Question about Cakewalk Studio Instruments ( Windows Macintosh ) for PC, Mac (CWS10010C)
How do I change drum sounds (programs in Drum module) from Sonor?
Am using Home Studio for live performance..different drum kits in CSI are saved as "programs"..would like to load a song in Home Studio and have it specify (change) the drum kit ("program") in CSI
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 49 Answers
I like CSI--at least the original. Have you tried going to the "change" function and changing the sound? That's all I can think of.
Posted on Nov 30, 2014
  • 2072 Answers
SOURCE: SMART KIT DRUM CARTRIDGE
Call 1-800-821-2797. Thats a machine software issue..
Here is the note on it.
Problem:
The DRUM and TONER cartridges are not installed correctly. Web page indicates replace %0 empty cartridges. The Machine doesn't copy. Cause:
Firmware and work-process problem. . Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. Don t worry about cartridges. They are safe. Upgrade firmware. The message goes away and machine copies
Posted on Mar 07, 2008
  • 10 Answers
SOURCE: Electronic drum kit, with USB out, problem
Sounds to me like you have the midi tracks outputting to the microsoft midi mapper or wavetable synth, which is built into the sound chip in your pc, and that this is conflicting with the mobilepre sound card - midi is just data, no audio, needs to drive some kind of synth. what you want to do is disable your internal sound card thru device manager, then just use the m-audio mobile pre as the input/output sound card in ASIO mode - you'll need to monitor via the headphone jack on the mobile pre or plug speakers into the line outs on the interface.
Then do tutorial 8 (in help files) on using soft synths - INSERT>SOFTSYNTHs creates a midi track and an audio track in a track folder.
Good luck.
The dude.
Posted on Aug 07, 2008
  • 990 Answers
SOURCE: Toshiba E-Studio 35 PM Kit Instructions
open front door and remove waste toner container, unplug connector and loose blue screw slide out developer unit removed top cover empty developer(100%). then open by-pass, duplex and jam access cover , remove two screws and slide out drum unit .remove charge corona. release latch on rearand remove bracket/bar( on top of drum),turn level counter clockwiseto release slide drum shaft out.remove two screw lift drum blade before install new drum & blade needdust some lubrication powder.after put everything back,hold down05 while turn onthen enter200,press start,let run about 3 minutes ,the value should bebetween 2.35-2.45 press set or interupt key same procedure doing 08then401 set to 0
Posted on Dec 15, 2008
SOURCE: Drum kits marking up and streaking the paper
I had the same problem with a 3100cn printer. Dell had a large batch of defective drum kits. They replaced 3 before we found a good one. I recommend you exchange the defective drum kits.
Posted on Jun 03, 2009
SOURCE: My Ion iED05 Drum Kit Says connect module and wont work?
I had the same problem, still doesn't connect. I got Joy to Key application and Battery 3 demo and mapped the pads to the keyboard letters of the laptop and now it works, got the idea from:
http://www.wibwobweb.com/blog/articles-by-me/using-the-ion-ied05-usb-drum-kit-with-midi-capable-software/
Posted on Oct 17, 2009
Tip
Studio Recording at Home; Part Deux
This tip, continuing the series of Home Studio Recording, focuses on the hardest part of accomplishing this feat: Drums.
A big sound killer on 'budget' recordings is poorly recorded drums. There is a remedy, though. If you have one set of drum mics, buy another (or borrow. This will come into play later, though).
If you have clips that hold them on the drums, great. With the two sets, you'll only use half of the clips. For the rest of the mics, you'll want stands. You'll need one stand for each drum, plus six.
The dual mics serve this purpose: To capture the sound of the whole drum. One mic for the batter head (the side you hit), and one for the resonator (the side you don't).
For the batter head, you'll use the mic clips, and attach the mics as you normally would during playing. For the resonator head, use the stands to position the mic directly across the drum, making a straight line from the top of the drum to the bottom. This will help eliminate any voicing differences, which can be a real headache.
For the bass drum, you'll need 2 stands. Position the batter head mic close to the edge of the head on whatever side is easiest to access, but is also comfortable for your playing style.
Aim the mic so that it is pointed at a midway point between the center of the head and the edge. You can experiment with different spots, but be sure to NEVER let the mic be directly in front of the head.
For the bass resonator head (the front one that everybody sees), position the mic so that it is a mirror image of the batter mic. Once again, this gets rid of voicing problems.
You have just miked your drum kit, but what about cymbals? That's where the other 4 mics and stands come into play. Those 4 will take care of:
Hi-hats
Ride
Overheads
For the hi-hats, you'll want to position the mic about 3-5 inches from the top, and 2-4 inches from the side. It's best to come in from the outside of the kit, so that you'll pick up a bit of ambiance (the rest of the kit, as well as some natural reverb). Point the mic at a point close to midway between the bell and edge of the hats. Too close to the edge, and you'll get a sound similar to banging trash can lids together. Too close to the bell, and there's too much high-mid noise that CANNOT be reduced with an EQ.
For the ride, follow the same instructions for the hi-hats, but add about 2 inches to the distances. Aim the mic a little closer to the center as well, so that the mic will pick up any bell hits. A good spot is 1/4 the distance between the bell and edge.
