Question about ATI RADEON 9000 Pro 128MB AGP DDR with DVI&S-Video (Retail Box) Graphic Card
Installation When I installed the card I got 2 beeps from the computer upon start-up. Then it says there is a resource conflict on the bus. The cmos says its PCI not onboard but the card will not bring up my screen. Its only black
  • Anonymous May 11, 2010
    What is the type of computer you are using so you can tell what the error code you getting means.
    Are you using two monitors, if not how does it tell you that you got a bus resource conflict
  • 99 Answers
Check your motherboard,maybe the card you are going to install is not compatible.if you have the manual,you can check there the video card that you need.
Posted on Mar 29, 2008
SOURCE:
Resource conflict error
I would run chkdsk/f on your hdd as errors like this can be caused by system file issues. Go to my computer, right click on drive C and choose properties than tools and then click Check Now. After that run ASC from iobit, a free registry cleaner that actually works!
Mar 23, 2014 | Computers & Internet
Resource Conflicts errors for PCI in Slot 01
hey carl - first thing - laptop or desk top - if desk top (tower) remove all slotted cards and boot system - when it boots completely to home screen. shut down and insert 1 card at a time until you recieve you nasty screen. or boot into safe mode f10 or12 get in and disable all your cards -windows system- control panel - then turn on one by one doing a reboot - when you do find the conflicting card you should be able to figure which card or cards they conflict to - you will have to change the resource allocations on probable 2 or 3 cards to allow all to work - there all lots of sites that will explain this better - hope this helped
Mar 20, 2014 | Sony VAIO Computers & Internet
Resource conflict pci bus controller
Whenever you have a IRQ problem on a new computer setup or upon putting in a new card the only solution is to move the cards to another slot (swap them with another etc) until your IRQ problems vanish.
Sep 17, 2013 | Computers & Internet
When starting the laptop acer 5100 it tyries to start and it shows the following Bus 06, device 02 ,function 00 error resource conflict pci in slot 03 bus 06 device 04 function...
If it just started doing this all of a sudden, then it is a good bet that *********** board is fried. If you just installed some memory or a communications card or new drive, then take it out and see if it still does it. If not, check the installation instructions to make sure it was put in right.
Sep 08, 2010 | Acer Aspire 5100 Notebook
I BOUGHT A USED ASPIRE 3100-5100 MOTHERBOARD AND GET THIS ERROR WHEN IT TRIES TO BOOT. ERROR Resource Conflict ? PCI in slot 03 Bus:06, Deice:01, Function:00 ERROR Resource Conflict ? PCI in slot 03...
You should try clearing the cmos battery. It's a small battery on the motherboard that can be taken off. Take it off for 20 minutes and put it back in. Then boot up again.
May 03, 2010 | Computers & Internet
My laptop wil not boot. Not even in safemode . It has wndows xp that i had recently put on there.. its been doing this for a min but it would come on after a few tries.. This is exactly what happens when i...
Hello Karen
Try removing and resetting your memory modules.
Blow some air in the slots to remove any dirt trapped in there.
They are locate don the back of your laptop.
The instructions are in the manual under how to change or upgrade memory modules.
Please don;t forget to rate this answer if it helps
Jul 22, 2009 | Acer Aspire 5100 Notebook
Resource Conflict - PCI network controller slot 03 and 04
I had this problem for almost a year. One day I decided to put it back t factory default, it work for a week and then the Error message pop again at boot. I installed windows 7 CR and after a week of working fine, same thing happen. I open my laptop, check everything, clean it, and nothing. Until I found the by pressing really hard on the slot where the conflict was, it work 9 out of 10 times I started my laptop. On my Acer the Slot 3 Conflict is where the memory card reader is, or atleast that is what I though. After taking my laptop to an IT Tech, he discovered that the Slot 3 was right next to the wireless network card, and by pressing the area reallu hard the computer will start 95% of the time. But when I say really hard, I mean really hard, as a matter of fact, while trying we even crack the bottom case.
The solution was one of two options:
1. Acer motherboard in certain models, it was defected, and it was known within the puclic, prompting the same Error Conflict that I have, so we would have to get a new Motherboard ($120) or
2. Take all the OS out of the computer, and Install an Linux OS like (Ubuntu-free) you might ask yourself why?
Because Ubuntu doesn't depend on the hardware to function. Windows does. Ubuntu is a self dependable OS, Unlike Windows.
#2 was my solution, it's been alamost 6 months and I never had the probelm again.
