Question about Directv HR20-700
How do you reformat the hard drive for hr-20/700
Frame freezes up for a few seconds on recorded programs.
  • 212 Answers
If you go into the DVR's Menu/Setup there will be menu selections to "Restart Receiver" and "Reset Receiver"
In the reset menu you should find three options "restart receiver" which is roughly equivalent (and possibly safer) than the reset button or a power cycle. "Reset defaults" will clear all of your preferences and personal setting without affecting recordings. "Reset Everything" pretty much returns the receiver to ground zero and deletes everything.
Posted on May 04, 2010
Dashboard code puller on a 2004 Caddy Deville: U 1016, B 1860 and P0741 codes. Changed oil and exchanged trans fluid. I drove about 120 miles the service light came back on. Code P 0741 can back.
What year ?
If the PCM detects high torque converter slip when the TCC is commanded ON, then DTC P0741 sets. DTC P0741 is a type B DTC.
The powertrain control module (PCM) controls the torque converter clutch (TCC) solenoid valve pulse width modulation (PWM). The solenoid controls the hydraulic fluid for TCC apply and release. When the TCC is applied, the engine is coupled directly to the transmission through the TCC. The TCC slip speed should be near 0.
Diagnostic Aids
• Inspect the transmission fluid level.
• The transmission may be in hot mode. Inspect the transmission fluid lines to the radiator. The lines may be pinched, plugged or twisted.
Do you own a professional or factory scan tool ?
Install a scan tool.
Turn ON the ignition, with the engine OFF.
Important: Before clearing the DTC, use the scan tool in order to record the Freeze Frame and Failure Records. Using the Clear Info function erases the Freeze Frame and Failure Records from the powertrain control module (PCM).
Record the DTC Freeze Frame and Failure Records.
Clear the DTC.
Drive the vehicle at 72 km/h (45 mph).
Using the scan tool, command the torque converter clutch (TCC) pulse width modulation (PWM) solenoid valve ON.
Operate the vehicle under the following conditions:
• The transmission fluid temperature (TFT) is 20-133°C (68-271°F).
• The engine torque is 43-215 N·m (32-159 lb ft).
• Drive the vehicle in D4 with a throttle position (TP) angle of 10-50 %.
• Ensure that the TCC applies for more than 5 seconds.
Monitor the TCC slip speed.
During TCC application, is the slip speed within the specified parameters?
Nov 21, 2017 | Cars & Trucks
When I connect the VC500 to the computer and the vcr, most times, the video plays fine. When I try to record, the video skips - it records - but skips and the recording skips as well. It's almost as if...
Hello mabusse
The sofware is too heavy for your computer . You can improve it's function buy setting the quality to a lower level , it will record smootherly but of course the image will be less sharp .
I experienced my self that the best way to succeed in recordong video tapes or tv programs is to use a stand alone recorder .
Best regards ,
fanaudi .
Mar 03, 2011 | Diamond Multimedia ( VC500) Video Capture
I just got my Xacti CS1 and after I shot a couple of test videos, I checked the playback. On the camera screen, playback is flawless, it's quite great, however, when I play the videos back on my macbook in...
http://us.sanyo.com/dynamic/product/Downloads/VPC-CS1_OM_English-6223243.pdf
p.60 of the manual describes different recording modes with lower resolutions (1280x720) pixels and lower frames per second (30fps).
I would choose from the menu to record in a lower resolution and lower fps mode so that the quicktime program can display the video at a good rate for you.
I don't know what kind of macbook you have, but usually such problems are due to the older macs not having enough speed to display high definition video with all its data all at once.
I used to have problems a few years ago, before i upgraded my hardware on PC's, with choppy video that was High Definition.
Jul 30, 2010 | Cameras
The unit keeps freezing up
Take out memory stick from camera and check does it still freeze?
I think memory card in camera is causing problem.
Hope this info will help you.
Dec 08, 2009 | Sony MHS-CM1 HD AVC Camcorder
Recorded shows/movies skip when played. Frame freezes and then jumps ahead a few seconds. Problem is progressively getting worse.
The hard drive is failing. I suggest you have it replaced before it is totally gone. When the technician comes out ensure he checks the system end to end to eliminate any other possible issues that may be conducive to a future loss of service. Dish technicians are tasked with this responsibility however a sub may not do the same. Thanks for using Fix Ya.
Sep 24, 2009 | DISH Network DVR-625 DTV Receiver /...
Advancing one frame at a time during playback on LCD screen
If I were you I would feed the video from the camcorder into your computer via the dv link cable where you can edit it frame by frame using ulead or similar.
Dec 11, 2008 | Sony DCR-SR65E HDD Camcorder
BURNED DVD FRAME FREEZES
I have no problem with TDK DVD +R/W .
Jan 24, 2008 | Cyberhome DVR 1600 DVD Recorder
Several problems
you may want to check all of your coax conections and stray ground shield piece littl tiny silver mtal wire will cause that reaction or you may have a ad reciever if so if ou have the directv inurance they will replace it for no cost to you at all.
good luck
please rate
Jan 11, 2008 | Philips DSR708 DirecTV DTV Receiver /...
Tivo pausing
Most likely your hard drive. You can replace it and not junk the unit.
Oct 05, 2007 | Philips DSR708 DirecTV DTV Receiver /...
Video recording
Ok this is generally caused by the "Frame Rate" usually for full motion video faster is better and about 25 frames a second will give OK picture.. with say 30 frames a second being better, faster means more CPU usaeage too. You need to use the program to "Set" the frame Rate. You could try my old Favorite Amcap here.http://www.freewarezoom.com/archives/amcap This will at least allow you to test stuff.
Jul 31, 2007 | Logitech QuickCam Pro 5000 Webcam
Directv HR20-700 Logo
789 people viewed this question
Top Directv Televison & Video Experts
john milligan
rundiggity
Are you a Directv Televison and Video Expert? Answer questions, earn points and help others