Now for overheads. These are the mics that not only record the cymbals, but pick up the most ambiance.
NOTICE: I haven't already mentioned it, but you do NOT want to record with the drum kit up against a wall, nor do you want it in the center of the room. For best results, use the midway rule (as with placing mics on drums and cymbals, place the kit midway between the center of the room and the edge, preferably headed towards a corner). This will reduce unwanted echoes in the room due to sound reflection.
You will want to place the overheads about 1.5 feet above the highest cymbal. Space them out so that the entire kit is between them, but be sure to keep them evenly spaced. You'll want to use the snare as a midway marker for the placement of overhead mics, since it is your loudest drum, and more likely to be picked up in the overheads than any other drum. This will also keep the snare panned center (you'll be panning the drums out to the left and right later on the mixer, but the snare and bass stay center).
These are some guidelines for setting up mics for recording drums at home. I hope that helps, and stay tuned for Part Trés of Home Studio Recording.
on Mar 13, 2011 | Music
SD5K Drum module NOT saving user defined voices.
Possibly has a Lithium battery in it that is depleted that maintains the saved data.
Jun 02, 2011 | Simmons SD5K 7Piece Electronic Drum Kit
Alesis DM6 electronic drum kit module sound problems: The mix in, display and sensors are working on the module but no drum sound is produced through the monitor or through headphones (but an ipod can be...
It appears that you have to select a "Kit" of drums when using the external triggers. It appears that the volume level for the kit and that for each voice MAY all have to be set, especially after new firmware download. Read manual about KIT volume level and selecting voice and volume level for those. Manual is NOT very clear about these things and you have to try them as this is where the probllem is.
May 08, 2011 | Alesis DM6 Electronic Drum Set
I'm trying to use the pads of my Yamaha DTXplorer drum kit as triggers for the sounds stored on my Alesis SR-18 drum machine. I have seen that Alesis markets a trigger module of their own which they...
you need to determine what midi note the DTXplorer is using for the snare, kick and 3rd tom, and set the SR-18 accordingly, or vica-versa. the midi notes for each instrument has to be the same.
if you cannot change the midi note in either unit to make them correspond, you can download a "midi mapper" program (i think e-drum might be one), there is freeware available if you search CNet. with a midi mapper program, you would have to get a midi/usb adapter for your computer and rouite the midi signal through a computer. midi mapping software allows you to change the midi note, when the hardware itself is incapable of doing so.
Mar 09, 2011 | Yamaha DTXtreme III Drum Trigger Module
Drum sound distorted
Try a factory reset:
alesissr16logo53x41.jpgrmidialesissr16logo53x41.gif Performing a 'Reset' on your Sr16 will will 'clear' it's memory and re-initialize all of it's parameters to the original factory settings. This implies that:
  • All of your User Patterns will be erased.
  • All Songs will be erased.
  • All drum assignments you have made will be erased.
  • None of the above actions should be an issue to you as:
  • It is assumed that at some point you have Download And Save A Copy Of The Sr16's Current State.
  • It is assumed that at some point you have Export any 'User' Patterns you may have programed into your Sr16 and imported them into your _rMidi installation.
  • It is assumed that at some point you have Export any 'User' Kits you may have programed into your Sr16 and imported them into your _rMidi installation.
  • Perform The Reset
    To perform a 'Reset' on your Sr16:
  • Turn the pwer off and wait a few seconds.
  • Press and hold the PLAY and ERASE buttons while turning in the power.
  • Continue holding down these buttons for at least three seconds after turning on the power.
  • If this doesn't fix it, check power adapter. If that is OK then service is required
    Jun 06, 2010 | Alesis Sr 16 Stereo Drum Machine
    Making Midi Files for Importing to Tascam 2488
    You should always work in wav format if possible because there is a loss of quality with mp3 which is a compression format in which bits are lost in order to compress the file size.
    There are a number of wav editors available which will allow you to load a stereo wav and then save it as a mono wav. The free one I use is called Audacity.
    When working with FL or Reason I will sometimes import files to the Tascam, or I will take the outputs from my PCs sound card and line them into the tacams inputs and record them live. I only tend to do this with programs (like synths) where I am using an external midi keyboard and can play live what I want to record.
    With basic drum pattern tracks I'll usually create them on the PC, save as wav, convert to mono, and then import to a track on the Tascam.
    hope this helps.
    bd.
    Jun 25, 2009 | Tascam 2488 Portastudio Multitrack...
    DTXpress III Special Yamaha Drum Kit - high hat won't sound closed
    solution!! you go to "voice" hit the hihat pedal, then press "page" till you get to hhat ofset and bring the value to negative. approx -25. pressure that you applied to hhat pedal becomes less
    Sep 19, 2008 | Yamaha Dtxpress Iv Special Electronic Drum...
    Good luck.
    The dude.
    Aug 07, 2008 | Yamaha Dtxpress Iv Special Electronic Drum...
    Cakewalk Studio Instruments ( Windows Macintosh ) for PC, Mac (CWS10010C) Logo
    121 people viewed this question
    Top Cakewalk Computers & Internet Experts
    Dan Shibata
    Dan Shibata
    Are you a Cakewalk Computer and Internet Expert? Answer questions, earn points and help others