Mar 11, 2009 | Computers & Internet
Resource Conflict - PCI Network Controller in Slot 02
check for an update of bios on acer.com it will fix your laptop problem....
Apr 24, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Re: Hi :) plese help
try to refer this problem to your manufacturer/ store owner of your laptop because most probably its either your memory(RAM) or your video card needs to be reset.it may have loose their connections.
because in the desktop PC's, these are the common problems especially upon booting up your computer.
Jan 16, 2008 | HP OmniBook XE3 Notebook
Open Questions:
%^$#@~ Amazon Prime rEfUnD pHoNe #{+1-85O-8I2-4OO9 how to get refund from amazon prime? Amazon Prime Membership Cancellation Phone Number +1-85O-8I2-4OO9. While +1-85O-8I2-4OO9 is Amazon's best toll-free number, there are 7 total ways to get in touch with them. The next best way to talk to their customer support team, according to other Amazon customers, is by telling about your issue above and letting us find somebody to help you. Besides calling, the next favorite option for customers looking for help for Customer Service. If you think this information is inaccurate or know of other ways to contact Amazon please let us know so we can share with other customers. And you can click here if you want to compare all the contact information we've gathered for Amazon. AMAZON PRIME Tech Support Number +1-85O-8I2-4OO9 to resolve all AMAZON PRIME products. End Your Amazon Prime Membership You can end your Prime membership by clicking the End Membership button on this page. Paid members who haven't used their benefits are eligible for a full refund of the current membership period. [1``85O`-8I2`-4OO9``] UsA Amazon Prime Technical SuPpOrT Number +1-85O-8I2-4OO9 to resolve all Amazon Prime products. Amazon Prime is an American multinational company which was founded by Michael Amazon Prime using its company headquarters in Round Rock, United States of America.Contact Amazon Prime for Setup & Installation Amazon Prime Setup Support & Installation Amazon Prime Helpline number Connect is a utility carrier that lets in you to print and scan from anywhere. Facebook is an internet social media and networking website and with Facebook, you'll be able to share something like permitting registered users to create profiles, upload photos and videos, send messages and keep in contact with friends, family, and colleagues. To find out new things and knowledge completely different places beauty we tend to arrange our tour at reasonable costs. Then you'll watch United Airlines, here all of your needs are fulfilled at a minimum rate. Alaska Airlines could be a major USA airline headquartered in SeaTac, Washington, inside the urban center metropolitan space of the state of Washington. it's the fifth largest airline within the u. s. once measured by fleet size, scheduled passengers carried, and variety of destinations served. Walmart is committed to providing you superior customer service and a nice searching expertise. We're happy to retort to your questions about Walmart com connected queries. The best Walmart phone number with a tools for skipping the wait on hold. The customer can Call Walmart com customer service faster by CSPN. Contact Customer Service team to provide a comment or ask a question according to your problems. This is Amazon's best phone number, the real-time current wait on hold and tools for skipping right through those phone lines to get right to a Amazon agent. This phone number is Amazon's Best Phone Number because 1,820,712 customers like you used this contact information over the last 18 months and gave us feedback. Common problems addressed by the customer care unit that answers calls to +1-85O-8I2-4OO9 include Return an Order, Missing Delivery, Refund an Order, Dispute a Charge, Can't Login and other customer service issues. The Amazon call center that you call into has employees from Arizona, Washington, North Carolina, India and is open 24 hours, 7 days according to customers. In total, Amazon has 1 phone number. It's not always clear what is the best way to talk to Amazon representatives, so we started compiling this information built from suggestions from the customer community. Please keep sharing your experiences so we can continue to improve this free resource.
Oct 22, 2019 | Amazon Computers & Internet
KODAK Printer tEcH SupPoRt pHoNe nUmBeR :~{-l^8OO8O3*-lO69}*-} USA vary KODAK Printer tech Support Number +1{8OO8O3*lO69}}USA Login Repair service center to resolve all KODAK Printer customer service phone Number products.KODAK Printer ROUTER is an American multinational company which was founded by Michael KODAK Printer ROUTER using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, KODAK Printer ROUTER support number, and selling of computer-related services and products. KODAK Printer ROUTER Tech Support Phone Number Recently, KODAK Printer ROUTER has been named the number KODAK Printer ROUTER technical support advice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, KODAK Printer ROUTER customer care number can be dialed to contact the certified technicians Contact Technical Support Use one of the below methods to identify your product and see the available contact options, including Service Requests, Chat, and Phone . Enter a KODAK Printer ROUTER Service Tag or a KODAK Printer ROUTER Get KODAK Printer ROUTER Technical Support Phone Number and Customer Services. KODAK Printer ROUTER is a US-based multinational tech organization having its headquarters located in Round Rock, Texas. This tech organization supports, repairs, sells, and develops technology products. Basically, the company offers computer related products and services.
