Question about Spectroniq PLTV3250 32 in. LCD TV
PLTV 3250 no power
TV won't turn on. My warranty is over now. purchased from cbsNBC 11-2006
I have turned switch by power cord off then waited turned back on... Unpluged TV for several hours still won't turn on. No green or red light on front of TV
  • 11,361 Answers
First make sure it does have at least red indicator on the front panel, if not, the standby +5vdc is not working, common problem with this monitor is dead power supply due to bad caps, shorted transistor and Zener Diode in the standby power supply.
http://s807.photobucket.com/albums/yy352/budm/Protron%20PLTV%203250/
Power supply; http://www.google.com/products?rlz=1T4GGIH_enUS282US283&q=pltv+3250+power+supply&um=1&ie=UTF-8&ei=hdgBTL6MJaKMNZLC1Ts&sa=X&oi=product_result_group&ct=title&resnum=1&ved=0CCQQrQQwAA
Posted on May 30, 2010
Proton pltv- 3250 32 "lcd tv a friend gave me
To turn on the TV:
Turning the Display On and Off
There is a power switch on the bottom of the display and a power button on top. The power switch is used to cut off power completely, whereas the power button turns the screen off but
allows the remote to continue working.
To turn the display on:
1. If the power light on the front of the display is off, turn on the power switch on the bottom of the display.
2. Press the POWER button.
To turn the display off:
1. Press the POWER button.
2. If the display will be unused for an extended period of time, turn off the power switch on the bottom of the display and disconnect the power.
Please make sure you rate my answer 4 thumbs up! Thanks so much for understanding, it would be a huge help to me. I would be forever grateful if you could do this for me. If you still have a question or concern about this problem please just respond / reply to my answer here before rating my answer.
Thanks
Tim
Oct 13, 2010 | Protron PLTV-32 Television
My TV will not pwer on, I have replaced the ac power cord and made sure the switch was in the on position that is next to where the power cable gets plugged into the tv. The blue led lite in the front is...
This is common problem with the PLTV-3250, the power supply DC filter caps go bad, 5vdc standby transistor and diode shorted out.
Check the power supply; look for bad caps with leaking/bulging tops, check to see if you have standby +5vdc at the power supply connector, the front red indicator will not be on if you do not have this +5vdc standby voltage due to shorted out Q7 and ZD4.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Power supply: http://www.google.com/products?rlz=1T4GGIH_enUS282US283&q=pltv+3250+power+supply&um=1&ie=UTF-8&ei=9lIDTL7XO4fcM7HA-Ds&sa=X&oi=product_result_group&ct=title&resnum=1&ved=0CCgQrQQwAA
Jul 12, 2010 | Protron PLTV-32 Television
Protron pltv 3250 power cord
It is the same power cord as used for your PC, NEMA5-15P to IEC C13.
This TV has known problem with power supply, so keep an eye on it.
http://en.wikipedia.org/wiki/Capacitor_plague
Jun 18, 2010 | Protron PLTV3250 32 in. LCD Television
Spectroniq PLTV-3250 turned off will not turn on?
Nov 22, 2009 | Spectroniq PLTV-42HW68 42 in. LCD TV
My tv wont turn on
Just 1 SUGGESTION: If the unit is too old, it may be cheaper to replace it, then getting it fixed. But I don't know anything about this.
Oct 13, 2009 | Televison & Video
Tv has no power - Protron PLTV 3250
Look at the othewr posts for Protron PLTV - 3250. You need a power supply.
Aug 16, 2009 | Protron PLTV3250 32 in. LCD Television
Protron PLTV-3250 doesn't turn on
The power supply needs to be replace or repair.
I service these power supplies. If you need more info write to jah2mil@hotmail.com
Oct 30, 2008 | Protron PLTV-32 Television
My PLTV 3250 keeps switching from tv to dtv on its own!
I had the same problem and called the company. They suggested this solution and to my amazement... it worked! Turn off the TV manually (don't use the remote). Unplud the TV from power supply. Wait 1/2 hour. Then replug and turn it on manually. It should take care of it by resetting to factory settings. You will have to redo any color, hue, brightness, etc adjustments. Sherri
Dec 07, 2006 | Protron PLTV-32 Television
Spectroniq PLTV3250 32 in. LCD TV Logo
230 people viewed this question
Top Spectroniq Televison & Video Experts
Frank Zabroski
Frank Zabroski
Jayesh Panchal
Jayesh Panchal
Are you a Spectroniq Televison and Video Expert? Answer questions, earn points and help others
