Question about Sony DVP-CX995V Multi-disc DVD Player
I had to remove the front panel to get the front door to open. When I placed the front panel back in, there is a black wire that has a metal clip at the end, in about 1 1/2 inches in length. Where do I place this? Thank you kindly.
Clip it onto the chassis base.
Posted on Nov 03, 2010
How do you remove door panel on rover 75?
1st off remove the plastic moulding inside of the door release ,undo the small screw,at the bottom of the door there are 4 screws[usually pozy drive] undo them, prise off the bottom part of the cover [the door pull arm]inside there is a large pozy screw,undo that,then using a medium screwdriver or a small pry bar placed between the door panel/door,prise away the panel section by section,beginning from the bottom,until you have unclipped all the plastic retainers,then gently lift away upwards,do not drop,as you have to unclip the door release cable from the back of the door panel,making sure to remember how it is sitting on the door panel and the lever,so to ease the re-assembly.
Jun 01, 2014 | 2005 Rover 75 1.8
Wd62p replace hinges
First of all remove the door from the machine by unscrewing the screws on the hinge than remove clip at the top of door seal, when it unclips remove metal band, pull front of door seal off of front panel, Pick up metal bracket. Now with the hinge attached to door hold in place and place bracket behind the two holes fit screws and then fit the seal and clip.
Regards
May 05, 2012 | Hotpoint Ultima WD72 Front Load...
Frigidaire Model NMER336FS0 How do I change the interior light bulb in the drum?
Unplug the dryer first, of course. With a putty knife, locate the clips under the front of the main top to release the spring clips. Lift the top and support it open. Disconnect any wire clips that are attached to the front panel, such as the door switch wires or wiring harness. There may be a zip tie attached to the wiring harness that you have to remove simply by cutting it off. On the inside, remove the front panel mounting screws down along the front inside edge of the panel. Pull the front panel up and out to remove. Disconnect the wires from the light bulb, carefully noting which wires go where, and press the release tab to remove the old light bulb housing. Install the new bulb and assembly by inserting it into the front panel and snapping it into place. Reattach the wires. Replace the front panel by aligning the slots at the bottom of the panel with the support clips. Lift on the front of the drum as you snap the front panel into place. Replace the panel screws and reattach any wiring that you disconnected to remove it. Rotate the top back into place, pressing down on the front to secure the spring clips. Plug it back in and voila! Good luck!
Jul 16, 2011 | Dryers
Trying to remove rear door handle on chrysler lhs 99
Hello, to remove and replace the rear door try the following:
1. Disconnect the negative battery cable from the battery of your Chrysler LHS. You can accomplish this with an open end wrench, to prevent any injury or short in the electrical system as you are working on the door lock switch. Place the negative battery cable out of the way so it does not touch any metal parts.
2. Undo any screws that are holding the lower door panel to the door with a screwdriver. Unclip the plastic hold clips that are attached to the back of the panel by carefully pulling them away by hand.
3. Locate the electrical connector wires. These wires run behind the panel to the door arm rest and detach each wire connector by hand. Remember how the wires were attached so you can put them back the same way when it is time to reattach them.
4. Lower the door panel away from the door. Then, remove any screws holding the upper door panel in place. Remove the door handle pull cup that covers the door lock switch and door handle by carefully popping the cover off after you have removed the screws holding it in place.
5. Detach the upper door panel from the door. You can do this by pulling it away carefully from the plastic clips. Move the upper door panel out of the way and locate the door lock actuator switch. Remove the screws from the actuator switch that are holding it in place and disconnect the electrical wires attached to the back of the switch.
6. Replace the old door lock actuator switch with a new one. This replacement can occur by connecting the electrical wires to the back of the new switch and reattaching the switch to the door frame with screws. Put the upper door panel back in place, securing it to the door frame with plastic clips and screws.
7. Reattach the door handle pull cup to the upper door panel with screws. Then, put the lower door panel in place and reattach the electrical wires to the window switches underneath the armrest. Attach the lower door panel to the door frame with plastic clips and screws.
8. Attach the negative battery cable to the Chrysler LHS battery with the open end wrench.
Thanks
Jul 27, 2010 | 1999 Chrysler LHS
HOW TO I GET INSIDE A NEPTUNE DRYER MODEL 9700 TO FIX A FUSE
Unplug the unit.
Remove the top panel(two bolts in the rear metric 10 or Phillips will work) There are four screws across the top front of the control panel remove those and the panel will swing out and down,move it back and forth while pulling upward it has plastic clips on the bottom that keep it in place.follow the wires from the panel to the control board and unplug them or you can just lay the whole panel on top of the unit.
Open the dryer door and remove the two phillips screws on either side at the bottom of the door opening,then remove the four screws across the top of the panel it will lean out toward you,unplug the door/light switch and lift the front panel off the bottom clips.
You're probably looking for the thermal fuse located in the plastic elbow of the blower housing at the bottom of the unit it will be the round metal disc with a brown or black plastic backing.check your vent going outside and make sure it is completely clear/open doesn't have to be spotless clean but if it gets restricted in any manner it will blow this fuse.
Sep 13, 2009 | Maytag MDE9700AYW Neptune 174 Electric...
How do I remove the front door panel to replace the mirror
Normal 0 Disconnect your negative battery cable. Locate and remove the screws that hold your interior door handles in place (they may be hidden by snap in, or snap on clips). Remove the interior door handles, then disconnect the wire clips to the switches. Your panel is held in place by snap in clips; use a small pry bar to pull them from the door (try to get as close to, or directly under the clips to prevent them from tearing out of the door panel). Once the clips are pulled, pull the panel upward to remove it from the door.
Install in reverse.
