Question about ASUS A9600GE/TD RADEON 9600, (128 MB) Graphic Card
Triple monitor set up
Radeon 9600 sereis (on windows xp)
i could not find an easy answer for my problem
can i have a triple monitor set up?
VGA to Reg monitor
DVI to HDTV
TV out to reg TV
I would like to run all three at once if it is possible?
IF so how can i do this?
currently i can only get DVI and VGA as a dual OR TV and VGA as a dual, but not all three....???
THANKS
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 100 Answers
That is because the tv is a connector for the tv only.. the other ones are for the computer monitor only.. you can only set up one at a time... If you want the tv one then only get the tv one to work...
Posted on Mar 24, 2008
SOURCE:
I have ATI RADEON 9600 Pro, (256 MB) graphic card and I'm looking to buy a new monitor; does anyone know what resolution my card supports? I can't find it anywhere. Thanks!
  • Supported Display Graphics UXGA (1600x1200),
    1152x870,
    SXGAW (1600x1024),
    1152x864,
    SXGA (1280x1024),
    SVGA (800x600),
    720x480,
    1856x1392,
    2048x1280,
    QXGA (2048x1536),
    VGA (640x480),
    XGA (1024x768),
    1280x960,
    HDTV (1920x1080),
    1792x1344,
    2048x1152,
    1920x1200,
    1920x1440
Found at: http://reviews.cnet.com/graphics-cards/ati-radeon-9600-pro/4507-8902_7-32107705.html?tag=mncolBtm;rnav
Jul 25, 2011 | ATI RADEON 9600 Pro, (256 MB) AGP Graphic...
Vga driver
If your notebook si NEC?LaVie RX?LR700/8E then the VGA chip is Mobility Radeon 9600
http://www.opendrivers.com/driver/291088/ati-mobility-radeon-9600-9700-x300-x600-x700-x1300-x1400-x1600-driver-9.3-windows-xp-free-download.html
At the middle of the page there is button
May 21, 2011 | NEC LaVie RX Notebook
Ati radeon X300 SE how to get both monitors working at the same time. Windows XP screen settings and ATI Catalyst Control Center can see only one at a time, but not both...
Use the DVI port, and the VGA port on the ATI Radeon X300SE graphics card.
If you have two monitors that are LCD, and they both have a DVI connector, use a DVI to VGA adapter for the VGA port on the ATI Radeon X300SE.
[You need a Female DVI to Male VGA adapter, such as this example,
http://www.directron.com/dviadapter.html
Turn both monitors on. Right-click on an empty spot on the desktop screen. Left-click on Properties, then the Settings tab.
Left-click on the monitor icon with the 2 in it.
Go down to ->Extend my desktop to this monitor, and left-click in the box to the left of it.
Go down to the right, and left-click on Apply.
Now go over to the left, and left-click on OK.
You should now have your desktop screen on both monitors. When you open a window on your Primary monitor, (Monitor icon 1), Left-click on the frame, hold the mouse button down, and drag this screen to the Secondary monitor.
If it doesn't work this way, drag to the other side.
Sep 07, 2009 | Computers & Internet
Radeon 9600 is showing black and white picture
check to make sure monitor is pluged in all the way and check with another monitor. if no good check catalyst control center sharpness setting (if conecting via s-video) if not you will probably have to resolder the connections on the board
Aug 14, 2009 | Diablotek RADEON 9600XT Video Card -, ...
Radeon 9600 (128mb) detected as sis315 vga (16mb)!!!
The SIS315 is an integrated video card which uses shared RAM in order to work. Most mainboards will automatically turn off the integrated card as soon as an AGP or PCI-e card is installed. Yours may not do this, or maybe the card just needs re-seating as it is not picking it up correctly.
First you need to double check to make sure the new card is firmly in the slot (this is a common problem that is often overlooked) re-seat card and push it firmly and evenly into the slot. Next, on start-up, go into BIOS and make sure all on-board video is disabled. Save and then restart as normal, hopefully it will see your new card and then be looking for the drivers.
It is possible that the BIOS has your on-board video set on auto, which would mean if no other card is present then the PC would automatically go back to on-board video. Which means it can't see your new card, which in turn means it is either not installed properly or it is faulty.
Just out of interest, it may seem a stupid question but you have plugged your monitor cable into your new card and not the on-board socket?
As always much more info is needed for more help
Bri
Feb 04, 2009 | Connect3D : RADEON 9600 128MB TV-out DVI...
Radeon R9600/XT GRAPHICS CARD
Yes, they both will act independently if you choose to use it that way or they will show the same picture, one is a DVI output and the other is VGA. Use the ATI’s CATALYST software suite provides the ultimate software required to enjoy the full acceleration of your ATI Graphics Accelerator card. You can use it to separate your Primary video from your Secondary video.
Jan 03, 2009 | Abit R9600XT-VIO RADEON 9600 XT, (256 Mb)...
Viewsonic vp912b lcd display will not work.no DVI
Yes you can but there should be an option in the monitor settings for DVI... Maybe if you go into safe mode and attempt adjusting settings for the ati for the dvi output, from what I hear that monitor is nice with the DVI option would be aa shame to lose that.
Dec 22, 2008 | ViewSonic VP912B (Black) 19 in. Flat Panel...
Radeon 9600 XT AGP - wn't activate second monitor as TV output.
hi
check if you have the latest software or not if not download from http://ati.amd.com/support/driver.html this will give you a more simple and easier way change the double monitor settings
Nov 12, 2008 | ASUS RADEON 9600XT, (128 MB) AGP Graphic...
Ati radeon 9600 video card
what you have the ATI card hooked up can you see the boot screen? If you can see that you might want to try going into safe mode and making sure your graphics settings aren't set beyond the capability of your monitor. If you can't see the boot screen then your card might be dead.
Apr 28, 2007 | ATI Radeon 9600 Pro 256MB DVI+CRT+TV 8X...
Open Questions:
See all ASUS A9600GE/TD RADEON 9600, (128 MB) Graphic Card Questions
ASUS A9600GE/TD RADEON 9600, (128 MB) Graphic Card Logo
108 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
