Question about Gateway GT4016 Desktop PC
My monitor on my gateway mid tower goes straight to power saving mode so I can"t log on
    Sergeant:
    Novelist:
  • 172 Answers
Hi, if the monitor stays on "saving mode" it means you have some bad capacitors inside the monitor, so you have to get it fixed. If you connect another monitor and you still get the same thing, it means the display's resolution is out of range. So restart safe mode and reconfigure it. I hope this helps.
Posted on Apr 26, 2010
My daughter's tower was just returned from being repaired. We plugged everything up and turned on the monitor and on the screen it says "Power Saving Mode" and turns off. Can someone suggest...
Power saving mode means the monitor is not receiving input. Assuming the Monitor is working properly, the tower is not producing the input or the cable is damaged. If the tower has another video out, try pluging into that. Try using another cable, if the problem continues that likely means that the computer is not working properly. The next step would be re seating the graphics card. http://www.youtube.com/watch?v=O9x097QRXeA
Simply remove then re-install the Graphics card. The device is very static sensitive and you should be sure to ground yourself before opening the case of the computer.
If that doesn't work it's likely the computer was damaged during the repair.
Or was not repaired at all, such is not unheard of; http://www.youtube.com/watch?v=WaZFGD0WJc0
Aug 08, 2011 | Gateway FPD 1730 17" Flat Panel LCD...
When I turn the computer on it goes into digital power save and windows does not load
The monitor is going into power-save mode because it's not receiving a video signal from your computer. Are you turning on the computer at the monitor or on the tower? If you're turning the tower on are you hearing any noise (i.e. fans running, beeps, drives spinning, etc.)? Does the power light on the tower come on and stay on? If not you may have a bad power supply or other hardware issue.
May 02, 2011 | Computers & Internet
My monitor has gone to Power Save Mode
If your monitor is going in Power save mode it can be cause by following reasons.
>Check the data cable going from monitor to your Dell Dimension 4600 Tower is connected properly.The connector will be blue or white in colour.
>If the Dell Dimension 4600 Tower is powering on.
If still in power save mode then try to shutdown Tower and monitor,disconnect power cable from tower and monitor.Hold the power button on tower for 15 seconds.Then again try to connect monitor and check,if still nogo,and if tower has no lights then issue with motherboard or video card or power supply.If possible try connect spare known good monitor.
Thankyou
Sep 09, 2010 | Dell Dimension 4600 PC Desktop
How do I turn it on
Hello.
To power on the Gateway VX750, press the power button on the front. The power button has 3 sides with a "G" in the middle.
The LED indicates the power status of the monitor.
  • Not lit - The monitor is turned off or does not have power connected.
  • Blinks one time and then goes off - The LED blinks one time when the monitor's power cord is plugged into an AC outlet to indicate that power is detected.
  • Lit solid blue - The monitor is turned on and active.
  • Blinking blue - The monitor is in power saving mode. Before entering power saving mode, a message briefly appears.
Hope this helps.
Aug 12, 2010 | Gateway VX750 (Black, Platinum) 17" CRT...
My home computer screen wont turn on its goes straight to analog power saving mode
Open it up and look for bad caps with bulging top for monitor this old (released in 2001), replace all 9 at the same time. See example of failed monitor due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 18, 2010 | Gateway FPD1975W 19" LCD Monitor
Computer will not power up. The monitor will display a power saver mode the button will light on the front and a internal light will come on but with the power supply check the cooling fan will not...
i have not work on this type of system b4.from your statement is power pack problem,take it to another system to test or to were you bought it.
Dec 14, 2009 | Computers & Internet
My monitor shuts down after one second.
Dell monitors automatically go into power-save mode after a preset amount of time when the computer is inactive. The Dell monitor will go completely black, instead of showing a screensaver. This doesn't mean that your Dell computermag-glass_10x10.gif has shut down. Instead, this allows your monitor to essentially turn off until it's needed again. You can change how long it is before the Dell monitor goes into power-save mode by changing your display settings.
  1. Step 1 Press any key on your keyboard or move your mouse. Either will turn off power-save mode. Alternately, you can press the power button on your Dell computer tower or laptop.
  2. Step 2 Press any key a second time if the monitor goes from power-save to stand-by mode. Stand-by mode allows the screensaver to appear.
  3. Step 3 Enter your user name and password into the login prompt if your computer requires a login. Press "Enter" to begin using your Dell computer.
  4. Step 4 Change the display settings on your Dell monitor to prevent your monitor from going into power-save mode prematurely. Right-click anywhere on your desktop and choose "Properties." Click the "Screensaver" tab and press "Power." Beside "Turn off Monitor," choose a time amount from the drop-down list and press "Apply."
Nov 13, 2009 | Dell Dimension 3100 PC Desktop
LG Flatron L1717, jumps straight to Power saving mode when it is turned on.
Hi, your monitor has a hardware problem .there possibilty of some IC or Transistor's on the motherboard having leackage ie
Beacuse of over heating of it goes to power saving mode .
Jul 13, 2009 | Computers & Internet
I need to replace the power button on a Gateway E4000 mid size to
I think you will find this site useful in assisting you with removing the cover. I think you can scan directly to pg 107 for the "mid-tower" http://nzr.mvnu.edu/facilities/items/gatewaye4000manual.pdf
Mar 26, 2009 | Computers & Internet
My Gateway 500s monitor is stuck in power save mode
Try tapping the F8 key while booting the computer, you will get the start up menu, choose safe mode, when you log on, go to the display settings, that is right click on the desktop, properties, screen saver, advanced and make sure that hibernation is off, along with turn off disks or whatever , probably see turn off monitor after XX minutes, I make ours 15 minutes (150 computers and servers), I don't let the disks turn off. Choose always on also, not home/office. Try this and see if these settings help.
1r1sh
A+
Net+
MCP
Jan 24, 2009 | Gateway 506GR PC Desktop
Gateway GT4016 Desktop PC Logo
105 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
