Question about Wellness Ijoy Ottoman 3.0 Microsuede & Faux Leather
Ottoman comes on and starts then shuts down after about 15 to 20 seconds. pushing the start button just does the same thing over again. will not run longer than about 20 seconds.
Sharp tv shut down after about 2 seconds
Could be power supply trouble. It tries to start but can't and shuts down.
Dec 06, 2013 | Televison & Video
Basement flooded and got approx 12 inches of water in bottom of dryer let sit for a week to dry before trying when pushing start button will come on but wont continue running unless you hold button in ...
Sorry to say but you will need to replace the motor. After water gets in you can rarely save the motor no matter how long you let it dry.There is an internal over load inside the motor that is cutting out after 30 seconds and once it cools for 15 or 20 minutes then it resets .Hope you found this information helpful and thank you for using Fix ya.
Jun 24, 2011 | Whirlpool Dryers
WINDOW XP WOM'T SHUT DOWN
Hold the power button in for a few seconds it will shut down. Then unplug system and push the power button down with it unplugged then replug it in and power up again. Then do a proper shut down again to see if the problem fixed. I hope this assisted you. John
Feb 07, 2011 | Microsoft Windows XP Professional
Runs when PTS held but shuts off when released/no heat
No problem at all.The motor has a start and run winding.Your run winding is bad.The reason you have no heat is the run winding has to run to close the contacts on the motor switch.Replace the motor ,both problems solved. Hope this helps Please rate my response :)
Dec 13, 2009 | Kenmore Washing Machines
My car wont start
sounds like security shut down which will start run for second then shut down after several time the security will shut down completely.......you can try what is called the relearn proceedure..this is what you dealer will do...might have to put battery charger on car first... then put key in ignition and turn to the run position do not crank leave it in the on position for ten minutes...... then turn key to the off position then back to the run position again for another ten minutes.....for the last time turn key off then back to run for the last ten minute cycle.... after the final ten minutes is up turn key to off position then attempt to start... let me know
Aug 31, 2009 | 1997 Chevrolet Cavalier
Laptop keeps losing power at start up and shuts down repeatedly
does it run with the power cord plugged in? if so your batterys dead, otherwise harddrive/bios/motherboard fault? is your power supply charging the battery?
May 09, 2009 | Compaq Presario R3000 Notebook
I replaced the burnt out lamp,not working !!!
This may sound crazy. If you still have the old lamp. Put new lamp in old housing, and try that.
Mar 18, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Wellness Ijoy Ottoman 3.0 Microsuede & Faux Leather Logo
37 people viewed this question
Top Wellness Health & Beauty Experts
JonSnell Electronic
JonSnell Electronic
Are you a Wellness Health and Beauty Expert? Answer questions, earn points and help others