If you don't have power windows you will have to remove the manual window crank. It is held in place by a clip on the back side of the base. To remove the clip, you will need a small hook (kind of like a knitting needle). Put the hook in behind the base, and grab the clip and pull it off. To replace it, slide the clip back on the window crank, and snap it back on the door.
May 25, 2009 | 1998 Buick LeSabre
Window off track
Looking at the opened door from the inside remove the philips screw near the upper hinge. Pry the speaker grill off with a thin blade putty knife, starting at the bottom left and work to the right. Remove speaker screws and the three screws in the recessed plastic spaces behind. Remove the square covers behind the handle and in the arm rest. Remove the 2 philips screws exposed. Start to pry from the top hinge side between the plastic door panel and the metal door. Work your way around the door until plastic clips release. Once the bottom of the panel and sides are free, lift the panel up and off the door being careful not to pull wiring and door handle mechanism loose. Unplug the as much of the wiring as you can and support the panel so as to not stretch the wiring. Pop the plastic retaining clip on the door handle connecting rod and lift the rod out of the handle. Slowly peel back the vinyl/rubber door cover stuck to the metal door. The window is held in the lower track with two clips that are bolted to the track. Unbolt by raising or lowering the window and using a 10MM socket on the nuts to loosen. Remove the window seal along trhe bottom of the window opening by prying straight up. You can then remove the window and re-epoxy in the lower clips and reassemble window in reverse order.
Mar 08, 2009 | 1998 Plymouth Breeze
2001 tahoe door panel
THE COUTESY LAMP IS HOT DUE TO THE DOOR BEING OPEN WHILE THIS PROCEDURE IS DONE!!!! First: Remove the triangle panel at the top of the door (behind the mirror). This is held in with two metal clips about half way down the panel. Do not pry at the bottom as there are two tabs that slide in to keep the module in place. I pulled the top of the triangle out by hand then could see the clips and used a straight screw driver to carefully pry from under the triangle panel so as not to scar the visible part after re-assembly. Once these two clips are disengaged the triangle should pull straight up and be free. Second: Carefully pry out the door lock insert. There are no significant tabs to worry about here. Again a straight screw driver and care should not leave any scars. The lock insert has no mechanical connection but simply is used to slide the lock rod. Re-installing you will need to align the slot for the rod in the lock or unlock position depending on the rod position. Third: Carefully pry out the insert that is located at the door handle. Start at the rear of the insert as this is where the clips are located and once the rear is out pull open the door handle and pull the insert to the rear so as not to break off the two front tabs. You will find two small screws (mine were black). One near the front and one at the rear of the door handle module. Both are 7 mm and are the only ones that need to be remove in the process. (I understand some door panels have an other screw at the very bottom of the door as well; guess you'll have to check you door. Fourth: Pry up the control panel for the automatic windows and unplug the wires. Here again start from the rear and once the rear is free pull the module to the rear and it should come free. There are tabs at the front that you do not want to break off. To unplug the wires - First remove the clips (mine were blue) that hold the plug in place. There is also a push catch on the plug that must be depressed to release the plug from the control panel. Fifth: My door had no push in 'buttons' or clips to hold the door panel in place. It simply lifted up and became free with the exception of the numerous wires attached to things like the speakers, the remote mirrow and courtesy light. Unplug these wires by first taking off any retaining clips (usually blue) and then unplug the wires. The courtesy light pulls straight out (toward the front) and watch your fingers as this is one hot little bulb. The door panel can then be totally removed and set aside. You may find it easier to remove the courtesy light lens by prying out the rear first and then pulling it toward the back of the door so as not to break the two front clips. I found it easier to do this and then install the bulb in the lens and then install the lens back in place. Six: I'm sure I don't need to say it but here goes - ' reverse the procedure to re-assemble'. Remember to poke the courtesy light wire out the hole and re-connect the remote mirror and speaker wires before the door is put in place. The wires to the window and electronic lock module can be installed after the door is back in place. Working by myself made the door difficult to handle during re-installation so I took a 'light' bungy cord and placed some protection over the top of the door and hooked the bungy into the opening were the door handle was to come through. This allowed me to steady the door and do the electrical connections as required. PS - we were replacing the power window motor and were able to 'force' the cable into the gears of the new motor by turning the motor and this saved a lot of further disassembly. The contacts on the new motor were reversed so I removed the pins from the plug going into the motor and reversed them - presto.
Jan 19, 2009 | 2001 Chevrolet Tahoe
GE dryer is getting louder when running
most common cause is the failure, or wear of the rollers at the rear,
the drive belt places a lot of torque on the drum, and it has rollers to support this force, in addition to nylon guides as the front has
good roller
worn roller
most dryers access from the front, the front panel and door come off,
here are generic removal instructions
with dryer unplugged examine lower front panel.
If there are two screws at lower corners
  • remove screws
  • swing front panel up from bottom
  • unhook top clips
  • undo door switch wires
  • set panel and door aside
If there are no screws
  • remove llint screeen from top
  • remove 2 screws from under lint screen
  • with putty knife or other blunt blade
    push spring clips at front top corners
  • tilt top up
  • remove 1 screw each side 1/3 way from top of dryer
  • tilt front panel down
  • undoor door switch wires
  • set front panel aside
Common to both
  • reach under drum to belt tensioner, pull tensioner to end of spring travel
  • unhook belt from motor and tensioner
  • withdraw drum forward
  • examine rollers felts nylon guides
replace rollers in pairs if worn
replace nylon glides if worn
replace felts if worn, the back one may wear before the front one, if the dryer is the open drum type,
Oct 17, 2008 | Dryers
Sony DVP-CX995V Multi-disc DVD Player Logo
105 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