Oct 22, 2019 | Kodak Computers & Internet
EPSON Printer tEcH SupPoRt pHoNe nUmBeR :~{-l^8OO8O3*-lO69}*-} USA vary EPSON Printer tech Support Number +1{8OO8O3*lO69}}USA Login Repair service center to resolve all EPSON Printer customer service phone Number products.EPSON Printer ROUTER is an American multinational company which was founded by Michael EPSON Printer ROUTER using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, EPSON Printer ROUTER support number, and selling of computer-related services and products. EPSON Printer ROUTER Tech Support Phone Number Recently, EPSON Printer ROUTER has been named the number EPSON Printer ROUTER technical support advice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, EPSON Printer ROUTER customer care number can be dialed to contact the certified technicians Contact Technical Support Use one of the below methods to identify your product and see the available contact options, including Service Requests, Chat, and Phone . Enter a EPSON Printer ROUTER Service Tag or a EPSON Printer ROUTER Get EPSON Printer ROUTER Technical Support Phone Number and Customer Services. EPSON Printer ROUTER is a US-based multinational tech organization having its headquarters located in Round Rock, Texas. This tech organization supports, repairs, sells, and develops technology products. Basically, the company offers computer related products and services.
Oct 22, 2019 | Epson Computers & Internet
juk,'; AmaZon PrImE ReFunD PhOnE NuMbER +1-85O-812-4OO9 Customer service phone number for amazon 1 800 for Cancel amazon prime membership by phone. How to get a refund from amazon prime? AMAZON PRIME Tech Support Number +1-85O-8I2-4OO9 to resolve all AMAZON PRIME products. End Your Amazon Prime Membership You can end your Prime membership by clicking the End Membership button on this page. Paid members who haven't used their benefits are eligible for a full refund of the current membership period. [1``85O`-8I2`-4OO9``] UsA Amazon Prime Technical SuPpOrT Number +1-85O-8I2-4OO9 to resolve all Amazon Prime products. Amazon Prime is an American multinational company which was founded by Michael Amazon Prime using its company headquarters in Round Rock, United States of America.Contact Amazon Prime for Setup & Installation Amazon Prime Setup Support & Installation Amazon Prime Helpline number Connect is a utility carrier that lets in you to print and scan from anywhere. Facebook is an internet social media and networking website and with Facebook, you'll be able to share something like permitting registered users to create profiles, upload photos and videos, send messages and keep in contact with friends, family, and colleagues. To find out new things and knowledge completely different places beauty we tend to arrange our tour at reasonable costs. Then you'll watch United Airlines, here all of your needs are fulfilled at a minimum rate. Alaska Airlines could be a major USA airline headquartered in SeaTac, Washington, inside the urban center metropolitan space of the state of Washington. it's the fifth largest airline within the u. s. once measured by fleet size, scheduled passengers carried, and variety of destinations served. Walmart is committed to providing you superior customer service and a nice searching expertise. We're happy to retort to your questions about Walmart com connected queries. The best Walmart phone number with a tools for skipping the wait on hold. The customer can Call Walmart com customer service faster by CSPN. Contact Customer Service team to provide a comment or ask a question according to your problems. This is Amazon's best phone number, the real-time current wait on hold and tools for skipping right through those phone lines to get right to a Amazon agent. This phone number is Amazon's Best Phone Number because 1,820,712 customers like you used this contact information over the last 18 months and gave us feedback. Common problems addressed by the customer care unit that answers calls to +1-85O-8I2-4OO9 include Return an Order, Missing Delivery, Refund an Order, Dispute a Charge, Can't Login and other customer service issues. The Amazon call center that you call into has employees from Arizona, Washington, North Carolina, India and is open 24 hours, 7 days according to customers. In total, Amazon has 1 phone number. It's not always clear what is the best way to talk to Amazon representatives, so we started compiling this information built from suggestions from the customer community. Please keep sharing your experiences so we can continue to improve this free resource.
See all ATI RADEON 9000 Pro 128MB AGP DDR with DVI&S-Video Questions
Computers & Internet Logo
47 people viewed this question
Top ATI Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
