Question about HTC TyTN II Smartphone
The unit does not switch off and the screen remains on all the time I have carried out a soft reset but still the problem persists
    President:
  • 1,118 Answers
Firstly, go to 'Start > Settings > System tab > Backlight'. There, in one or more of the tabs, you will find checkboxes named 'Turn off backlight if device is not used for', next to a dropdown menu representing the timeout value, for operation both under battery and external power sources.
However if you find these settings to be correct, and, yet, your device refuses to follow them, I think something you have installed might have messed them up. Perhaps a hard reset would fix your problems. A hard reset will restore your device to its factory defaults, i.e. all the programs you have installed, as well as your personal data, will be cleared. So, if possible, make a backup, to be restored afterwards.
If your device is operational, you can hard reset it by going to 'Start > Settings > System tab > Clear Storage', type in '1234' and, then, tap 'Yes'
However, if you are e.g. stuck in the splash screen phase, you can still hard reset your device by hardware means: press and hold both softkeys (the ones marked with '-',) and, then, whilst keeping them pressed, briefly press the reset pin with the stylus pen. Release the softkeys only when instructions come up on-screen. Press the green Send/Call button to confirm the procedure.
Hope you are able to sort your problems out.
Cheers! Carlos
Posted on Apr 26, 2010
The unit will not turn on check there is power is there a reset ?
Welcome to FixYa.
Do a soft reset first, if the problem still occurs, do a hard reset.
Soft reset (Does not delete GPS Data)
  • Turn unit OFF
  • Press and hold the PAGES key
  • Press and hold the PWR key
  • Release both buttons when the unit powers up to Full Map Screen
Hard reset (Deletes GPS Data)
  • Turn unit OFF
  • Press and hold the ZIN & ZOUT Keys at the same time
Thank you for using Fixya, have a great day.
Jas247
Jul 22, 2011 | Eagle Industries FishElite 640C GPS...
Screen freeze after soft reset
Hello
did you remove the battery ? Shut off it and the remove the battery some freeze can be resolve like that. if not may be you need to update the firmware of the phone.
melnavz
Apr 01, 2008 | Samsung i760 Black Phone
Will only operate when plugged in to the mains adapter
Hi angelahar313,
You can try to reset the unit and recharge it again.
This operation will not affect your ebooks:
1. Leave the unit connected to the adapter
2. Hit the reset at the bottom for 3 seconds
3. Slide the power switch (the screen will blink and boot up)
If after that the proble still persist, you can try a hard reset. NOTE: This will set the reader to factory settings and will delete all you content.
1. With the unit connected to the AC Adapter, hit the reset button at the bottom for 3 seconds
2. Slide the power switch
3. While the reader shows "Opening Book" press and hold the "0" button and the directional down arrow at the same time, until " Reset All" appears on the screen
4. Press number 5 to confirm and turn the unit back on
5. Try recharge unit and disconnect it and see if that works
If these steps do not work, then contact Sony to get the unit repaired.
GoodLuck!
eBookBoy
http://digialreader.freeforums.org
Jul 18, 2011 | Sony Reader Pocket PRS-300
My mp3 player syncs to the computer and shows the connection screen but once i unplug it, it will not turn on.
Install a new battery and reset the player. Schematics can be found in the owner's manual. If the problem persists, service may be required and can be obtained by carrying the unit in to the place of purchase.
Mar 04, 2010 | Insignia NS-DV2G MP3 Player
Gas furnance would only operate for about 3-5 minutes then turn off. Replaced gas valve on furance for a Rudd comerical A/C 4 ton unit model UKKA-A048JK10E. Now the blower fan turns on but the igniator and...
the rollout switches will be located at the ends of the burner assembly and will have a manual reset. they must be manually reset to ensure that the problem has been corrected. Most units will go into a soft lockout for a time and eventually a hard lockout if the problem persists. Go to tempstar.com and go to their troubleshooting section for a gas furnace. the codes they give are pretty common for alot of furnaces and see if they help
Dec 10, 2009 | Ruud UAKA042 Air Conditioner
I have been having problems with the alignment on my touch screen. Just reset it and have been tapping the target repeatedly but it continues to move diagonally across the screen ad nauseum. What can I...
Remove the Screen protector from the device screen and then calibrate the screen with the stylus.
If the issue still persists, perform the Soft Reset on the device.
1. Use an unfolded paper clip, or the reset tool at the tip of your stylus.
2. Gently press and release the RESET button inside the hole on the back panel of your device .
3. After a soft reset, a logo screen appears, followed shortly by a Preferences screen asking you to set time and date.
4. All data on your device should be retained.
If the issue still persists, perform the Hard Reset on the device.
1. Press and hold the Power (on/off) button on the front panel of your device.
2. While holding Power, use an unfolded paper clip, or the reset tool at the tip of your stylus. Gently press and release the RESET button inside the hole on the back panel of your device.
3. If you see a progress bar, keep holding the Power button.
4. Next, the Palm Powered screen will appear. Release the Power button when you see it.
5. You'll see a screen that asks: Erase all data? YES = "up" button NO = any other button. Press UP on your 5-way navigator to complete the hard reset.
Your device will then take you through a series of screens to calibrate the digitizer and verify the time and date.
Note: A hard reset does not delete the current date and time. It does restore other settings to the factory default.
Sep 22, 2009 | Palm Tungsten E2 Handheld
Treo 650 "Dead Screen"
Try plugging in your Treo as if you were charging it.
Then click the reset button in the back.
This should reset the charging mechanism inside.
See if the Treo starts to charge again after that by letting it sit for 1-2hrs.
Jan 04, 2008 | Palm Treo 650 Handheld
Screen Display Problem
Do hard reset? See Owners Manual.
Call Garmin they are very helpfull
Garmin USA 1-913-397-8200
Tech support 1-800-800-1020
1-888-442-7646
8am to 5pm Mon -Fri
Garmin Europe 44 1794-519944
Garmin Taiwan 886 2-26429199
Oct 27, 2007 | Garmin iQue 3600 GPS Receiver
Kodak DX6490
A repair will cost a lot- Go for a new camera
Sep 04, 2007 | Kodak EasyShare DX6490 Digital Camera
HTC TyTN II Smartphone Logo
252 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
