Question about Husqvarna Rear Propelled Rear Bag Lawn Mower (CA)
How do I replace the drive cable?
How do I replace the drive cable on a self propelled 7021 model that is 4-5 years old bought at Sears?
4 Suggested Answers
  • 19 Answers
SOURCE: I have a Husqvarna model
You probably answered your own question, the belt is the first thing i would check
Posted on Jul 05, 2011
  • 122 Answers
SOURCE: cable broke on self propelled 7021r. Is this easy
Here's a diagram of the mower, I not familiar with the Husqvarna lawnmowers but have replaced many cables from other brands of mowers, should be simple with some basic tools.
http://www.partstree.com/parts/?lc=husqvarna&mn=7021+R+%2896143004600%29+%282009-01%29&dn=90_25_0003
Posted on Sep 04, 2011
If the belt bis turning the pully, and the axel is turning, how could the real solution be the bbelt??
Posted on Mar 21, 2012
I have a self propelled lawn mower and the the belt that propells the wheels is loose, do I need to replace it or is there a way to tighten the tension.
Cathy, there is a way to adjust belt tension on some models whether it is by the cable or a slotted bracket where the idler wheel is mounted, depends on make and model. If you have your manual check in it for belt adjustment. Could be stretched belt, stretched cable, worn/oil on pulley, seized tensioner, stretched/broken spring on tensioner,etc.
How to replace drive belt on Craftsman 22 Front wheel drive mower
How To Repair Troubleshoot Self Propelled Part Of Lawnmower HD
Fix Self Propelled Craftsman Push Mower
How to adjust drive belt on 6 75 Horsepower self propelled lawn mower...
May 23, 2016 | Garden
The self propel system slowly stopped working and now doesn't work at all, what could it be?
You didn't specify the make or model of your mower, but generically speaking for self-propelled walk-behind mowers, the drive belt or the front wheel gears can wear out after several years of use. The drive belt could also be loose or off the pulley. The belt and the front wheels can usually be replaced.
You can remove the drive pulley cover and see if the belt is off.
The other components that make up the drive system are the gearbox and the engagement cable. Sometimes the cable can get get out of adjustment or come loose.
Jul 23, 2015 | Garden
Lawnboy self propelled walk behind mower
a drive that old is going to be hard to repair so it generally not worth it
Sep 11, 2013 | Garden
Can't find grass bag
As long as the model number is correct. Sears still carries the bag for this.
Part No. 410693 for $40 us
I found this at Sears parts direct, and yes there is a website.
Jun 17, 2013 | Craftsman Garden
Cable broke on self propelled 7021r. Is this easy to replace?
Sep 04, 2011 | Husqvarna 21" Lawn Mower with Honda GCV160...
I have a Toro Proline walk behind . Problems with the self propel
I suspect the drive belt, not the Hydro. Especially if the drive belt was never replaced. The belts are known to stretch and wear out over time. It's a cheap part.
Jun 04, 2010 | Toro Lawn Mower With Toro Power Tools
Toro model 20038 self propel problem
Try taking the back wheels off and lubricating the joint cogs and wheels with ,say, 3 in 1 oil . The dealer recommended doing this once every couple of years as preventative maintenance when I bought mine , and it has solved sticking problems for me .
Sep 12, 2009 | Toro Lawn Mower With Toro Power Tools
Craftsman self propelled lawn mower will not propell
Take off the cover up front on the self propel. Engage the self propel and make sure your cable is not broken. If that is ok then remove the wheels and inspect the molded cogs on the inside of the wheels and make sure they are not stripped out. If they are stripped go to www.sears.com and on the tool bar click on parts direct. Under model number enter yours and it will take you to a parts diagram. Get the part number for the wheels and go to local small engine parts dealer and get new. You can also do a search on the web for the wheels and maybe get them cheaper.
Good luck and let me know if this helps or you need any more help.
roundo4
Aug 16, 2009 | Garden
Self Propelled does not work
if you look below the headlamp of your vac you will find a cable that attach's to a piece called the actuator arm. either this piece is likely broke or the cable itself. always work the power drive smoothly or things will break. also could be that the smooth belt is stretched and will cause the same problem. belts should be replaced every 4 months. good news is all parts above should be under $5. dont let anyone tell you that you need a power drive assy, that usually isnt the case. good luck!!!
Sep 24, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Husqvarna Rear Propelled Rear Bag Lawn Mower  (CA) Logo
149 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
