Question about Coby TF-TV1901 19 in. LCD Television
My Coby flat screen tv does not show a picture for about 20 minutes until after I turn on the set. There used to be a blue screen with COBY on it that would pop up when I turned the tv on, but now that does not come on, just the sound and then some vertical color lines appear and it takes about 20 minutes for a picture to appear. Any ideas?
5 Suggested Answers
  • 95 Answers
SOURCE: Lost TV remote for Coby Flat Panel TV, 17inch
Universal remotes are not compatible with any Coby TV. You can get a remote directly from Coby:
Send:
$6 Money Order - 'Made out to Coby Electronics'
note with your name, address, phone#, model# and what part you need
Send to:
Coby Electronics
Att: Customer Service
56-65 Rust St
Maspeth, NY 11378
Posted on Aug 23, 2008
SOURCE: Missing: Coby code for any universal remote
NOT SOLUTION. I wrote customer service at the vendor and I called customer support at the manufacturer. The vendor wrote me back and Coby Customer Support told me the same thing: There are no codes for the TFDVD2274. So now I turn on the lights and figure out which stupidly placed identical button is for pause, play, reverse, fast forward, etc. That is, after clicking the identical button (but fairly easy to find since it is the top left button of all the identical buttons) that pops up the mode options and clicking the up-down arrow 5 or 6 positions to change from TV to DVD. All fairly learnable once you have done it a few hundred times.
Posted on Jun 27, 2009
  • 8457 Answers
SOURCE: My Coby tv's VIDEO turns off after a few minutes
Ur backlight IC inverter board is dead.Tries disconnectors & reconnectors the connections to the board see if it work?
Posted on Sep 03, 2009
  • 246 Answers
SOURCE: No picture on coby tv
I'm not certain but it sounds like there is a loose video cable in there...if you are able to, take the tv apart, and literally push on all of the connectors and cables to make sure they are not loose. The main video cable may not seem to be loose, but once it is making contact again, it should clear that mess up. Just look for cables running to the main screen and pull them off and put them back. Then put the tv back together again and see if it worked...it usually does. why does this happen? Some blame it on dust, others blame it on quick manufacturing processes...whatever the case, the cables become slightly seperated from the controller board and that happens...it also happens to computer monitors too...Good luck and take your time. If there are a lot of screws and things either take pictures of where they all went or write it down. I like to make a diagram on a piece of paper and tape the screws on the diagram to show where they went.
Posted on Sep 01, 2012
Why doesn't it turn on?
The problem could be internal power supply failure. The blue light merely indicates power is getting to your TV.
Feb 04, 2016 | Coby Televison & Video
Can a tv inverter board cause tv to not display
inverter board may be used to power backlight for the lcd display. If it is similar to laptop lcd displays in functionality .
http://www.ehow.com/how_7501465_check-tv-inverter-board.html
Apr 17, 2015 | Coby 40 TFTV4028 LCD TV
Coby KTFDVD 7070 unable to access tv channels
check that your set is set to the correct source. if one source doesn't work another should, say a dvd player. if a dvd player gives you a picture then either the connection or cable you are using is bad, possibly the tuner. it sounds like a connection problem to me.
May 08, 2014 | Coby Televison & Video
Coby tv screen wont turn on
Sounds like a Power Supply problem. This problem will probably require a live, in-person tech, especially if you have no hands-on experience. Do you know anyone with soldering experience or other electronics hands-on experience? If so, I could communicate a process to them. Tx, Petra
Jun 15, 2013 | Televison & Video
Coby HD LCD TV Blinking and Flickers ?
It sounds that the problem is with its back-light inverter baord itself
May 28, 2013 | Coby TFTV3225 32 in. LCD TV
My coby tftv3229 wont turn on and I've only had it
If its two weeks old why are you here? Take it back to point of purchase and either have it fixed or replaced or get a refund.....
From the brand you likely are in UK but here all sets come with some kind of warranty==the problem sounds like a power supply issue but if you have a warranty and open the set it will void that warranty.
Apr 11, 2012 | Coby Televison & Video
Coby tv will not come on
Died and went to monitor heaven. U can always check out the power supply. But other than that you may need to go shopping.
Jul 28, 2017 | Coby 20" Flat Screen TFT LCD TV Monitor
I have a 7 inch Coby digital frame and it only shows half the screen, how do I reset?
there is no reset on the frame itself, when you turn it on, it should show a blue screen with coby logo, if this is also halfed, then the screen is broken.
Mar 06, 2011 | Coby DIGITAL FRAME COBY DP102 RTL
Coby TF-TV1901 19 in. LCD Television Logo
95 people viewed this question
Top Coby Televison & Video Experts
Computer Repairing
Computer Repairing
Henry  Thomas
Henry Thomas
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
