Question about Dell 946 All-In-One InkJet Printer
Yesterday my Dell 946 printer was fine. Today when I try to print a document I get an error message which says --------------------------- Microsoft Visual C++ Runtime Library --------------------------- Runtime Error! Program: This application has requested the Runtime to terminate it in an unusual way. Please contact the application's support team for more information. --------------------------- OK --------------------------- I've checked my connections and reinstalled the printer. Can you help?
  • Valerie Nobles Apr 26, 2010
    When I went to check your solution and apply the fix I received the following message:
    System TipThis article applies to a different version of Windows than the one you are using. Content in this article may not be relevant to you.Visit the Windows Vista Solution Center
    I am using Windows Vista Home Premium, SP 2.
    President:
  • 2,923 Answers
What is the operating system of your computer? The error message means that there's missing from the driver library.
Here's what you need to do:
1. Try to uninstall the printer driver.
2. If that did not help, perform a system restore prior to the last day that the printer and computer worked properly.
3. The bad thing is, you need to re-install your OS, if you get the same problem after the system restore. So that all of the required drivers will be installed correctly.
Thank you and good luck!
Posted on Apr 26, 2010
    Brigadier General:
  • 3,513 Answers
Please check this bellow link to get a solution to your problem...
http://support.microsoft.com/kb/307817
Let us know if you want something else please accept the solution.
Thank You for contacting fixya.com
Manual For Dell 946 all in one printer
I used to own this type of printer. You can access the installation drivers by clicking here: http://www.dell.com/support/drivers/us/en/04/DriverDetails/Product/dell-946?driverId=R145315&osCode=W732&fileId=2731116941&languageCode=en&categoryId=PR. Here are the manual and printing documents associated with this printer: http://www.dell.com/support/Manuals/us/en/04/Product/dell-946
Jun 02, 2013 | Office Equipment & Supplies
When I print from the internet my copy prints my color comes out a different color I think it might be my black ink is off I have a dell 946 all-in-one printer.
Are you using Dell Series 5 ink cartridges?
Can you copy a document under the glass? Black & White and color? Do they look ok?
If you unplug the printer from the wall and remove the power brick for 60 seconds, this will reset any error messages the printer has. I would then plug everything back in.
Power on the printer.
Open the printer(with the power on) and take out the Dell Series 5 black cartridge and then reseat it. I would then take out the color Dell Series 5 ink cartridge and reseat it. Now close the printer and it will print an alignment page.
Any error messages?
black cartridge = black side(left side) color cartridge = color side(right side)
photo cartridge = black side(left side) color cartridge = color side(right side)
Dell Series 5 ink cartridges have a sensor in them that cannot be reset. Article on refilling Dell ink cartridges .
Dell Series 5 ink cartridges can be purchased at Staples, Walmart or Dell's Website.
It's possible to get a Dell Series 5 ink cartridge with a bad sensor. I would that these back to the place of purchase for a replacement or a refund.
Rick
Jul 27, 2011 | Dell 946 All-In-One InkJet Printer
Not Printig
When you select print, you should see a preview before it prints. Then you can check your settings. Select, print entire page.
Apr 17, 2010 | Dell 946 All-In-One InkJet Printer
Dell all in one 946 printer
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled or third party cartridges that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
Feb 20, 2010 | Dell 946 All-In-One InkJet Printer
Won't print with one cartridge
I can get my 946 to print with just a black cartridge, as long as I select black and white printing (there is an error message on the PC but I can just select 'continue'). But with just a photo cartridge (i.e. a combined black and colour one) it won't work - looks the same, but the 'continue' option doesn't work.
Dec 13, 2009 | Dell 946 All-In-One InkJet Printer
Off line message.
could you check your settings please.
start, control panel, Printers, right click your printer, check it's online here,
or, double click your printer, when grey box appears, go to documents tab, check it's set as your default printer,
Cancel any jobs,
try to print now
or reboot and try printing again.
Hope this helps
Regards
Richard.
Apr 21, 2009 | HP Deskjet 5940 Photo InkJet Printer
I have a Dell 946 printer that is a couple of years old. It has started printing crooked on the pages. I have done the alighnment and that did not fix the problem. Can you help?
probably no much you can do the correct the problem because The problems that users encounter while using a Dell printer
varies with the model. However the common problems all Dell printer models suffer from are their slow speed and faulty paper feed mechanism. Quality of prints varies from one model to another, but most of the models do not produce prints having very fine qualities. A Dell printer is particularly notorious for its poor and faulty feed mechanism. They tend to cripple the papers or take in large number of papers at a time and print parts of documents on each page. They keep on generating messages indicating lack of paper, no matter the paper is being supplied or not. Such a problem makes the printer absolutely useless
Nov 20, 2008 | Dell 946 All-In-One InkJet Printer
Dell 946 -carriage jam/stalled
the ink carriage is in far left position and jammed. it appears that the black cartridge far left was not seated correctly. how do i resolve this?
Nov 19, 2008 | Dell 946 All-In-One InkJet Printer
Cartridge error
I switched my cartridges, color in black and vice versa, then printed test page then switched them back and they worked fine.
Oct 24, 2007 | Dell A940 All-In-One InkJet Printer
Dell 946 All-In-One InkJet Printer Logo
60 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
