Question about Mitsubishi HS-U577 VCR
Remote control-function stopped working. After batteries were replaced and it still didn't work I assumed it was the remote, so I purchased another one. Remote-function still doesn't work, so I can only assume at this point the problem is inside the VCR. Any ideas?
  • Mitsubishi Master
  • 5,056 Answers
Yes it will most likely be the remote sensor on the VCR. If you find where the actual point of entry for signals from the remote control, you should be able to trace the circuit back to the pc board. You should find an IC, chances are it's failed. Of course it could be the sensor itself, but I doubt it. If you put the IC number into Google, you should be able to find out the cost and other details, also if it still is made!
Posted on Apr 27, 2010
Remote works with on and off and volume but stopped all other functions.
1 Remove the batteries form the remote and blow hot air by hair drier about 5 seconds . replace the older/ used batteries with new one of same kind. Does it solve your problem ?
2. Remove the batteries and unscrew the remote and then open the case of remote , clean the PCB's key pad area with soft and dry cloth , put small amount of carbon ink (purchase from electronics parts shop- cost $0.5 approx) on key pad's back side round dots, let it be dry for 30-45 min , assemble the remote and fit batteries and enjoy.
May 27, 2016 | Universal Remote Universal Genesis Remote...
I have a 32" insignia LCD TV. My remote stop
You can reset your remote control by removing the batteries, pressing all of its buttons, and installing new batteries. Also, ensure that your TV's sensor is clean and unobstructed. If the problem persists, try using a universal remote control as a troubleshooting step. This will help identify whether the original remote or the TV is at fault.
Oct 20, 2011 | Insignia IS-LCDTV32 32 in. Television
Stopped working
Assuming that replacing batteries makes no difference the remote has broken.
Buy a replacement from Bose or buy a 'universal' remote from any electrical store. With the latter you will need the appropriate code to link the universal remote to your equipment. Try this website for remote codes http://www.xdiv.com/remotes/
Feb 18, 2011 | Bose RC-18S Remote Control
Remote control-function stopped working. After...
Yes the VCR remote sensor is faulty. It will most likely be the IC, which can be found by tracing the wiring from the detector on the front of the vcr.
May 21, 2010 | Mitsubishi HS-U577 VCR
Remote control stopped working. no signal
I apologize if I am stating the obvious. Replace the batteries with NEW ones and be sure they are installed with the correct polarity. Also, assuming this is a multi function remote, press the TV function button on the remote. Often a remote gets inadvertently set for dvd, or tuner control and then will not control the TV. My Samsung remote for example can control a stereo, vcr, cable box, and dvd plater in addition to the TV. If none of these simple fixes solve the problem you will most likely need to replace the remote. Try partstore.com
Nov 16, 2009 | Vivitek V37835 46 in. LCD Television
Bose 3-2-1 Remote Control stopped working
I purchased a LAZBOY universal remote (at Fred Meyers, on sale for $9.99) and after a bunch of research and trial-&-error, was able
program it with a code (1629) which works reasonably well with the
Bose 3-2-1.
I don't have all the system-level functions (which I never utilized anyway) but do have all the basics as far as power, volume, source, and CD/DVD control.
Sep 07, 2009 | Bose 3 2 1 GSX System
Refuses to work
you are going to have to try a new universal remote because that one is not capable of programming to your tv. not all universals will work. trial and error. your best option sense you need to purchase a new remote is to go to www.replacementremotes.com and search my your TV model number and purchase the original equipment manufactured remote for your tv. Good news you wont have to program it either. and it will work your menu functions.
May 28, 2008 | RCA RCU410MS Remote Control
Remote control will not work?
Hi Quad, recently I also got same recorder and faced the same problem with the remote controller. today i tried to solve this. i opened it up. it turned out the battery connections are not proper. The battery connection are in the form of a spring coil which touches the outerside of the battery which is not touching properly. I bent and slight lift it with a plier and it started working. The other connection is touching front side of the battery(on backside you see label cr2025 printed) and this is alright. I hope it works for you too. with best regards
Nov 26, 2006 | Cyberhome DVR 1600 DVD Recorder
Mitsubishi HS-U577 VCR Logo
75 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
