Question about Kenmore Elite HE4 Electric Dryer
Loud noise agitating and spinning
Makes a loud noise especially when spinning. if it is a belt, how do you get to it?
  • 4 Answers
If you cant get into it through the back by removing the screws making sure you have unpluged it 1st then maybe you have to go in through the top this is sometimes the case in new models
Posted on Apr 26, 2010
My washer will not spin or agitate, but will fill & drain
with it empty need to look at the bottom of the unit and see if the pulley and belt setup is bad.. my sisters un it broke the pulley and hers is newer..seems they dont make them to last anymore..
Feb 08, 2014 | Washing Machines
GE washer WPRE6100G0WT not agitating or spinning
Depends on how old the machine is. It might me a transmission problem
Jul 25, 2012 | GE Profile WPRE6100G Top Load Washer
I have a eterna EWA5600G king size washer that is making a very loud sceaching sound
check the drive belt from the motor to the gearbox it might be louse that would make it screach and week agitating
Dec 01, 2011 | Washing Machines
My Performa Top Load Heavy duty (PAV1000AWW) has a loud noice when it is spinning. Just changed the belt but still extremely loud when spinning...any suggestions>
Thanks for choosing FixYa and welcome to the site. Anytime you have noise while spending, loud thumps and noises, it can almost always be traced back to the drive motor. This is what allows the washer to spin, drain, and agitate. You need to check this out first and check your spin bearing as well. I would say one or the other is the reason for your noise.
Apr 26, 2011 | Maytag Washing Machines
Top load won't agitate or spin
If it is a direct drive (no belt) Your motor coupler is broken. The washer would make a grinding noise but do nothing. Basically it is like a belt it connects motor to tranny. It is a fairly inexpensive part $20-25 retail.
Apr 25, 2009 | Washing Machines
Washer won't agitate or spin out.
Well it is ethier Belt, Cluch ,motor ,Or transmission. But it does sound like your transmission . The loud clunk is the brake in the gear case ( Trans.). It might have broken off.
Apr 05, 2009 | GE WJSR2070B Top Load Washer
My Kenmore 80 series washer just started making a loud Aihaiha electrical or motor type noise. This happened during a heavy load cycle. Noise was very loud. When I click to regular, delicate or hand wash....
The following are the reasons for the drum not spinning :-
* Test the lid switch
* Test the timer control
* Test the centrifugal switch
* Test the water level switch
* Inspect the motor coupler
* Inspect the drive belt (belt drive only)
* Inspect under the washer for soot (clutch)
* Test the motor
* Inspect the pulley
* Test the transmission
In the case of loud noises in the machine, the drum bearings might have been damaged and might need a replacement. Also do check the leveling of the machine. Good luck.
Feb 28, 2009 | Washing Machines
Loud noise during spin cycle and agitator won't rotate
the machine is nknown to have bad main seals, in turn leading to the corrosion of the spin bearing, in which case makes it sound as if a helicopter is landing in your laundry room
Jan 26, 2009 | Amana LWA40A
My Capacity Plus Admiral Washer will spin and agitate, but it makes a loud grinding noise.
Well, Sounds to me like the Bearings are going out, but it could make that noise a good while, before it goes completely out.. Replacement would possably be more cost effective, Kinda hard to beleive !!!!!!
Oct 26, 2008 | Washing Machines
Kenmore Elite HE4 Electric Dryer Logo
73 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
