Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Wont go into gear, stuck in neutral - Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
    Sniper:
  • 52 Answers
Check and see if the belt to the rear end broke. Sometimes they will break and get wrapped around the pulley and will keep you from putting it in gear.
Posted on Apr 26, 2010
Will not go into any gear. Seems to be stuck in neutral.
Hi, Warren for more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
totalmotorcycle com
transmission stuck in gear couldn shift fixed
Locked out of gear stuck in neutral
How To Shift When Your Motorcycle Is Stuck In Neutral
Apr 24, 2016 | Motorcycles
I have a JD318 it was running great the other night , but now it wont start. I think it is stuck in gear. How do I get it into neutral manually?
your neutral safety switch wont let it start,if you want to bypass the safety switches,pull the small black wire off the coil
Apr 18, 2015 | John Deere Garden
Jeep compass transmission problem
state the symptom , the FSM lists about 100.
and year,
but> ? (simple?)
slips? aka: flare or false neutrals. (doom)
fails to shift up or down automatically.?
car wont move.?
noise.?
passing gear dead.?
wont down shift on hills.?
cant shift out of park.?
stuck in 1 gear, name it?
Oct 23, 2013 | Jeep Cars & Trucks
1984 BMW 533I MANUAL 5 SPEED
If you tow your car in neutral how come is stuck on one gear. Towing got no problems. That mean it wasnt in neutral it was in gear but the clutch is stuck and seem the gear is in neutral. You should have clutch problem before you think about gear box.
Jul 21, 2013 | Cars & Trucks
98 Honda Accord Transmission Problem sluggish stuck in 4th gear
I'd say the shift solenoid connection is the problem. When the No 1/2 solenoid isn't getting a signal or has failed, the trans then can't find low gears, and of course it will be sluggish at slow speeds.
Mar 05, 2017 | Honda 1998 Accord
My REVO is stuck in gear and wont go into neutral. Athough the lever does move to neutral. What could be worng?
My dad's Revo had the same problem. What happened was the little piston that the engage the gear is stuck and when you pull the lever to dis-engage the gear to neutral the piston stuck no matter how much force you use. What I did was take a flat head screw driver and can to WD40, spray some WD40 directly on to the piston let it sit for 10 second the WD40 to penetrate, then take a flat head screw driver try to lift the piston to dis-engage while pulling the lever up. You will need to remove the left wheel to see the clutch assembly. Good luck.
Aug 09, 2011 | Pride Health & Beauty
My 2002 Saturn Vue stuck in a gear
IF IT STUCK IN PARK.CHECK BRAKE LIGHT SWITCH FUSE AND THE BRAKE TRANSMISSION SHIFT INTERLOCK SOLENOID FUSE.AND PARK NEUTRAL SAFETY BACK UP SWITCH FUSE.IF ANY OF THESE 3.IF FUSE IS BLOWN OR ANY IS FAULTY.YOU WONT BE ABLE TO MOVE CAR OUT OF GEAR.ANOTHER THING MAKE SURE YOUR BATTERY HAS 12.5 VOLTS.
Jan 18, 2010 | 2002 Saturn VUE
Craftsman lt1000 rider 42 in deck is stuck in gear and wont go into neutral. so i cant get it started.
this happens when lawnmower is cut off in gear try this mash clutch and shake mower forward and backwards while trying to shift into neutral
Sep 18, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Dashboard indicator stuck on Drive
My Dodge Intrepid 99 is stuck in he drive position. The gear wont go back to park or neutral or anything. I was looking for the shift release cable but can't locate it. Can someone please help.
Apr 27, 2009 | Dodge Grand Caravan Cars & Trucks
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
330 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
