Question about Microsoft Windows XP Home Edition
What kind of ram would i need to up grade ? i now have two 256 sticks in it.. chuck
  • 666 Answers
I would buy 1 gig stick and replace one of the 256 should run windows and anything else you need it for perfectly however if its simply a browser (internet Browser) computer you may be fine with the 512
Please leave feedback
thanks
Robb
Posted on Apr 26, 2010
My pc was working fine with 128 + 256 ram. few days ago it didnt boot.it was restarting automatically. then i removed 256 ram and it booted normally.means pc works normally with 128 ram but not with 256...
i guess u have 2 different RAM cards in the RAM slots....
the main issue is both dont work together...the primary reason is compatibility....or one of the RAM cards have worn out...
u must use exactly similar kind of RAMs in both slots....
i suggest u use one 512 MB if your motherboard supports....
RAM technology has advanced so mush that you wont get RAMs for old PCs (motherboards)....so u decide...
pls revert back...and kindly leave a feedback and rating for this solution...it will help me move to Guru" here from Expert at Fixya....
regards...
Sep 29, 2010 | Gigabyte GA-8I845GV Motherboard
How to buy addtional memory 256MB, now 256MB. may need more memory for Windows XP Home grade-up from Win 98.
You need 100 MHz SDRAM SoDIMM 144 pin ram to match this laptop. You can put in a maximum of 512 MB (take out the current memory and put in 2 256 MB sticks). One source for this memory is http://www.pcmemorystore.com/Ashton_Digital-MaxiMate-420-ram.htm .
I hope this helps.
Sep 05, 2010 | Ashton Digital Maximate 420 Notebook
Mother board has 4 slots..i have 2 .256 ..but the board only reconizes 348 of it //ive looked in the bios but cant fin how to increase it// emachines T6216 DESKTOP amd ATHLON 64 proc 3200//2.0 ghz //256 +...
I am going to assume that you are talking about RAM.
In which case you will never be shown the exact amount of RAM that you have installed. A certain amount of your RAM gets used as base memory, and therefore is not considered to be available ram.
In your BIOS there should be an option that says something like:
64mb memory OS2. You should enable this option if you are using a 2K operating system.
This option will most likely be under integrated peripherals.
Jul 04, 2010 | E-Machines Computers & Internet
Can i mix my RAM?
You can surely use one stick of 512 and other of 256. Just make sure you are not mixing a DDR with DDR 2.
Please get back for any further clarification
Thank you for choosing Fixya
Mar 28, 2010 | Computers & Internet
What kind of memory can i add
go by the law, youre only as fast as your slowest stick of ram, and PC2700 is about the most expensive ram out there.. old ram that is...
if i were you, sell those two, and buy yourself a stick of 512 pc3200..
i mean think about it mathwise...
if you go from 400 mhz ram
to 266 mhz ram
your going down in speed 33 percent...
sell em! =]
Jan 14, 2010 | ASUS A7N266-C (A7N266-C/ACR_6CH/WOL-UAY)...
I would like to nwom how much of memory this laptop support
The Thinkpad is installed with 128 MB SDRAM is standard, and is expandable to 512 MB
There are two memory slots, to expand it to 512 Mb you need two 256 Mb RAM modules and throw away the 128 Mb RAM module, but if you don't throw away this module and you insert a 256 Mb RAM module in the 2nd memory slot then your total memory would be 384 Mb.
Nov 20, 2009 | IBM ThinkPad T20 2647 Notebook
I want to use both RAM sticks
You may not be able to. the sticks usually have to be added in matching pairs. some older machines may read them mismatched
Aug 19, 2009 | Microsoft Windows XP Professional SP2 Full...
PC RAM
This refers to the data width and chip configuration. 64*8 is an 8 chip 512MB module. (8 components @ 64MB each) 32*8 is an 8-chip 256MB module. (8 components @ 32MB each), etc.
Mar 03, 2009 | Kingston 1GB PC2700 DDR DIMM Memory
Memory upgrade
There is many things that can happen with RAM that end up with this issue.
First I'd try removing the 256 and just place the 512mb stick into the first slot and see if that works. If it doesn't there's one of three problems occuring.
Incompatible RAM (which may fit and lock in place but still not meet the requirements systems BIOS, so it will not function)
Oversized RAM Stick (some models will only use single sided sticks of ram, where most of the newer sticks are double sided. This can actually cause problems like this and even sometimes work but only show half of the ram on that stick)
Dead Ram (It's possible and I've had it happen a few times, that you could have a dead stick of RAM. If the 512 stick works alone without the 256 in there; the the problem lies elsewhere.)
Each manufacturer has different specifications on their systems and the ram that they can use. Believe it or not, one laptop I had would only work if you had two matching sticks of RAM in the slots. So, I could use the two 256mb sticks together; but I couldn't use a 512 and a 256. I couldn't run the 1gb stick and a 256 or a 512 stick. It had to be two matching sizes. So, make absolutely sure you have a compatible stick of ram for the laptop (I suggest calling HP/Compaq and asking them if it is the correct chip as you can never be too sure). If it still will not work, then either the laptop won't support all of the 768mb, or you have a dead stick.
Try these things and see what happens. If you still have a problem, by all means, ask away. :)
Sep 10, 2008 | HP Compaq Evo Notebook N410c
What are the ram limits on a compaq presario 5000a. I put 256 ram in the compaq and it only reads 128. Why?
You can install up to 3 sticks of 512 mb of memory. Did you add a 256 stick to the already-existing 128? You need to put DDR266/PC2100 memory. To troubleshoot, remove the 128 stick and put your 256 in and see if it is recognized. You will know right away from the bios screen. Memory needs to be the same type.
Jul 16, 2008 | Compaq Computers & Internet
Microsoft Windows XP Home Edition Logo
23 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
