No sound I have a RCA Colortrak 2000 TV Model # F27155AK Serial # 824370635 and it has no sound. For a time I was using external speaker which was an option for this TV, but the external speaker option is now not working. Do you have a suggestion to this problem?
    Scholar:
  • 87 Answers
If you are using a cable box try patching the audio from the box to your stereo system. If that does not apply to you, then getting the set fixed or replacement is in order. A colortrack 2000 is like 20+ years old. They don't make them like that anymore., Too bad.
Posted on Mar 24, 2008
How do get it to work
go into tv settings and then speakers. switch to external speaker.
Apr 14, 2016 | RCA Televison & Video
How do I hook up my ps3 to my rca colortrak?
would be best to get a old vcr, then with a cable you hook it to the vcr and play it thru the vac
Mar 03, 2015 | RCA Colortrak 2000 Tv Large Tube Screen Tv...
Rca colortrak 2000 manual
You may be able to get a manual by requesting it directly from RCA.
Jul 28, 2014 | RCA Colortrak 2000 Tv Large Tube Screen Tv...
TV channel sound from a different channel
I just unplugged the tv from the power source and disconnected the cable connection and then reconnected them back after sometime. The TV started auto programming after turning on and that resolved the problem.
Oct 18, 2009 | RCA Televison & Video
52 inch (Model D52W19) RCA TV's sound doesnt work
internal / external selector switch on back of tv near inputs or setting in menu under settings or sound labeled - internal amplifier/ external amplifier.
Sep 28, 2009 | RCA D52W19 52" Rear Projection Television
TV has sound but no picture RCA ColorTrak 2000 P52150CP
If I had a model # it would be helpful but my guess is the deflection circuit failed and a fuse opened in that circuit. Could be vertical or hoizontal circuit failure but either way you will need test equip. as well as solder/desolder equip. to repair it. If set is over 10-12 years old you may consider replacing set in this case Sorry I can't be more help.
Jun 02, 2008 | Televison & Video
Rca projection tv sound problem
You could try to get the set fixed but I would say the set is just worn out.
Time to buy a new TV I think (going by the picture above anyway)
Dec 28, 2007 | RCA G27647 27" TV
1987 RCA Colortrak 2000 Television
Line 1 is Channel 91, Line 2 is Channel 92 - you can select them directly using the remote
Sep 17, 2007 | Televison & Video
RCA Colortrak Plus Model # F27672ET
Your set might have a leaky capacitor that takes a while to fully charge to the supply voltage as well as loose conections to the vertical Ic,sometimes you can identify it because it overheated and the insulation is peeling,sometimes they look normal but they are bad.If you are familiar with tv service you will have a place to check but if you are not too familiar seek the assistance of a servicer.
Sep 30, 2006 | Zenith IQC50H95W 50" Rear Projection...
26in rca colortrak 2000
Very common problem The Highvoltage transformer and the horizontal output transistor has to be replaced. If you have no tv repair experience, this is not a repair for you. seek a professional. Should cost about 175 to 225 for this repair. Good Luck
Jul 12, 2006 | RCA F32450 32" TV
Televison & Video Logo
105 people viewed this question
Top Televison & Video Experts
