Question about Sony Cyber-shot DSC-W50 Digital Camera
When I power on my Sony Cyber-Shot DSC-H2 camera it automatically shuts itself off. When I use the function to review pictures already taken and stored in the memory, it allows the camera to stay on as I click through the photo's. What could be wrong with the camera? Thanks for your help. Dan Parsons
    Brigadier General:
  • 11,967 Answers
This is a lens problem. Try these: Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Apr 26, 2010
Hi, when I click on the button to view pictures the camera switches itself off. Also if I click on the tool box menu the camera switches itself off. Also if I connect to my PC it doesn't see the camera -...
Have you checked the batteries on the camera? Weak batteries will shut the camera off any time ther is a call for power that exceeds the charge left in the battery.If after you change or charge the battery and you are still having this issue let me know and we can go from there.
Please use Sony Cyber-shot batteries for DSC-H2 model camera
If your camera keeps shutting down and not allowing any pictures to be taken, use the 3 pixel setting. It may allow you to get at least some use out of the camera. After reading numerous reviews on this unit and comparing the performance of mine to that of a friend who also has it, I have to say that SONY made a slew of defective cameras and this should have been a recall. Some cameras seem to work fine, thus the good reviews. Others, and there are many many of these, shut down unexpectedly, won't work well on the 5 mega pixel setting, take terrible pictures (especially in low light) and generally aren't worth the money you paid for them.
What I soon learned was that it was running low on battery power and needed to be off most of the time or you would go through batteries like butter. Even when the camera is off and loaded with new cells it will quickly deplete itself. So you have to turn the thing off if you aren't about to shoot...this makes catching that special shot almost impossible, especially since when you do turn it on you then have to wait and wait and wait for the shutter to snap. Forget anything with low light
Dec 26, 2010 | Sony Cyber-Shot DSC-WX5 Digital Camera
Taking pictures with my Sony super Steady Shot camera DSC-H2 What if I want the focus to be on something that is not in the center of the lens?
On my Sony DSC-H1,I just depress the shutter button HALFWAY,with the subject in the center.then recompose the shot as you'd like it(i.e.off center), and the subject will stay in focus.
Aug 31, 2010 | Sony Cyber-shot DSC-H2 Digital Camera
I have a Sony-Cyber shot DSC-P72
It's a memory card error,You can try to take the memory out and retrieving them with your computer
May 13, 2009 | Sony Cyber-Shot DSC-P72 Digital Camera
DSC W70 Cybershot was dropped
My DSC-W70 is problem de turn off ,what im doing
Dec 08, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
Camera keeps shutting off.
Please use Sony Cyber-shot batteries for DSC-H2 model camera.
Nov 18, 2008 | Sony Cyber-shot DSC-H2 Digital Camera
Sony Cyber-shot DSC-N1 8.1 Megapixel
http://www.dcresource.com/reviews/sony/dsc_n1-review/ Hi there, just fixed mine. Had the same problem. Click on link above. Leisa1
Jan 20, 2007 | Sony Cyber-shot DSC-N1 Digital Camera
Sony Cyber-shot DSC-W50 Digital Camera Logo
199 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
