Question about HP Pavilion a350n PC Desktop
Hello I am getting a code 10 failure to start error on my ethernet connection Do you know how to fix this?
    Sergeant:
    Novelist:
  • 172 Answers
These Device Manager codes can be tricky to troubleshoot, but essentially a Code 10 means that the Operating System and the drive are not "talking" to each other. This can be the result of driver corruption, hardware failure, firmware lock, or device configuration errors.
Try to uninstall it via Device Manager and reboot, and see if it reinstalls and you dont get the any codes then ok. If that doesnt solve the problem you might have to buy a PCI ethernet card. They cost around $10 to $15. I hope this helps
Posted on Apr 26, 2010
Rational SCC 202 service 34-6
34-6 is a service code associated with both the upper and lower oven fans not operating. Check the fan motors. there is a green LED. they should be on steady. If they are blinking, watch and count how many times it blinks before starting over. that is the error code associated with the fan motor. If there is no LED lit, then the fan power supply has failed. The fan failure is a hexadecimal code. "2" is the master fan failure, "4" is the slave fan. "6" is both fans. data to and from the fans is via the I/O PCB. There is a data cable from the operator pcb to the I/O PCB, then on to the fans. The problem can lie anywhere. Fans, PCB's, or data connections.
Jul 09, 2013 | Ovens
Error code 10
Please download, install this driver from HP website. Else, go to device manager and try to update this driver there.
Jul 06, 2013 | HP Computers & Internet
My computer beeps at start up
Depending on your beep code, this might be a hardware problem. Please refer here for a bit of details.
Hope this will give you a place to start.
Apr 26, 2011 | Computers & Internet
Got error code f-10 how do i fix this
Hello, the f-10 error code is a oven temp sensor failure notice. you will need to check the wires leading from the temp sensor to the control. if the wires are in good condition and , the sensor harness is not welded, replace the temp sensor asap.
Thanks
Jun 11, 2010 | Frigidaire 24" Built-In Single Gas Wall...
One red light and a e73 error code??
Hello sir
E73: General Hardware Error: Ethernet port... this error is caused by a problem with the Ethernet port.
May 15, 2010 | Microsoft Xbox 360 Console
Hello, I'm getting and Error Code F24, does anyone
The "F24" error code is a heat sensor error code. The following link explains the error code in detail and the steps to correct it:
http://www.fixya.com/support/r1976126-f24_error_code_whirlpool_duet_kenmore
In many cases, the connector plug on the NTC sensor wiggles loose and causes the error code. Check the NTC connection first to make sure it is tight and making good contact. This may save you a service call and/or replacement parts. Make sure you UNPLUG the washer before servicing anything inside the unit.
A replacement NTC module (if required) can be purchased at searspartsdirect.com for about $10. The part number is 8181705. Refer to the parts illustrations under the "Tub and Basket Parts" heading for item 26 as a pictoral reference to assist you in locating the sensor on your washer.
If you have any questions, please let me know. I hope this helps you.
Dec 08, 2009 | Maytag EPIC MFW9700S Front Load Washer
Bios setting problem?
Optimal Defaults and Fail Safe Defaults are two different sets of values. If you set one after the other the second would have replaced the first. Try setting back to optimal again.
If you still see errors relating to the Ethernet adapter find the Ethernet adapter in your BIOS settings and set it to Auto. If you still see errors try all of the available Ethernet settings.
Hope this helps you get your computer running again.
Oct 01, 2009 | Computers & Internet
Ethernet port connection failure
You could get another ethernet card from ebay for less than $10. Although, honestly, I don't think the port could have oxidized in 5 years. What is the error message(s)?
Mar 29, 2009 | Linksys Wireless-G WRTP54G Router
Xbox360
The Specific Type of hardware failure can be determined by the error code displayed on the screen.
If the screen is blank or you would like additional information follow the instructions for determining the secondary error code in the section below
E45: Unknown (possibly dashboard update related)
E64: DVD Drive Error.... DVD Timeout, Wrong firmware, dvd is without f/w chip, etc.
E65: DVD Drive Error.... DVD Timeout, Wrong firmware, dvd is without f/w chip, etc. This can also be caused by the tray not being fully closed on boot.
E66: DVD Drive Error: DVD model, or version does not match that of the version expected by the dashboard. OR the firmware version on the drive is older then the firmware version expected by the dashboard. Make sure the DVD drive is of the same version originally included with the console and that it is using either the original firmware included with the console or newer.
E67: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it
E68: Voltage Error... This error means that the Xbox 360 has insufficent power to function properly. This can be caused by an error in the hard drive or the fans that make them suck up too much power, it can also be caused if you have unnecessary accessories attached to the console like an external fan unit. Attempt to remove unnecessary accessories first, and then necessary components such as the hard drive and USB devices. If you have any case mods you may want to investigate those as well.
E69: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it
E71: possibly a dashboard update error, Check below in the "Console Reset Codes" for instructions. If that does not work there is no other solution and the console must be sent back to MS for repair.
E72: (not yet known)
E74: There is a 90% chance it's a scaler chip problem (the "ANA" or "HANA" chip near the AV cable connection) it can also be caused by a faulty AV cable so check that first. In rare cases it is a problem with the GPU.
E76: This error deals with the Ethernet port's controller chip, a dead chip may not cause the error but removing the Ethernet controller chip does, it may also be caused by other Ethernet related problems.
E79: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it.
According to tmbinc: E79 is the error code if xam.xex could not be started, i.e. probably a file system corruption.
Dec 10, 2007 | Microsoft Xbox 360 Console
HP Pavilion a350n PC Desktop Logo
113 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
