct battery type for model 7864XL at shaveroutlet.com. See link below.
http://shaveroutlet.com/shaver-replacement-parts/shaver-battery-pack-for-most-norelco-more-p-278.html
To replace, you will need to remove the back cover by removing the two screws. You may need to extend the long hair trimmer to get to the second screw. Take off back cover to access inside. There are two metal clips that must be unhooked for better access. You can unsolder the batteries from the circuit board but for easier replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries with small needle nose pliers rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
If you are not able to do this yourself, you can have shaveroutlet.com do it for you. See link below
http://shaveroutlet.com/shaver-replacement-parts/professional-battery-replacement-for-most-models-p-374.html
Mar 13, 2011 | Norelco Health & Beauty
Battery not holding full charge
You will find the correct battery for model 8894 at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/norelco-philips-liion-battery-cell-for-select-models-p-380.html
To replace, you will need to remove the back cover by removing the two screws. You may need to extend the long hair trimmer to get to the second screw. Take off back cover to access inside. You can unsolder the battery from the circuit board but for easier replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old battery with small needle nose pliers rather than unsoldering it from the circuit board. This allows the old battery to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new battery to the old existing tabs
Feb 26, 2011 | Philips Philishave HQ8894 Electric Shaver
The battery dies with three green lites still showing. How do I reset the battery memory to get a full charge, and the flashing red lite when low ?
This problem indicates that the battery is worn out and needs to be replaced. You will find the correct battery type for model 7864XL at shaveroutlet.com. See link below.
Dec 29, 2010 | Norelco Quadra 7865 XL Electric Shaver
I have a Norelco 8865xl. It needs new batteries. How do I replace them?
You will find the correct battery type for model 7865XL at shaveroutlet.com. See link below.
To replace, you will need to remove the back cover by removing the two screws. You may need to extend the long hair trimmer to get to the second screw. Take off back cover to access inside. For easier replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries with small needle nose pliers rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
Nov 29, 2010 | Norelco Health & Beauty
What is nasal trimmer
This is a trimmer to clip those nasty hairs growing in your nose. J.
please rate my answer as very helpful. thanks
Mar 24, 2010 | Emjoi AP-4M Nasal/Ear Trimmer
Philips hair shaver
Nov 07, 2009 | Health & Beauty
Health & Beauty Logo
1,079 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Bruce Foote
Level 1 Expert
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
