Question about Hitachi CP-S235 Multimedia Projector
Hi have an Hitachi CP-X880 projector. I bought it used and it worked fine for some time. Then it started to shut off with no warning. No blinking lights, no screen message, no red temp or lamp lights - at least I never noticed them being on. After cooling down for 20 minutes I can toggle the on switch and it will power up again and will work fine until it suddenly stops again. It seems as if the unit is very hot around the bulb. The bulb has 1435 hours. I got two brand new bulbs with the projector so I installed one of them but the projector still stops with no warning. I have cleaned the filter and there seems to be no blockage of the fan and there seems to be decent exhaust air from the front - but maybe not enough to move all the hot air?? Any ideas?
    Top Expert:
  • Hitachi Master
  • 12,962 Answers
Could be overheating - till you find the issue just put another fan directly on bulb and give it the mother of all BJ's.
Posted on Mar 22, 2017
tinamarie49
  • 34 Answers
SOURCE: Hitachi CP-X250 LCD Projector
If both lights are flashing orange, that means that the bulb needs to be replaced and the filter needs to be cleaned. Make sure you reset the counters for both after you replace them.
Posted on Dec 05, 2007
SOURCE: hitachi projector cp - s210
hi there,
I have just done the exact same thing today. Press menu button on projector. Scroll (navigate) to the mirror option. This give you the options to mirror image left to right or up and down.
This should fix any of your problems.
Cheers
Luke
Posted on Feb 03, 2008
Marrie
  • 563 Answers
SOURCE: Hitachi CP R555 Multimedia LCD Projector
Hi there
In your Menu options there is a subfolder where it either reads lamp or lamp timer.
Scroll down to it and hold down you right or left arrow key on the Projector for a couple of seconds.
Posted on Mar 26, 2008
  • 105 Answers
SOURCE: Resetting the air filter timer
Hitachi CP- RX60:
Press the RESET button on the remote control or the right-pointing triangle button on the projector for about 3 seconds. Once you see the RESET dialog, use the upward-pointing triangle to RESET. I can't see what you are or are not doing...so please see page 39 of the user's manual (download found below)
Source:
http://www.aboutprojectors.com/Hitachi-CP-RX60-projector.html
Hitachi-CP-S335 :
"The lamp time is the time counted after the last resetting. It is shown in the OPTION menu as the use time of the lamp. Pressing the RESET button on the remote control for about 3 seconds displays a dialog. To reset the lamp time, select the RESET option using the (triangle) button."
Taken from pg 36 of the users manual (download link below)
Source:
http://www.aboutprojectors.com/Hitachi-CP-S335-projector.html
Posted on Apr 24, 2008
  • 3422 Answers
SOURCE: Have a hitachi projector CP-RS55.
CLICK HERE
to view the user manual about this problem.Refer the pg nos.48,49,50..
Goodluck,
Please don't forget to rate the solution
Posted on May 04, 2008
My Hitachi CP-X275 Multimedia Projector will run then shutdown by itself and not show a picture.
Normally when a unit like this shuts down, there are indicators that will show why. Are any of the lights on or blinking when this happens? The most common cause is overheating. Is the lamp indicator RED or the temp indicator? A little more detail would be helpful here. Can you also indicate how long the unit runs before shutting down?
Thanks,
Dan
Nov 04, 2010 | Hitachi CP-X327 Multimedia Projector
Hitachi projector cp-s318 and the pictures give off a red tint.
Make sure the Computer Input is set to VGA, Computer, or RGB (depending on which projector model you have). Go through the menu settings of your projector.
Hope this helps
Apr 01, 2010 | Hitachi CP-S318 Multimedia Projector
Lamp turns-on and off
lamp ballast and/or power supply is going. the ballast has to boost the charge up to 140 vdc, and after it's up to it full strength, it drops down to 40vdc to maintain. if the ballast can't get up to the proper voltage, it shuts down. or the lamp itself will not hold the voltage, and therefore needs replacing.
Aug 10, 2009 | Hitachi Performa CP-RS55 Multimedia...
Hitachi projectors cp rx60 cp r555 same remote control?
Specifically i don't know. What i do know is mfg's use the same codes, whether they map them to the same functions across a series of remotes can't say for sure. Experiance tells me it will be just fine...
Jun 10, 2009 | Hitachi CP-S335 Multimedia Projector
Cleaning the filter/blinking LAMP and TEMP
Goto Advanced menu and select option then lamp Time hold down the reset button on the unit for 3 seconds until a new screen comes up then hit reset. Do the same for resetting the filter time
Feb 01, 2009 | Hitachi CP-X445 Multimedia Projector
Hitachi cp x880
well lens assembly has to be repaired. try avalontc.com
Jul 21, 2008 | InFocus LP70+ Multimedia Projector
If you do not have a remote here is how to reset the filter time. Use the "Menu" bottun to get the "easy menu" to display. Push the down arrow until you get to "Filter Time," then push and hold the RIGHT arrow to reset the filter time. DO NOT try to reset using the "Reset" option on the easy menu, it will not work.
Apr 22, 2008 | Hitachi CP-S335 Multimedia Projector
My CP-RS55 Projector Doesn't Work??? No Light?
Hi there
If the unit is brand new , they should replace it under warranty.
This is most probably a faulty Powersupply / Fanboard !
Apr 15, 2008 | Hitachi Performa CP-RS55 Multimedia...
Hitachi CP-X960 Shutting Down
Hi Jason
This is normally a faulty Ballast ( lamp's powersupply )
It will need replacement unfortunatelly
Apr 02, 2008 | Hitachi CP-X960 Multimedia Projector
Hitachi CP-S225
Hi Ian
Your Projector is in need of a new Mainboard.
Must warn you that it could be a costly exercise
Dec 06, 2007 | Hitachi CP-S225 Multimedia Projector
Hitachi CP-S235 Multimedia Projector Logo
115 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
Chris Goulet
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
